  1. Mar 1, 2023 at 11:49 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    Snews are coming down here, snuck in a quick walk with Molly before it gets too cold
  2. Mar 1, 2023 at 11:49 AM
    Wulf
    rock raisin
    hook up a gerbil feeder to the diff breather so it auto fills :luvya:
    Kwikvette and eon_blue[QUOTED] like this.
  3. Mar 1, 2023 at 11:51 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Once I get home, just got out of class and I'm exhausted
  4. Mar 1, 2023 at 11:52 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    If it leaks, it's got oil :burp:
    eon_blue[QUOTED] likes this.
  5. Mar 1, 2023 at 11:53 AM
    eon_blue
    Azusa, CA
    until it doesn't and I get a locked up differential out in the middle of nowhere lol
    I hope I can fix the throttle lag before we go or I might be chugging up the mountain pretty slowly, might have to bite the bullet and buy a new TPS at the local dealer for 150% mark up
    Kwikvette[QUOTED] likes this.
  6. Mar 1, 2023 at 11:54 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    @eon_blue
    Hey Ryan, what size fuel tank does your runner have? Is it 15.4 gal or 18.5 gal?
  7. Mar 1, 2023 at 11:55 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Bold to assume they'll have it in stock before this weekend:luvya:
    Wulf likes this.
  8. Mar 1, 2023 at 11:56 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Are you buying a 4runner?
  9. Mar 1, 2023 at 11:56 AM
    eon_blue
    Azusa, CA
    did they come with a 15 gallon tank? I thought they'd have the same 18.5 as the 6 lug Tacomas
    my gas gauge is kind of wonky which I hear is really common on these early 3rd gens. It will start going down super quick then rise, go down, rise, etc etc.
    I've filled up right above the E line with 13.5 gallons so maybe it is only 15.4...I'll have to dig and see
  10. Mar 1, 2023 at 11:58 AM
    01x4
    01x4 I know what I'm doing?
    Coast of Southeastern VA
    That's crazy. Understandable, but crazy. Might make me move on from this one, we'll see
  11. Mar 1, 2023 at 12:00 PM
    eon_blue
    Azusa, CA
    He just picked up a 3.4l 5spd manual one too, I forget the year I think a little newer than mine.
  12. Mar 1, 2023 at 12:01 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    That makes sense, yeah my 4r was also 18.5. But filling up I can only get a max of about 15.
  13. Mar 1, 2023 at 12:02 PM
    eon_blue
    Azusa, CA
    yeah that tracks because the light is supposed to come on with 2.5 - 3 gallons left, I haven't gotten it to the light yet on the T4R so I suspect I do have the 18.5
  14. Mar 1, 2023 at 12:02 PM
    Digiratus
    Roaming the PNW
    The RedHead
    My owners manual says mine is a 15.4, but when I look at places like edmunds.com they say it is 18.5.
    I first noticed something odd on the first leg of the drive from Boise. To Penlelton Or is 220 miles. The dash gauge was down to the 1/4 tank mark and I could only put in 10.4 gal.
  15. Mar 1, 2023 at 12:03 PM
    eon_blue
    Azusa, CA
    Yeah there is a very active 3rd gen T4R Facebook page that I read through, way more active than the 4runner forum on here. They talk a lot about the inaccurate gas gauges these have.
  16. Mar 1, 2023 at 12:03 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    You can clean the level sensors if you ever decide to remove the pump
  17. Mar 1, 2023 at 12:04 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Already did.
    What year was yours?
  18. Mar 1, 2023 at 12:04 PM
    01x4
    29 gallon aux tank for 3rd gen Runners from LRA will fix ya
    Wulf likes this.
  19. Mar 1, 2023 at 12:06 PM
    Digiratus
    Roaming the PNW
    The RedHead
    It sems odd to me but thought that maybe ones newer than mine might have got a larger tank. :notsure:
  20. Mar 1, 2023 at 12:06 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    1998
    V6 limited 4x4 with rear locker which is mainly why I knew about the gear ratios yesterday
