  1. Mar 12, 2023 at 9:13 PM
    eon_blue
    Azusa, CA
    All of the above? Although I admit I've watched some clips of the game recently and this episode pretty much follows the firefly hospital stuff to the T so you probably already know what to expect, but it was done well....fuck now we probably gotta wait 2+ years for next season, knowing HBO
    Kwikvette[QUOTED] likes this.
  2. Mar 12, 2023 at 9:14 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @Wulf I'll be on Discord; they've got one for this game to help look for players and stuff
  3. Mar 12, 2023 at 9:40 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    late 80s.
  4. Mar 12, 2023 at 10:02 PM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    Wait just the pins being loose can cause leaking? Like from where? Just through that hole they mount in?
    Running Board Man likes this.
  5. Mar 12, 2023 at 10:03 PM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    Just finished up all my weekend chores and shit, laptop isn't wanted to connect to my router :( I'll see if Mobile Hotspot works
  6. Mar 12, 2023 at 10:04 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Yeah, holes aren't covered by the boot. So it can leak out through them and mine clearly has. It certainly has other leaks too but that's one of the main ones. If tour doesn't have a good turret I'm just going to turn a couple of bolts on the lathe so they have smooth ends and tap the hole so that they can thread into that and then the smooth ends can just be the pins
  7. Mar 12, 2023 at 10:06 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    No worries we just got done!
    I'll let @Wulf chime in her opinion on the game but I really like it; for $3 it offers way more fun than you'd expect.
    Abeyancer[QUOTED] likes this.
  8. Mar 12, 2023 at 10:25 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
  9. Mar 12, 2023 at 11:51 PM
    Running Board Man
    Running Board Man Well-Known Member
    Gawd I wish I had a lathe
    04Pre_Runner likes this.
  10. Mar 12, 2023 at 11:54 PM
    Running Board Man
    I was thinking about this when shifting
    Like shnchros have to make the input shaft speed up when downshifting or slow down when upsetting... if it were done any faster like yeah you have to move your hand less but that's more force you're putting on the component
  11. Mar 13, 2023 at 12:38 AM
    Logans2001
    Logans2001 What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    You guys ever cut these off? Do we really need them? They’re just getting in the way when I turn in reverse or compress the suspension on a turn. My caster is around 4.0
  12. Mar 13, 2023 at 12:45 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    This. ^^
    When they get evening looser the wheel will twist at an angle snapping them off.
  13. Mar 13, 2023 at 3:43 AM
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    Helping my single mother co worked out. Her 04 dbl cab 4wd 3.4 was running rough felt like it was missing, went and pulled a code in the work parking tonight cyl 6 misfire. P0306. Told her maybe coil, injector, or plug but more than likely injector.
    what you guys think
    Kwikvette likes this.
  14. Mar 13, 2023 at 5:33 AM
    Ozark_RegCab
    Ozark_RegCab Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    I found it hard to believe giraffes could survive the winters in SLC.
  15. Mar 13, 2023 at 5:46 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Giraffes walking around peacefully is harder to believe than a world infested with zombies? :luvya:
    Ozark_RegCab[QUOTED] likes this.
  16. Mar 13, 2023 at 5:51 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Wow, some 3rd Genners are really out there.
    Dude complaining about gas mileage after putting on a GFC camper, larger tires, and a roof rack :facepalm:
  17. Mar 13, 2023 at 6:23 AM
    Speedytech7
    You can unbolt that bracket and remove it entirely and yeah I moved the washer reservoir years ago
  18. Mar 13, 2023 at 6:24 AM
    Sebz13
    Shane
    Maui Hawaii
    Its cheaper to just sniff glue than spend 50g's on a trd pro with a bunch of dumb stuff bolted to it.
    Ozark_RegCab likes this.
  19. Mar 13, 2023 at 6:24 AM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    The 98-00 version of those brackets commonly break. Mine were broken and didn't seem to cause an issue. I've since swapped to a 4Runner bumper that doesn't line up with the outside brackets anyway. You'll probably be fine.
  20. Mar 13, 2023 at 6:41 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
