  1. Mar 3, 2023 at 8:23 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Well perfect then
    treyus30[QUOTED] likes this.
  2. Mar 3, 2023 at 8:37 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    Who's gonna be the first to put a procharger on a 3.4l?
  3. Mar 3, 2023 at 8:37 AM
    Wulf
    rock raisin
    Check Glassdoor for salary range ideas
  4. Mar 3, 2023 at 8:38 AM
    Wulf
    rock raisin
    Nice rig
    Taco critter likes this.
  5. Mar 3, 2023 at 8:45 AM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    If they weren't so expensive...
    Wulf[QUOTED] likes this.
  6. Mar 3, 2023 at 9:06 AM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    @treyus30 so I'm fairly certain blue is the common, resistance between black and blue was 12.6ohms resistance between brown and blue is 13.0ohms and for poops and giggles the resistance between black and brown is 23.1ohms. Using that watt reading device the power factor is .98 after start up. The watt reader gave amps at ~3.875 and my rms fluke meter says 3.9A
    treyus30 likes this.
  7. Mar 3, 2023 at 9:15 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    What is it?
  8. Mar 3, 2023 at 9:15 AM
    Wulf
    rock raisin
    same lol
    3pct is cost of living adjustment and 5pct is "raise" hahahaha
    0xDEADBEEF[QUOTED] likes this.
  9. Mar 3, 2023 at 9:21 AM
    Wulf
    rock raisin
    belt driven centrifugal super charger
  10. Mar 3, 2023 at 9:28 AM
    Digiratus
    Roaming the PNW
    The RedHead
    I've never heard of it but I stopped looking once I got mine. I didn't realize anyone besides magnuson was making a supercharger for the 3.4L.
  11. Mar 3, 2023 at 9:31 AM
    eon_blue
    Azusa, CA
    Procharger makes one for the 3.4l? I thought they only did for the 3rd gens
    Magnuson has that new one coming out this year for the 3.4l, basically a more efficient version of the one that's been out for years now. Thats the only other option I've been aware of
  12. Mar 3, 2023 at 9:31 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Only ProCharger worth actually using was specifically for the SN95 Bullitt due to the better flowing intake manifold compared to the Cobra of that year.
    Great power, better handling, and less money than a Termi.
  13. Mar 3, 2023 at 9:34 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    They've been out for many decades but they're not as popular because they're limited with their power increase.
    You're restricted by the intake manifold on a stock vehicle for starters, plus their small size really makes them more of a toy than anything.
  14. Mar 3, 2023 at 9:34 AM
    Wulf
    rock raisin
    Supercharged Buick 3800 swap kit when
  15. Mar 3, 2023 at 9:38 AM
    eon_blue
    Azusa, CA
    I went through this like 6 months ago, same thing...thought I was screwed and either needed to take it apart and replace the port or buy a new phone. Took it into a local repair shop and the dude shines a light in the charging port, whipped out a pair of tweezers and scraped out a shit ton of dirt and pocket lint. Blast of canned air and it charges like new ever since
    I use a little plastic toothpick now once in awhile to clean it out
    Wulf likes this.
  16. Mar 3, 2023 at 9:39 AM
    Digiratus
    Roaming the PNW
    The RedHead
    I've seen that. I am not convinced yet that it will actually improve that much over the current one. Time will tell tho. I am sure it will be more expensive.
  17. Mar 3, 2023 at 9:40 AM
    Digiratus
    Roaming the PNW
    The RedHead
    I did a quick search for 'procharger for 3.4l' but only magnuson shit came up.
  18. Mar 3, 2023 at 9:50 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I'd never recommend one for any vehicle really.
    I had a Bullitt with one already installed, and one without. So I was able to compare the two.
    The Procharger being small and belt driven spools up so quick, but runs out of steam at high rpms unlike a turbo where exhaust gasses continue to build more boost.
    Used to run it in autocross and it was nice coming out the apex where I'd leave people behind except Miata's....then I got a Miata myself :laughing:
  19. Mar 3, 2023 at 9:54 AM
    treyus30
    Trey
    Mesa / AJ, AZ
    Is that power factor with the cap on it? And are you connecting anything external to the brown wire, or just the cap? How does the power factor change without the cap?
  20. Mar 3, 2023 at 9:56 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Fucking heavy cream is expensive
    Bought some so I can make two Chocolate Ganache Tarts; thinking I'll bring you and Sergio a slice each @eon_blue
    eon_blue likes this.
