  1. Mar 6, 2023 at 5:43 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Im not a fan, I didn't enjoy driving the SRT10 ram my uncle had either, sounding just terrible and handled like hot trash, and it only had 8k mi on it so nothing should have been worn out. The engine has some power but in this age, it doesn't hold up anymore.
  2. Mar 6, 2023 at 5:44 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    Yeah that will be interesting. It makes sense they would feel the same for now though. When I had a shop do it, it never felt right. Fun fact, I'm pretty sure the clutch fluid is original :anonymous:
  3. Mar 6, 2023 at 5:46 PM
    Speedytech7
    Yeah I remember driving it before you fixed it yourself and it was really bad. Actually this was the first time I drove your truck since then and it felt a lot better.
  4. Mar 6, 2023 at 5:48 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    That old one was still used in the SRT10 Ram pick up; it uses a TR6060 but yeah the input is heavy AF.
    m3bassman[QUOTED] likes this.
  5. Mar 6, 2023 at 5:51 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Anyone ever tried tapping a barb fitting into a plastic radiator for an auxiliary return?
  6. Mar 6, 2023 at 5:53 PM
    Wulf
    rock raisin
    Not quite
    I did break a plastic barb for the degas bottle off a radiator and water welded a pipe barb on
  7. Mar 6, 2023 at 5:54 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Feels like it would be easier to have a tee on the radiator hose.
    Wulf likes this.
  8. Mar 6, 2023 at 5:55 PM
    Wulf
    rock raisin
    Could add in a ball valve too. For maintenance:luvya:
  9. Mar 6, 2023 at 5:57 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    I do have one capped off from a long time ago actually, but I worry about how that disrupts flow...without seeing it it's impossible to tell. Also I actually need to run two (each turbo) so I feel like just tapping the top of the rad will be cleaner
    Right now it sources and returns via the heater hoses
  10. Mar 6, 2023 at 5:57 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Last thing you need to do is add more shit on your TO-DO list :luvya:
    Wulf[QUOTED] likes this.
  11. Mar 6, 2023 at 5:58 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    I replace my rad more than I replace my fluid lol
  12. Mar 6, 2023 at 5:59 PM
    0xDEADBEEF
    I suspect tapping a plastic radiator could lead to cracking. I think the plastic is usually glass reinforced though.
    Surely someone else has faced this problem before?
  13. Mar 6, 2023 at 5:59 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Guys tap and add a fitting to their end tank on their radiator when the nipple for the coolant bypass breaks off - Radiator Nipple Fix Walk-Through... | IH8MUD Forum
    They've posted back having been successful for many miles to come.
    I said fuck that.
    treyus30[QUOTED] likes this.
  14. Mar 6, 2023 at 6:00 PM
    0xDEADBEEF
    Need an entire radiator fluid manifold.
  15. Mar 6, 2023 at 6:01 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    You'd think
    I spent at least an hour searching for some kind of adapter that could work on the return hose or between the pressure cap
  16. Mar 6, 2023 at 6:05 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Helpful and reassuring, thanks. I'd hopefully be able to do something without jb weld but I guess if worse comes to worst...
    Kwikvette[QUOTED] likes this.
  17. Mar 6, 2023 at 6:06 PM
    Wulf
    rock raisin
    Hey the list got a little smaller today
    I erased a few things I gave up on entirely:luvya:
  18. Mar 6, 2023 at 6:07 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Like the dimensions of the bracket you wanted me to cut for you? :luvya:
  19. Mar 6, 2023 at 6:11 PM
    Wulf
    rock raisin
    It's still in the back of my mind :luvya:
    Work has been in crisis so i haven't done any wrenching...or lifting...or other fun stuff for a while now
  20. Mar 6, 2023 at 6:14 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    Step one of the rear locker mod complete. I put the switch in.
