  1. Feb 12, 2023 at 10:07 AM
    Daddo
    Daddo Well-Known Member
    Paul
    2004 Doublecab Tacoma 4wd
    Full Total Chaos Long Travel
    Mine is an 2007 w/ Sportsmobile 4X with the Atlas transfer case. 6.0 w Kill Devil Hills O ringed heads ARP Studs Etc. Had it since New.
    Digiratus, 03_taco_IN, jubei and 3 others like this.
  2. Feb 12, 2023 at 10:12 AM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    It's all in how you feather the initial launch and that axle wrap
    Kwikvette likes this.
  3. Feb 12, 2023 at 10:14 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Launch hard and it won't unload until the 1-2 shift and then it'll load up again haha. That's a downside of the Chevy 63s
  4. Feb 12, 2023 at 10:36 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Sounds like you’re staying busy huh!
    It’s been good, the bedliner on my new bus should be dry when I go back on Monday. We have to still all the seats up top still, and I have to wire in the tour audio system.
    0xDEADBEEF[QUOTED] likes this.
  5. Feb 12, 2023 at 10:41 AM
    RustyVT
    RustyVT Well-Known Member
    Vermont
    98 4Runner limited, 12 S60 T6
    OME overload springs, airlift bags, Hayden 679, 33x12.5 X-ATs
    "Launch" is a really strong word for what mine does haha. I'd describe it as more of a lazy moan
  6. Feb 12, 2023 at 10:45 AM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    A day or two later....
    Good looking van. I am not sure why the original owner of mine went the Quigley route. I wish it was a sportsmobile 4x4, paperwork shows it was drop shipped to Quigley prior to the sportsmobile conversion.
  7. Feb 12, 2023 at 10:49 AM
    Wulf
    rock raisin
    yup it's a Dana 60
    Am I crazy or is your tie rod kinked?
  8. Feb 12, 2023 at 10:58 AM
    treyus30
    Trey
    Mesa / AJ, AZ
    Speaking of this, @Speedytech7, have you considered at all upgrading your valve springs now that you have the Haltech to increase RPM? I know LCE offers a setup for the 5VZ, but the pricing seems ridiculous compared with when I did it for my 16 valve Saab
  9. Feb 12, 2023 at 10:58 AM
    m3bassman
    Green truck
    It's that.... Not supposed to be that way?
  10. Feb 12, 2023 at 11:00 AM
    Wulf
    rock raisin
    I guess it depended on the year
  11. Feb 12, 2023 at 11:00 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Beats sitting around!
    Im looking forward to seeing how that bedliner holds up, I used the harbor freight stuff on my flatbed and it’s….spotty at best. Need to redo it this spring i think.
    what do y’all use for a PA system?
  12. Feb 12, 2023 at 11:03 AM
    m3bassman
    Green truck
    Yeah but it's not what year van I have it's what year...axle?
    Abeyancer likes this.
  13. Feb 12, 2023 at 11:03 AM
    Speedytech7
    I haven't considered it, I'd really want to balance the bottom end better, being a V6 it has some of the worst primary balance and it's a truck engine so I'm almost sure Toyota didn't do a great balance of the rotating or reciprocating parts because RPM was never supposed to be a factor. The springs are overpriced like you say as well. It's not the only factor too, you really should convert to shim under bucket if you go to higher RPM on these heads or you risk the chance of winging one out of the bucket entirely. The 5VZ ranks pretty high on my list of engines that have no payoff for building, at least not in an old truck.
    treyus30[QUOTED] likes this.
  14. Feb 12, 2023 at 11:08 AM
    Wulf
    rock raisin
    Yeah. I just assumed you had the older 60 and not the 99+. My 04 didn't have a kink like that lol
  15. Feb 12, 2023 at 11:10 AM
    Wulf
    rock raisin
    @eon_blue look at how great the Ironman AT tread pattern is :luvya:
    eon_blue likes this.
  16. Feb 12, 2023 at 11:10 AM
    treyus30
    Trey
    Mesa / AJ, AZ
    Ya, I really don't want to "build it" either, but I figured there could be some easy power on the table since I can boost my way into actually having power in the higher RPM range - if it's easy to upgrade valvetrain, which it seems not. Too bad you can't just slide in a helper spring in the middle of the stock ones..
    Do we know what the factory valve seat pressure is? Maybe like 40lbs?
  17. Feb 12, 2023 at 11:16 AM
    Wulf
    rock raisin
    Abeyancer and Speedytech7[OP] like this.
  18. Feb 12, 2023 at 11:24 AM
    m3bassman
    Green truck
    And now you understand how I'm so fucking lost HAHA
  19. Feb 12, 2023 at 11:30 AM
    Wulf
    rock raisin
    Do you know what year it is? Usually there's a BOM cast into the housing somewhere that will tell you
  20. Feb 12, 2023 at 11:48 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Looking for friends
    Flattened wall days ago, finished wall primer yesterday, today it's wallpaper time
    :burp:
