  1. Apr 21, 2023 at 9:03 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Low standards huh?
    No 3 phase :luvya:
    Abeyancer likes this.
  2. Apr 21, 2023 at 9:07 AM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    Speaking kinda on the same subject... to fix my steering rack that's way outta whack, is it easier for me to pull the steering wheel rotate it and put it back on. Or should pull the rack again, move the rag joint a couple splines and reinstall?
  3. Apr 21, 2023 at 9:09 AM
    Abeyancer
    Jimmie
    PNW
    Holy shit man, quoting out the work to get 3ph installed in a commercial building with only 240 single is soooooo damn expensive :pout:
    Kwikvette[QUOTED] likes this.
  4. Apr 21, 2023 at 9:09 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    No, don't fix it like that, fix it at the rag joint or the splined portion of the rack.
    Digiratus, jubei, Wulf and 1 other person like this.
  5. Apr 21, 2023 at 9:11 AM
    Speedytech7
  6. Apr 21, 2023 at 9:13 AM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Conductive grappling hooks all sold out?
    Abeyancer[QUOTED] likes this.
  7. Apr 21, 2023 at 9:14 AM
    treyus30
    Trey
    Mesa / AJ, AZ
    Needs more gators
  8. Apr 21, 2023 at 9:16 AM
    Wulf
    rock raisin
    You've seen my trucks, did I ever not have low standards ? :luvya:
  9. Apr 21, 2023 at 9:16 AM
    Wulf
    rock raisin
    assuming half of them are bots, we must put on a pretty good show for the rest
  10. Apr 21, 2023 at 9:21 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I thinks a drive around and shoot stuff on my 200k acre Texas ranch truck
    04Pre_Runner likes this.
  11. Apr 21, 2023 at 9:21 AM
    Abeyancer
    Jimmie
    PNW
    Okay I'll do it that way thank you.
    Is it possible to remove that ragjoint bolt and slide it up off the shaft to rotate it, without ing having to remove or loosen the rack itself?
  12. Apr 21, 2023 at 9:23 AM
    Speedytech7
    Yeah that's what I've done in the past, sometimes you need to remove that pinch bolt and tap a little wedge in the pinch to get it to play along
  13. Apr 21, 2023 at 9:23 AM
    Abeyancer
    Jimmie
    PNW
    :rofl::rofl:time to make my own!
    treyus30[QUOTED] likes this.
  14. Apr 21, 2023 at 9:24 AM
    Speedytech7
    Got the industrial strength chinese finger traps
    Abeyancer[QUOTED] and treyus30 like this.
  15. Apr 21, 2023 at 9:26 AM
    Abeyancer
    Jimmie
    PNW
    Awesome, thanks for the headsup
    Without removing the boots is it possible to make sure the rack itself is centered? The alignment was so fucked on my way home last weekend I didn't really give it a test drive but backing out of the stall something felt like I didn't have as many steering wheel rotations in one direction compared to the other.
    I didn't fuck with the rack, literally pulled it out of the toyota box, put on the rag joint, then bolted the two halves together. I don't have even stick out on my OTEs but I'm guessing thats cause I could not eyeball the alignment effectively
    Wulf likes this.
  16. Apr 21, 2023 at 9:28 AM
    Speedytech7
    I forget how many turns it is from lock to lock, but it usually comes centered out of the box and has mark on it to show that it is.
    Abeyancer[QUOTED] and Wulf like this.
  17. Apr 21, 2023 at 9:28 AM
    Abeyancer
    Jimmie
    PNW
    Don't know if you've ever messed with one but I've got a scrap one from my old job that I literally play with as a finger trap lol20230421_092726.jpg
    Wulf and Speedytech7[QUOTED][OP] like this.
  18. Apr 21, 2023 at 9:29 AM
    Abeyancer
    Jimmie
    PNW
    I'll double check that when I get it on the lift tomorrow, thank you
    Wulf likes this.
  19. Apr 21, 2023 at 9:53 AM
    Abeyancer
    Jimmie
    PNW
    Calling around tire shops this AM, tells me 15s are hard to come by:bananadead:
    Has anyone here ordered off tire rack. Com before?
    Wulf likes this.
  20. Apr 21, 2023 at 9:54 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Super popular, they're on the forum as well so you could see about getting a discount or is that discount tire?
    Either way tirerack is big.
