  1. Feb 28, 2023 at 12:16 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    ehhh even on 31s they sucked except for hyper miling at 60-70 lol
    Only time I got 22mpg in my truck
  2. Feb 28, 2023 at 12:17 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    You drove it. It is pretty peppy for being on 32s.
  3. Feb 28, 2023 at 12:18 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Yeah I think yours has plenty of get up and go. It's probably 4.10 or 4.30 those are still the most common ratios in 3rd gen runners.
    Wulf likes this.
  4. Feb 28, 2023 at 12:20 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    4.30 if it's a V6 limited with the locker and auto.
  5. Feb 28, 2023 at 12:22 PM
    Digiratus
    Roaming the PNW
    The RedHead
    It's a v6 with a 5 speed. Not a limited and no elocker.
  6. Feb 28, 2023 at 12:23 PM
    Wulf
    rock raisin
  7. Feb 28, 2023 at 12:23 PM
    Wulf
    rock raisin
    I don't think 4runners ever came with 3.91s
  8. Feb 28, 2023 at 12:25 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Also, ToyoDIY says that 4.30s were not an option for this rig.
    :notsure: just going by what that site says.
    Wulf[QUOTED] likes this.
  9. Feb 28, 2023 at 12:25 PM
    Speedytech7
    But could you get it with an N64?
    332706256_219503847314724_60913110880428_4ebc4a77bd900dac7c0e85e1f129c4bef1cbbaf0.jpg
    jubei, 04Pre_Runner and Wulf[QUOTED] like this.
  10. Feb 28, 2023 at 12:26 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    No elocker will get you 4.10, and I think only 4 cylinder manuals got the best gear ratio?
    Even though you've got a manual, I'd still wager you've got 4.10.
  11. Feb 28, 2023 at 12:26 PM
    Speedytech7
    I didn't take it up to highway speed, but what was cruising RPM at 60 or 70?
  12. Feb 28, 2023 at 12:26 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    4.30s were only on auto V6 with a locker.
    m3bassman likes this.
  13. Feb 28, 2023 at 12:27 PM
    Speedytech7
    4cyl autos had the option for 4.56 which is dope for me
    Kwikvette[QUOTED] likes this.
  14. Feb 28, 2023 at 12:28 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I know 4 cylinder got the best setup, wasn't sure if it was manual or auto.
  15. Feb 28, 2023 at 12:30 PM
    Wulf
    rock raisin
    No
  16. Feb 28, 2023 at 12:33 PM
    eon_blue
    Azusa, CA
  17. Feb 28, 2023 at 12:34 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  18. Feb 28, 2023 at 12:35 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  19. Feb 28, 2023 at 12:36 PM
    Digiratus
    Roaming the PNW
    The RedHead
    This is not intended to be confusing, more of an indicator of how I think about it. At 70 mph indicated by the speedo, RPM was ~2700. The GPS says actual speed was 73-74 mph. Likely cause is the bigger tires.
    The tire size calculator says there is a 3.4% difference in size between a 265/70r16 and a 265/75r16.
  20. Feb 28, 2023 at 12:38 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Tarte Tatin, not a fan.
    Way too sweet for me but here it is -
    CS_AR likes this.
