  1. Mar 2, 2023 at 2:13 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Worse, Taiwan :luvya:
    Abeyancer and Sperrunner[QUOTED] like this.
  2. Mar 2, 2023 at 2:14 PM
    ToyotaDriver
    ToyotaDriver Well-Known Member
    Idaho
    ‘04 V6 5 Speed SR5 TRD downward spiraling project, ‘15 V6 6speed TRD daily
    The 1st Gen: All pro 3” lift (650 lbs coils, expedition rears with bilstiens),Timbren rear bumpstops, ubolt flip, diff drop, carrier bearing drop, 33’s on beadlocks ,ARB Bumper, winch, hand throttle, ARE canopy, roof bars, poly bushings all around minus the body mounts. The 2nd Gen: Leveling kit, roll up tonneau cover. 265/75/16’s
  3. Mar 2, 2023 at 2:15 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Mfgs buying parts for their stuff like
    Kwikvette[QUOTED] and Abeyancer like this.
  4. Mar 2, 2023 at 2:16 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    ToyotaDriver[QUOTED] likes this.
  5. Mar 2, 2023 at 2:16 PM
    Running Board Man
    Running Board Man Well-Known Member
    Get this
    Customer of mine had his wheel bearing replaced by a shop on his sequoia
    They didn't put the dust cap on the front of it they pressed it in backwards, and didn't tighten the nut on the back (2wd), and broke the snap ring
    04Pre_Runner[QUOTED] likes this.
  6. Mar 2, 2023 at 2:23 PM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    You're fucking telling me bud. The heat exchangers we use are from a company based out of Austria. They had an issue sourcing the 120V version and were dealing with a "local" company in Austria to supply new ones.
    When I call complaining, come to find out the only thing made in Austria is the 420mm fan itself, the motor is somewhere in Asia that our American based tech support people have no contact with and no engineering data on the motor at all
  7. Mar 2, 2023 at 3:02 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Ah shit I hope this isn't blood
  8. Mar 2, 2023 at 3:04 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Even worse, gear oil.
  9. Mar 2, 2023 at 3:06 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    time for a taste test
    Sperrunner likes this.
  10. Mar 2, 2023 at 3:08 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    o_O
  11. Mar 2, 2023 at 3:11 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Wulf[QUOTED] likes this.
  12. Mar 2, 2023 at 3:17 PM
    Wulf
    rock raisin
    I have a drinking water tap with 5 micron filter rated for 20000 gallons. I don't have any kind of gauge to indicate how much I use it. What say the LT: How often should I change that? Every couple years, just because?
    Assuming I drank 1 gallon a day it would "last" for like 50 years lol. I doubt the filter media would actually hold up over that timespan though
  13. Mar 2, 2023 at 3:21 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Do you have an LC meter?
  14. Mar 2, 2023 at 3:26 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Think it's cracked? Should I cancel the order?
  15. Mar 2, 2023 at 3:26 PM
    Abeyancer
    Jimmie
    PNW
    For checking impedence correct? I believe my fluke 117 has that feature even though I haven't used it
  16. Mar 2, 2023 at 3:44 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
  17. Mar 2, 2023 at 3:45 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Every 6 months
  18. Mar 2, 2023 at 3:54 PM
    Wulf
    rock raisin
    I may have missed several changes in that case
    Abeyancer likes this.
  19. Mar 2, 2023 at 3:56 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    That tap, does it run all of your water IE water used for dishes, hand washing, etc?
    If so I'd do it every 6 months?
    If not, once a year?
  20. Mar 2, 2023 at 3:56 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Thats what i do in a commercial setup. You will be fine once a year. Just depends on usage and how dirty your city water is.
