  1. Mar 6, 2023 at 8:35 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I'm still in Glenwood
  2. Mar 6, 2023 at 9:13 AM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    I didnt think it made any sense either lol. I'm using a 500va 480 to 120 step down transformer, the fan is the only load on it. I'm doing what I learned at the panel shop and grounding the N side of the transformer directly to the enclosure back pan. I didn't mess with those connections at all, just swapped where L and N attach to the fan motor.
    I even swapped back in the 22mf cap with the leads switched. It died (do I definitely need the 40mf) but it ran for 38min before shutting off where previously it ran for only 20min
  3. Mar 6, 2023 at 9:18 AM
    Abeyancer
    Jimmie
    PNW
    jubei likes this.
  4. Mar 6, 2023 at 9:38 AM
    eon_blue
    Azusa, CA
    Another atmospheric river storm coming through us next week, awesome
  5. Mar 6, 2023 at 9:39 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Eh you guys need it anyway
    Kwikvette and eon_blue[QUOTED] like this.
  6. Mar 6, 2023 at 9:41 AM
    eon_blue
    Azusa, CA
    Yeah it's nice seeing all the green for a change. Here's hoping this summer doesn't suck like usual and it just makes for bigger fires
    Abeyancer likes this.
  7. Mar 6, 2023 at 9:44 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Damn. More tornadoes. At least it makes the water crossings deeper.
    eon_blue[QUOTED] likes this.
  8. Mar 6, 2023 at 9:45 AM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Ummmmm... are you sure that's running at 120V?
    I'm thinking that's only a 2:1 step-down transformer, unless the wiring diagram isn't representing everything inside
    Also I can't see, are 3-4 bridged on the high side, and 5-4 and 3-2 on the low side?
    And where is 1 going?
  9. Mar 6, 2023 at 9:53 AM
    Abeyancer
    Jimmie
    PNW
    I'm sure lol it's a "try to fit all applications" transformer, primary can be 240 or 480. Here's a zoomed in shot to show the jumpers.... plus I checked it with my meter, 125V no load 119V when the fan is runningScreenshot_20230306_095126.jpg
  10. Mar 6, 2023 at 9:55 AM
    treyus30
    Trey
    Mesa / AJ, AZ
    Ok, I'm thinking the HV winding is 2x the turns and you can bridge to get 4x, and the LV is x1 or x2, respectively...so that's fine. The fuse threw me off a little too.
    Abeyancer[QUOTED] likes this.
  11. Mar 6, 2023 at 9:57 AM
    Abeyancer
    Jimmie
    PNW
    Cheap trick I learned at the panel shop, fuse for the secondary bolted directly to the transformer. Boss man prefers breakers. But there's literally zero room for another breaker lol
  12. Mar 6, 2023 at 9:59 AM
    treyus30
    Trey
    Mesa / AJ, AZ
    What's the voltage rating on the cap they gave you/blew up?
  13. Mar 6, 2023 at 10:10 AM
    Abeyancer
    Jimmie
    PNW
    450V
    Which was weird to me because (at least state side) I've only ever seen 370v or 440v. I didn't have a 40mf 440V cap but a 40mf 370V, so that's what I'm using:anonymous:
    Highest voltage I saw in all my testing last week was 160V
    treyus30[QUOTED] likes this.
  14. Mar 6, 2023 at 10:13 AM
    treyus30
    Trey
    Mesa / AJ, AZ
    Oh also... if those impedances we got before are accurate, you're way overloading that transformer (500VA vs ~1200W). That could definitely be your issue.
    Idk how that wouldn't be blowing your 4A fuse though....
  15. Mar 6, 2023 at 10:19 AM
    Abeyancer
    Jimmie
    PNW
    Yea I know I'm using 92% and I shouldn't use more than 80% of a transformers capacity but I physically can not fit a 750va one in this enclosure.
    I'm pulling a classic dick OEM move by using something that will work but not last for as long as it could. Thankfully these units are used sparingly, and when they are in service it's inconsistent... customer only cuts for less than an hour before needing to shut the unit down and reposition everything.
  16. Mar 6, 2023 at 10:51 AM
    Abeyancer
    Jimmie
    PNW
    Too much electrical talk for ya?:laughing:
    04Pre_Runner and Taco critter like this.
  17. Mar 6, 2023 at 10:53 AM
    Speedytech7
    I'm just over here strapping fans to my transformers so I can pull 100% duty cycle at 99.999999999999999999999999999~% load.
    treyus30 and Abeyancer[QUOTED] like this.
  18. Mar 6, 2023 at 10:57 AM
    Abeyancer
    Jimmie
    PNW
    :rofl::rofl:
    Listen if it's capable of a certain amperage I should be allowed to use ALL the amperage :anonymous:
    treyus30 likes this.
  19. Mar 6, 2023 at 11:13 AM
    treyus30
    Trey
    Mesa / AJ, AZ
    Submersing in oil and pumping through a heatsink is the way to go haha
    THEN you can add fans
    Abeyancer and Taco critter like this.
  20. Mar 6, 2023 at 11:15 AM
    Abeyancer
    Jimmie
    PNW
    She's a bad girl, breakin ALL the rules
