  1. Mar 13, 2023 at 10:28 AM
    Wulf
    rock raisin
    Rust-Oleum rebuild, call me the Rembrandt of rattle can
  2. Mar 13, 2023 at 10:28 AM
    eon_blue
    Azusa, CA
    yeah hopefully I kept all the hardware together when I took them off, I'll have to check. Was a few/5 years ago
    treyus30[QUOTED] likes this.
  3. Mar 13, 2023 at 10:28 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I don't recall the part in red, is that a bushing through the frame. The rear diff cushion mount has a stud already.
  4. Mar 13, 2023 at 10:30 AM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    I assumed it was the nut to attach the 'rear diff cushion mount' to the frame. It does say "nut" on it when you search it
    The blue parts are more concerning. I believe they're rubber pieces that absorb deflection from the mounting bolts..
  5. Mar 13, 2023 at 10:40 AM
    Speedytech7
    Oh shit watch out @Sebz13 you got competition in Cali now...
    318908981_10225184890442219_534816975939_cfea25d59077860c1802da1d16b8357bb9aff88f.jpg
    Sebz13 and Ozark_RegCab like this.
  6. Mar 13, 2023 at 10:40 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Its a 4Runner site.. I mean.... Definitely not a competitor.
    Ozark_RegCab likes this.
  7. Mar 13, 2023 at 10:41 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Hawaiians be like "hold my Mai Tai"
  8. Mar 13, 2023 at 10:44 AM
    eon_blue
    Azusa, CA
    I've got a Mai Tai they can hold but will probably result in a trip to the ER afterward
    btw this is where he is 95% of the day since we got Dex lol
    Tour991 and Kwikvette[QUOTED] like this.
  9. Mar 13, 2023 at 10:45 AM
    CS_AR
    I think the EVOs might be a bit quieter than the special edition MTPs that were designed for Discount tire that I bought this time in 2020.
    When referring to highway manners, one reviewed called them a lady on the streets but a freak in the sheets.
    Ozark_RegCab[QUOTED] likes this.
  10. Mar 13, 2023 at 10:46 AM
    Speedytech7
  11. Mar 13, 2023 at 10:47 AM
    Speedytech7
    jubei, treyus30, Wulf and 4 others like this.
  12. Mar 13, 2023 at 10:48 AM
    eon_blue
    Azusa, CA
    omg I'm sending this to my wife pronto, she is obsessed with all things spreadsheets
  13. Mar 13, 2023 at 10:54 AM
    eon_blue
    Azusa, CA
    the only thing prettier than a light blue early 1st gen Tacoma is a light blue Hilux Surf, damn...
    I know they put it on the T4Rs too but have only ever seen a couple of them around
    treyus30, CS_AR and Ozark_RegCab like this.
  14. Mar 13, 2023 at 11:06 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    That is pretty much how most forums get started. Certainly true of Tacoma forums, including TW.
    TacomaTerritory became TTORA which spawned TacomaWorld.
  15. Mar 13, 2023 at 11:08 AM
    eon_blue
    Azusa, CA
    My Toyota forum before this one was Yotatech back in the day, circa 2003/2004...after I bought my '98 Prerunner. It gave me the 4wd itch bad haha. It was very active much like TW is now but not quite this big. Then I guess the owner sold it off and it became laden with advertising and everyone moved elsewhere, probably to TTORA and over here since this one started in 2008?
  16. Mar 13, 2023 at 11:11 AM
    CS_AR
    I'm going get 4 more EVO MTs -- special rebate and other discounts bring the set down to a few dollars of buying 3. So I will have 5 alike now. I had been doing a 5 tire rotation.
  17. Mar 13, 2023 at 11:13 AM
    Ozark_RegCab
    Ozark_RegCab Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    I thought Yotatech was mainly focused on the older 22re and 3.0 Pickups and 4runners. It doesn't seem very active now and the layout is horrible, but there's still a lot of valuable info there.
  18. Mar 13, 2023 at 11:13 AM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    I would get those again but I don't think they come in 255/80/17.
    CS_AR[QUOTED] likes this.
  19. Mar 13, 2023 at 11:15 AM
    eon_blue
    Azusa, CA
    Yeah it was way more active in the early 2000s when 1st gens were popular but so were still the Pickups and older 4runners from the 90s and on.
    It was a lot like TW in that advertising was subtle and not intrusive, looking at it now you can't do anything on that site without ads popping up at you. But that's why people moved on after the owner sold it off. Nothing kills a forum quicker
    Wulf and Ozark_RegCab[QUOTED] like this.
  20. Mar 13, 2023 at 11:16 AM
    CS_AR
    Do you know why I'm staying with 33s? Because most of the people that I out with are on 31s or 32s. I don't want to be one of those leaders that leaves everybody else stuck. I'm usually the one that takes the deep water crossings first.
