  1. Apr 16, 2023 at 10:11 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Wulf, 0xDEADBEEF and eon_blue[QUOTED] like this.
  2. Apr 16, 2023 at 10:24 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    CC446075-3804-4D62-B6FE-FA1E28A55D38.jpg Uhoh
    Wulf and CS_AR like this.
  3. Apr 16, 2023 at 10:47 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Homemade flour tortillas made with lard? :pray:
    0xDEADBEEF[QUOTED] likes this.
  4. Apr 16, 2023 at 10:52 AM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    Digiratus and Wulf like this.
  5. Apr 16, 2023 at 10:57 AM
    0xDEADBEEF
    Naaah, these are the uncooked ones from Costco. 95% of the flavor, 2% of the work :D
    CS_AR, Digiratus[QUOTED] and Wulf like this.
  6. Apr 16, 2023 at 10:57 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    My Long term fuel trim is still -13 lol
    I don't know what this truck wants from me lol. Injectors have been rebuilt. MAF is cleaned/replaced. Exhaust leaks are fixed
  7. Apr 16, 2023 at 10:58 AM
    Wulf
    rock raisin
    sounds pretty good though.
    4wd locked/locked launch? :D
  8. Apr 16, 2023 at 10:59 AM
    Speedytech7
    Do you have the right MAF for the truck?
  9. Apr 16, 2023 at 11:05 AM
    Digiratus
    Roaming the PNW
    The RedHead
    That's the only thing I miss from living in Phoenix. Cannot find anyone in the Seattle metro that sells tortillas made with monteca.
  10. Apr 16, 2023 at 11:06 AM
    Wulf
    rock raisin
    96-98(?) Bullet style MAF are all the same, right?
    I think the one I grabbed was from a junkyard 98 4runner. Not sure the one it replaced was a factory 96 one but I could swap it back in and see if it puts me closer to 0.
    Only other "issue" I have is cold idle is 1200-1500 rpm but it comes down to about 600 when warm. No CEL or pending codes
  11. Apr 16, 2023 at 11:08 AM
    Speedytech7
    I think so, anything you can think of that would be mechanically causing it to over fuel, kinked fuel return line maybe?
    Wulf[QUOTED] likes this.
  12. Apr 16, 2023 at 11:08 AM
    eon_blue
    Azusa, CA
    Spatula?
    Those Costco ones you cook yourself are good
    0xDEADBEEF[QUOTED] and Wulf like this.
  13. Apr 16, 2023 at 11:08 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Can you lock the rear in 2hi? That might be enough.
    It does sound good. No front locker tho.
  14. Apr 16, 2023 at 11:09 AM
    Wulf
    rock raisin
    Possibly, yeah, that would be a good thing to check. Flooded EVAP canister too, maybe?
  15. Apr 16, 2023 at 11:13 AM
    Speedytech7
    Watching Finnegans garage, he's building a jig to hold his turbos so he can make the exhaust manifold. He's dragging this polished turbo around his dirty metal workspace and letting it swing in an engine bay on a hoist. Just for shits I looked up the turbo set he's using from Nelson Racing Engines... the pair of them cost $7300. My man's working with them like they're used subaru turbos haha
    01x4 and Wulf like this.
  16. Apr 16, 2023 at 11:18 AM
    m3bassman
    Green truck
    It's running good. I think it'll take the smaller pulley later. It felt solid once it hooked. I don't think the locker is smart but 4wd will be on the next passed for sure. No weight, stiff springs and mud tires just aren't a good recipe. I think I can get into the 17s next pass.
    01x4 and Wulf[QUOTED] like this.
  17. Apr 16, 2023 at 11:24 AM
    Wulf
    rock raisin
    jubei likes this.
  18. Apr 16, 2023 at 11:27 AM
    Wulf
    rock raisin
    yeahhh that's a good call. I don't think the lil Elocker side gear would be super happy about it. But with any luck it will hold on and break in the middle of nowhere instead of at the track :p
    m3bassman[QUOTED] likes this.
  19. Apr 16, 2023 at 11:34 AM
    m3bassman
    Green truck
    Idk if it would make it handle goofy on the big end with it locked. I think 4wd will be ok, I'll just bang it into 2wd after I get in 2nd gear.
    Wulf likes this.
  20. Apr 16, 2023 at 11:42 AM
    Wulf
    rock raisin
    fixing all the little things that have pissed me off about this truck that for some reason i decided i could ignore for years at a time. Makes it a lot less shitty to drive though lol
    Got the sliding window latch done and I'm ready to fight the door cranks next
    Edit: $20 of ebay junk and 15 minutes of my life to fix the things that have pissed me off for years lmao.
    Digiratus likes this.
