  1. Mar 16, 2023 at 6:40 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    happy morning or something :burp:
    0xDEADBEEF and Kwikvette like this.
  2. Mar 16, 2023 at 6:44 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Every morning this hits me.
    01x4, Wulf[QUOTED] and Abeyancer like this.
  3. Mar 16, 2023 at 7:06 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Well this kinda all starts with even more engine theory, some heads and piston designs promote swirling of the air and fuel mixture, sometimes called a swirl chamber. Anyway the better mixed your air and fuel molecules the more uniform the burn and the more you can drive the timing up because the results can be repeated every time reliably. So Denso, Hitachi, Aisin all tried this air assist idea where a separate chamber is drilled into the intake manifold to distribute metered air to the base (pintle) of the special injector for the purposes of a small swirl chamber within the pintle of the injector. At the time, this was a pretty good advacnement but it didn't catch on because it came at a time when traditional injectors were getting pretty damn good at atomizing on their own as a lot went to multi hole designs instead of the single annular discharge hole of the early styles.
    Most toyotas after the 1980s (with the exception of some high performance models) use high impedance (saturated) injectors. It's more common overall actually. Low impedance injectors are more early technology that is over complicated since they use peak and hold drivers that allow higher amperage for opening the injector and then they hold the injector (dwell) at a lower sustained amperage before closing. It requires more hardware and back in the day allowed for more accurate control and higher injection rates, but technology for controlling high impedance has come a long way and now allows even more flow and control.
  4. Mar 16, 2023 at 7:09 AM
    Wulf
    rock raisin
  5. Mar 16, 2023 at 7:18 AM
    Running Board Man
    Running Board Man Well-Known Member
    Is that what that tube was going to the back of the intake manifold from the throttle body
  6. Mar 16, 2023 at 7:21 AM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    Ok it's been a while since I had that truck so couldn't recall where the interference was but I do remember I ran the tie rods "opposite" from the orientation on the Tacoma. @Digiratus just FYI.
    Wulf likes this.
  7. Mar 16, 2023 at 7:24 AM
    Speedytech7
    Yup, and then at the lower intake manifold it splits into two tubes and and there are channels bored front to back through each injector well to distribute the air. Can see the ball bearing they pressed in as caps here along with the balance tube.
  8. Mar 16, 2023 at 7:27 AM
    Wulf
    rock raisin
    wow this is neat lol
  9. Mar 16, 2023 at 7:28 AM
    Speedytech7
    It's a pain
    Wulf[QUOTED] likes this.
  10. Mar 16, 2023 at 7:28 AM
    Speedytech7
  11. Mar 16, 2023 at 7:29 AM
    Wulf
    rock raisin
    Neeeed
    Kwikvette likes this.
  12. Mar 16, 2023 at 8:10 AM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    You're not doing yourself an favors in fighting the stereotypes Mr Yanmar Engineer... in another place on the diagram it says "reray" :laughing:
    BartMaster1234, Blue92 and 0xDEADBEEF like this.
  13. Mar 16, 2023 at 8:38 AM
    Speedytech7
    Anime does this a lot since that's how romanji is translated for them.
  14. Mar 16, 2023 at 9:04 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Wait. This does not sound right.
    Are you saying you put the Tacoma outer TRE marked for the passenger side onto the driver side on the 4R? It seems like that would put the bend in the rod in the wrong place and cause interference.
  15. Mar 16, 2023 at 9:08 AM
    Speedytech7
    Regular road going 4Runner I would just run the 4Runner tie rods and ball joints. I don't think it's going to make any difference being on the road 90% of the time
  16. Mar 16, 2023 at 9:12 AM
    Wulf
    rock raisin
    01x4 likes this.
  17. Mar 16, 2023 at 9:22 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Yeah, I'm beginning to think this way too.
    It's my understanding that the only other difference is the diameter of the tapered end on the oTRe that fits into the LBJ.
  18. Mar 16, 2023 at 9:25 AM
    m3bassman
    Green truck
    Unless I've always had them backwards on the green truck, the bend is towards the LCA. To run them on a 4R the bend needs to face towards the cab. Picture below is green truck.
  19. Mar 16, 2023 at 9:26 AM
    Ozark_RegCab
    Ozark_RegCab Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    So I'm trying to sell the diffs and this guy wants to come open the diff cover before he buys to check for wear. Does this sound reasonable at all? Could you really tell that much just by taking the cover off?
  20. Mar 16, 2023 at 9:28 AM
    Abeyancer
    Jimmie
    PNW
    Huh, interesting tidbit I was unaware of
