What would you rather listen to instead of Cold Play
This poll will close on Jul 20, 2025 at 7:20 AM.
  1. Nails on a chalboard
    6.7%
  2. Bass boosted memes
    60.0%
  3. Rod knock
    53.3%
  4. Political discourse
    13.3%
  5. That one annoying drunk gal at a comedy club
    13.3%
  6. No i really do like Cold Play and I'm not writing this under duress (help Cold Play is in the room)
    6.7%
Multiple votes are allowed.
  1. Apr 9, 2023 at 4:13 PM
    Ozark_RegCab
    Ozark_RegCab Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    They still have vtec yo, tho.
  2. Apr 9, 2023 at 4:15 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    That's a fascinating subject that I'm way too drunk to expand upon. Suffice it to say you can doo cool things with a standalone ECU and VTEC when you have a turbo.
    Wulf and Ozark_RegCab[QUOTED] like this.
  3. Apr 9, 2023 at 4:23 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    @Ozark_RegCab
    All my Nissan love is with pre-Renault models. Over the top engineering that drove the company into bankruptcy. I didn't care if they made any money. I think 1998 was the best year. By 1999 they were starting to feel the pain. There might be a couple of models with some Prince Motor Company ancestry still around. But those are fading fast.
    Ozark_RegCab likes this.
  4. Apr 9, 2023 at 4:24 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @Abeyancer has entered the chat*
    Although, he'd buy that $5k motor when it was broken down to rebuild for a DIY motorbike only to throw it under a tarp on a shelf at work never to be seen again...possibly above or below his truck's uninstalled leaf pack :burp:
    Abeyancer likes this.
  5. Apr 9, 2023 at 4:27 PM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    Hm, yea I had heard about Carlos Ghosn and others running the company into the ground after the 90s. It seems like they're starting to turn things around with their new lineup though.
    CS_AR[QUOTED] likes this.
  6. Apr 9, 2023 at 4:28 PM
    TheloniusDrunk
    TheloniusDrunk Well-Known Member
    99 3.4L M/T 4WD 220k
    I'm running into issues removing the upper plenum from the engine bay. I've removed all the bolts and have it flipped over to access the 3 tubes on the throttle assembly underneath. I've managed to get 2 of the 3 tubes disconnected at one end but the third I can't disconnect from the throttle body assembly (actually two of them feel like they're glued onto the throttle bottle assemble but the other I was able to disconnect from the other end -- see binder clip). The stubborn one is closer to the cockpit and I can't access the clamp on the lower end that feeds into the engine but removing the clamp on the throttle body assembly hasn't made it any easier to detach the hose on that juncture. Any advice here? Picture attached, hose is going to the right of the underside of the throttle body assembly
  7. Apr 9, 2023 at 4:30 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Who the heck asks technical questions here :rofl:
  8. Apr 9, 2023 at 4:32 PM
    Speedytech7
    Grab them with some pliers and twist, they just get stuck after years of not being disturbed
    Wulf likes this.
  9. Apr 9, 2023 at 5:15 PM
    CS_AR
    The management before "Le Cost Cutter" over-engineered everything without regard for whether it would be profitable. They wanted the cars to be fast and technically over the top thinking if they build them the customers will come. Some did but not enough to make money.
    Talk about a wild engine design to cut your teeth on. It used RTV instead of gaskets.
    Ozark_RegCab[QUOTED] likes this.
  10. Apr 9, 2023 at 5:23 PM
    CS_AR
    I liked his management style. He continued to fund the GTR through lean times. It was just unfortunate that he misused company funds for his own personal benefit. When someone starts to think they have become king and starts flying in rarified air, that's when gravity pulls them back to Earth.
    https://youtu.be/yChtop17sd8
  11. Apr 9, 2023 at 5:29 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    I don't think that's the point. The jr drags are like mini top fuel with a single cylinder engine. Make a terrible racket but great learning tools for kids on the strip
  12. Apr 9, 2023 at 5:43 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    So guys, I'm thinking 4x Innovations sliders with DOM+square main and Coastal Offroad high clearance rear plate bumper w/receiver hitch. Any qualms?
  13. Apr 9, 2023 at 5:44 PM
    Speedytech7
    Good parts, for sure. Where's your intercooler gonna go. And in my experience you won't need the DOM
    treyus30[QUOTED] likes this.
  14. Apr 9, 2023 at 5:46 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    I've been beating the fuck out of my HREW 4x innovations sliders for (8??) years and they're still holding up
  15. Apr 9, 2023 at 5:47 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    Stock bumper in front.
    Idk, I watch their compare vid and it seemed convincing enough. Small bend at 6" with the HREW and nearly nothing with the square main + DOM after 12". $95 extra seems worth the peace of mind
  16. Apr 9, 2023 at 5:49 PM
    eon_blue
    Azusa, CA
    What a unit
    CS_AR likes this.
  17. Apr 9, 2023 at 5:51 PM
    Wulf
    rock raisin
    Y'all tryna lose at some Mario kart?
    Tour991[QUOTED] likes this.
  18. Apr 9, 2023 at 5:52 PM
    01x4
    01x4 I know what I'm doing?
    Coast of Southeastern VA
    I'm a fan of 4xI's stuff. Always liked the simplicity of their rear bumper as well. I get wanting the higher clearance and side protection of the Coastal though.
    Kwikvette likes this.
  19. Apr 9, 2023 at 5:53 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I'm doing homework at the moment but don't mind whooping some ass :burp:
    Tour991 likes this.
  20. Apr 9, 2023 at 5:54 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    I'd like the 4xI rear bumper instead but it's basically the same price with no side protection
