  1. Mar 16, 2023 at 1:53 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  2. Mar 16, 2023 at 1:53 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    cray cray
    I just want to weld a little aluminum ffs lol
  3. Mar 16, 2023 at 1:54 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Rent a machine for a day and knock the job out yourself
    Abeyancer likes this.
  4. Mar 16, 2023 at 1:57 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Should see how much a professional aluminum MIG machine (push/pull) setup costs. We had a fairly low spec miller one at my machine shop job that I used sometimes and it was $15k.
    Kwikvette likes this.
  5. Mar 16, 2023 at 2:04 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Hell, the Miller 350P at my last job alone is about $11k and that doesn't include the spoolgun.
    MIG pulse is the shit though.
    I could never get used to the push pull Cobramatic setup we had at my first weld job. I mean I used it well, but I think it's because we were welding cast aluminum and that shit sucks even with preheating it.
  6. Mar 16, 2023 at 2:22 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Almost 0 confidence in that test
    Running Board Man likes this.
  7. Mar 16, 2023 at 2:31 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    So you're saying I'm better off building a crucible and cast system :rain:
  8. Mar 16, 2023 at 2:34 PM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    Valve bucket shims aren’t making it this week. :(
    I could roll the truck out into the driveway and power wash the bay I guess. Clean the cracks and crevices.
    Not going to swap to 4.56 because I can’t afford a rear 4.56 to match my truetrac front. I’d want a Harrop elocked 8.4 or OEM elcoker 8” if I did swap.
  9. Mar 16, 2023 at 2:42 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
  10. Mar 16, 2023 at 2:42 PM
    Wulf
    rock raisin
  11. Mar 16, 2023 at 2:56 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Well, looking for that ground issue.
    Also, cleaned and made sure the connections were all good at the wiper motor since it doesn't work.
    I hear a sort of relay "click" when I turn on the rear wiper but it doesn't move at all; even if I leave it on and try to get it started by hand.
    I'm even pulling the sub and will not be reinstalling it.
  12. Mar 16, 2023 at 3:13 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @Speedytech7 remember the nasty wiring mess I had found in my rig?
    Pulled the sub and found the trailer harness; so I guess I have one and just need to find what wire does what.
    Which is odd cause the schematic I found used a different wire set when I looked on mud.
    Das it mang and Wulf like this.
  13. Mar 16, 2023 at 3:19 PM
    eon_blue
    Azusa, CA
    Sing me a song, you're the piano cat
    Sing me a song right now
    Cause we're all in the mood for a melody
    that goes meow meow, meow meow, meow meow, meowwww
    Abeyancer and 0xDEADBEEF[QUOTED] like this.
  14. Mar 16, 2023 at 3:24 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Fucking street sweeper has already rolled by like 6 times; how fucking clean you need the streets to be?
  15. Mar 16, 2023 at 3:31 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Rolled by a 7th time.
  16. Mar 16, 2023 at 3:33 PM
    Daddo
    Daddo Well-Known Member
    Paul
    2004 Doublecab Tacoma 4wd
    Full Total Chaos Long Travel
    Probably trying to clean up the mess you left in the street :luvya:
  17. Mar 16, 2023 at 3:34 PM
    eon_blue
    Azusa, CA
    that would be an awful job to have for someone with OCD
  18. Mar 16, 2023 at 3:34 PM
    JKO1998
    Utah
    tryna get that power steering fluid off
    Kwikvette[QUOTED] likes this.
  19. Mar 16, 2023 at 3:37 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    And I'd be all cool about it but this is the one time I've yanked all the rear interior trim and going through shit.
    I found a "loose" wire in my bulb socket after going back in there with cleaner but no effects at all and my light is still an issue.
  20. Mar 16, 2023 at 3:46 PM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    thot the same when i was omw to work this morning, there was still a demolished birb on the street after he went over it with the street cleaner. wot do
