  1. Mar 9, 2023 at 12:23 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    freedumb
  2. Mar 9, 2023 at 12:24 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Every injector will have an offset value at different voltages. This helps the ecu make up the difference if voltage changes and make up the difference for partial open and partial close volume for a given pulse width. Everything with fuel injectors will need the offsets (dead times) for them input in the ECU, GM goes way overboard with them actually and makes a voltage and pressure differential chart.
    https://support.haltech.com/portal/en/kb/articles/injector-dead-time
    jubei likes this.
  3. Mar 9, 2023 at 12:26 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    The biggest problem with buying old injectors or ones that are new and sitting on the shelf for too long is the blades can rust. To avoid that a preservative oil should be used that will prevent rusting. I've known guys who got injectors cleaned and let them sit for a couple of months and found the blades had rusted.
  4. Mar 9, 2023 at 12:36 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Combination of Pate Brisee, Pate Choux, (decorated with Creme Diplomat), Caramel, and Cream Puffs for a Saint Honore -
    Not sure how people like this stuff :notsure:
    CS_AR likes this.
  5. Mar 9, 2023 at 12:37 PM
    Speedytech7
    Did you leave it in the garage or something, what's with the moist spider webs?
  6. Mar 9, 2023 at 12:39 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    It's "intentional" as it's sugar, water, and corn syrup to create the caramel.
    You use some of it to "glue" the cream puffs together, and cook it again to create a sort of bird's nest or whatever as some abstract shit IDK.
    You can tell the sugar is cooked perfectly cause when it's browning, that means it's cooked too far and doesn't solidify well. That and it quickly crystalizes and ruins the batch.
  7. Mar 9, 2023 at 12:44 PM
    Speedytech7
    I uh, well... yeah that might work... could just do what Haltech says to approximate it though haha. The injectors I'm buying come with a table of deadtimes
  8. Mar 9, 2023 at 12:59 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  9. Mar 9, 2023 at 1:05 PM
    Wulf
    rock raisin
    I'm sure it tastes good for a few bites but it's looking like bubblegut city if I had any more than that :p
    CS_AR and Kwikvette[QUOTED] like this.
  10. Mar 9, 2023 at 1:15 PM
    eon_blue
    Azusa, CA
    Bubble butt city amirite
  11. Mar 9, 2023 at 1:16 PM
    Wulf
    rock raisin
    Brazil?
  12. Mar 9, 2023 at 1:16 PM
    eon_blue
    Azusa, CA
    Wulf[QUOTED] likes this.
  13. Mar 9, 2023 at 1:20 PM
    Wulf
    rock raisin
  14. Mar 9, 2023 at 1:20 PM
    Wulf
    rock raisin
  15. Mar 9, 2023 at 1:21 PM
    Wulf
    rock raisin
  16. Mar 9, 2023 at 1:22 PM
    Wulf
    rock raisin
  17. Mar 9, 2023 at 1:23 PM
    eon_blue
    Azusa, CA
  18. Mar 9, 2023 at 1:45 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Didn’t try
  19. Mar 9, 2023 at 1:45 PM
    Wulf
    rock raisin
    do u need the rest of the playlist? :D
    eon_blue[QUOTED] likes this.
  20. Mar 9, 2023 at 1:48 PM
    Speedytech7
