  1. Mar 1, 2023 at 12:07 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    It's for that saggy look, right?
    01x4[QUOTED] likes this.
  2. Mar 1, 2023 at 12:07 PM
    eon_blue
    Azusa, CA
  3. Mar 1, 2023 at 12:09 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    F150 tank swap so you don't hit your drive shaft
  4. Mar 1, 2023 at 12:10 PM
    Digiratus
    Roaming the PNW
    The RedHead
    So your thinking that maybe it just wasn't reading accurately and it had way more fuel left in it than was indicated?
    Not sure why the owners manual say 15.4 tho.
  5. Mar 1, 2023 at 12:12 PM
    eon_blue
    Azusa, CA
    I just ran my VIN through partsouq.com, found the fuel tank part number 770013D300 which on other sites is listed as an 18.5 gallon tank. Same tank the 1995.5 - 2000 Tacomas use.
    I'll see what the owner's manual says, maybe it was an error in printing.
    Digiratus[QUOTED] likes this.
  6. Mar 1, 2023 at 12:13 PM
    Digiratus
    Roaming the PNW
    The RedHead
    So after that conversation, I took a look at what the door jam tag said. Mine has a diff code of A03A, which is 4.10s. It is supposed to be the same as B03A which my Tacoma has.
    Kwikvette[QUOTED] likes this.
  7. Mar 1, 2023 at 12:15 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Yep, non-locker with V6 = 4.10
    I wish I had my window sticker still but I gave it away with the 4R....though I'm pretty sure that said 18.5 gallons as well on it. Can't remember the manual though, I never thumbed through it.
    But filling up it was definitely 18.5 cause I'd fill up 15 max when I intentionally hit the low light. When that light turns on, you're on the last 3 gallons or so.
  8. Mar 1, 2023 at 12:17 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Did you get an owners manual with it. Be curious what it says about tank size.
  9. Mar 1, 2023 at 12:22 PM
    eon_blue
    Azusa, CA
    Yep, just checked...it says 18.5 gallons, or 15.4 Imperial gallons haha
  10. Mar 1, 2023 at 12:23 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    eon_blue likes this.
  11. Mar 1, 2023 at 12:24 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, that is what I just did. Imp gallons are not US gallons. o_O
    m3bassman, Wulf and eon_blue[QUOTED] like this.
  12. Mar 1, 2023 at 12:29 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    :rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl:
    Wulf and Digiratus[QUOTED] like this.
  13. Mar 1, 2023 at 12:49 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @Wulf
    Did I give you one extra brake line or two?
  14. Mar 1, 2023 at 12:52 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I ask because if I gave you one, I'll have two more in my shed, garage, and/or storage out of town.
    Can send these other guys one if they need.
  15. Mar 1, 2023 at 12:54 PM
    eon_blue
    Azusa, CA
    bring one camping in case you overflex the LC and bust the line :evil:
  16. Mar 1, 2023 at 12:55 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Different lines.
    The extra brake lines I had were; 1 extended for a Tacoma rear, and 2 extended for a 4Runner rear.
    If there's snow, we're going to be extra cautious about where rocks are so we don't go sliding off anything...especially you being on stock suspension.
    eon_blue[QUOTED] likes this.
  17. Mar 1, 2023 at 12:56 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I will have ATF with me though.
  18. Mar 1, 2023 at 12:57 PM
    eon_blue
    Azusa, CA
    For sure, it could be real icy too because it will warm up some now that the storm is clearing out but still freeze overnight up there.
  19. Mar 1, 2023 at 12:59 PM
    Wulf
    rock raisin
    Pretty sure it was just one red one :)
  20. Mar 1, 2023 at 12:59 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    There's a spec out there I'm sure of what temperature it is supposed to output, just like the is for AC. How else would you quantity a broken heater or AC. My guess is the output is not below the threshold. Or he is feeding you bs. Put a thermometer in your weak vent and see what temp it's registering, Google says 115 is the normal output to expect.
    Damn over 21mpg!? Not bad at all with all the hills.
    :rofl: well there's your problem.
