  1. Feb 15, 2023 at 10:09 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Nope, that is just a 1-3/4" DOM tube on top of the frame, there is a narrow window where it will fit without a body lift.
  2. Feb 15, 2023 at 10:10 PM
    Shadowhunter
    Shadowhunter Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
    It’s fine now. I went wheeling and it ripped completely out. It flopped down and pogo sticked the ass end off the ground so I unbolted it. I used to love this truck, I swear :rofl:
    Wulf and Speedytech7[QUOTED][OP] like this.
  3. Feb 15, 2023 at 10:11 PM
    Speedytech7
    That happened on my old truck in the How To thread, shock fell off and pogod in death valley, that prompted that thread haha
  4. Feb 15, 2023 at 10:13 PM
    Wulf
    rock raisin
    I have a couple feet of 1.5" sch 40 that I was gonna use for that :burp:
  5. Feb 15, 2023 at 10:14 PM
    Wulf
    rock raisin
    must love it if you're still using it
  6. Feb 15, 2023 at 10:14 PM
    Speedytech7
    Make that Sch40 PVC and you're in business.
  7. Feb 15, 2023 at 10:18 PM
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    Low key want an 01-04 single cab 6 lug
    Taco critter likes this.
  8. Feb 15, 2023 at 10:20 PM
    Shadowhunter
    Nate
    13’ DCSB MT Sport
    Thanks for the chat. I think I have enough info to crawl underneath and visualize and throw a tape around. I’ve seen the outboard set ups. I don’t want to French anything or rub. I don’t need to get every drip of travel. Stock springs are clapped out, one shock is gone and just need down and dirty heavy hauler. I got a Ruff Stuff kit and springs. I’ll get some 12’s with a short rod eye and some tube. Rolling the lowers down isn’t a big deal for what that tuck does. This won’t go down until probably April. I might be back for more questions. Thanks guys!
    Speedytech7[OP] likes this.
  9. Feb 15, 2023 at 10:23 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I think I'd rather have this.
    Gen1FTMFW, Abeyancer, jubei and 2 others like this.
  10. Feb 15, 2023 at 10:25 PM
    Speedytech7
    Just make sure you nip the back of the ruff stuff main eye mount off if you aren't frenching them, or they'll bend your leafs
  11. Feb 15, 2023 at 10:27 PM
    Speedytech7
    I'd much rather have that, or @mjbtaco truck. That other truck is going to haunt my dreams, just knowing it exists is bad enough, but to think someone did that to it is even worse.
    jubei and mechanicjon like this.
  12. Feb 15, 2023 at 10:32 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Don't let Hawaii ruin you
  13. Feb 15, 2023 at 10:33 PM
    Speedytech7
    Can we put up a trade ban with one of our states?
  14. Feb 15, 2023 at 10:33 PM
    Shadowhunter
    Nate
    13’ DCSB MT Sport
    We have a love hate relationship but I’m committed till its second death. It was a 3.4 auto until 309k motor let go and I 3rz swapped it with a 5 speed out of a 02’ with 120k miles. Put the D44 in, put manual hubs and a lunch box locker up front. O and had a little fire up under the dash so I got to swap the wiring harness a second time. Positive wire for the Amp shorted out but didn’t blow the fuse. I ran it from underneath the glove box through the center console and past one little spot on the harness and for whatever reason thats where it went down.
  15. Feb 15, 2023 at 10:34 PM
    Sebz13
    Shane
    Maui Hawaii
    Have you guys considered I post these trucks to trigger Zane ?
    Abeyancer and mechanicjon like this.
  16. Feb 15, 2023 at 10:35 PM
    Speedytech7
    It works, they're just awful machines and the people who built them should be tried for treason
    Gen1FTMFW likes this.
  17. Feb 15, 2023 at 10:35 PM
    Sebz13
    Shane
    Maui Hawaii
    Oh, you think Hawaii is your ally.But you merely adopted the aloha state; I was born in it, moulded by it.I didn't see the light until I was already a man, by then it was nothing to me but STRETCHED BOGGERS!
    Abeyancer likes this.
  18. Feb 15, 2023 at 10:36 PM
    Sebz13
    Shane
    Maui Hawaii
    It’s not practical at all I know.
  19. Feb 15, 2023 at 10:36 PM
    Speedytech7
    It wouldn't be so bad if you guys did it to something worthless like a Ford.
  20. Feb 15, 2023 at 10:36 PM
    JKO1998
    Utah
    Yeaaa
    ruin a ranger or somethin
