  1. Apr 30, 2023 at 12:28 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Vaccum lines shouldn't cause a no start, maybe a rough start but not a no start
    Wulf likes this.
  2. Apr 30, 2023 at 12:28 PM
    Wulf
    rock raisin
    eek that sucks. Do you have any starting fluid on hand? If not a tiny amount of brake cleaner might kick it over and get it going
  3. Apr 30, 2023 at 12:32 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    It's a different sort of crank; I don't hear the starter It's just the initial whirl but don't feel anything else.
  4. Apr 30, 2023 at 12:32 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Battery checks in at 12.6v
  5. Apr 30, 2023 at 12:33 PM
    Speedytech7
    Engine isn't moving when starter is activated? Did you shear off flexplate teeth?
    Wulf likes this.
  6. Apr 30, 2023 at 12:33 PM
    Wulf
    rock raisin
    give the starter some love taps and try it again
  7. Apr 30, 2023 at 12:33 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    No movement correct
  8. Apr 30, 2023 at 12:34 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Already did
  9. Apr 30, 2023 at 12:34 PM
    Wulf
    rock raisin
    i hope it's not the flex plate teeth that suuucks.
    Though you can probably turn the engine over by hand a bit to get to a section of the flex plate with more teeth.
    Time to pull the starter and take a peek
  10. Apr 30, 2023 at 12:35 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Giving it gas started it up, stumbled and died
  11. Apr 30, 2023 at 12:37 PM
    Speedytech7
    So engine is turning?
  12. Apr 30, 2023 at 12:38 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Now it is, running too.
    What boggles me is my lines aren't leaking fluid and don't suck in air (brake lines that is) yet I can't get the bitch to bleed.
    It's running now though; smell of gas poofed out the exhaust.
    Wulf likes this.
  13. Apr 30, 2023 at 12:39 PM
    Wulf
    rock raisin
    Are the brake bleeders OEM? They are probably clogged up
  14. Apr 30, 2023 at 12:41 PM
    Speedytech7
    Plug your scantool in, see if the coolant temp is reasonable, when that sensor goes starting becomes a chore and everything runs dummy rich
    Wulf likes this.
  15. Apr 30, 2023 at 12:41 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I had to tap them, and clean them up a shit ton to get them loose so safe assumption they're OEM.
    I should've bought new bleeder screws.
  16. Apr 30, 2023 at 12:42 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Yeah I'll do that in a sec.
    That's what the 4R did but in this case, it was only rich smelling on startup. It's idling perfect, no exhaust fume color or weird smells.
    Wulf likes this.
  17. Apr 30, 2023 at 12:44 PM
    Wulf
    rock raisin
    I have this Dorman Speed bleeder PN that works for Tacoma/4runner/pickup and is stocked by parts stores: Dorman #12709
    Maybe Zane or Dan can confirm it works for LC if you need to grab em today
    Kwikvette[QUOTED] likes this.
  18. Apr 30, 2023 at 12:45 PM
    Wulf
    rock raisin
    fuck, you have lots of good wisdoms. I should check mine too.
  19. Apr 30, 2023 at 12:46 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    What's funny is I asked myself this morning if I should bother bleeding it if I don't have new bleed screws :anonymous:
  20. Apr 30, 2023 at 12:47 PM
    Speedytech7
    0xDEADBEEF and Wulf[QUOTED] like this.
