  1. May 16, 2023 at 9:01 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I'm with you. Back in the day my public school education taught that Pluto was a planet. I was devastated to find out it had been demoted.
  2. May 16, 2023 at 9:04 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I caught the news mid schooling and no longer know what to believe anymore. My entire basis for understanding the galaxy was shattered.
    Wulf, Digiratus[QUOTED] and eon_blue like this.
  3. May 16, 2023 at 9:06 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    The whole argument was because it's too small or something?
    By that logic, we should exclude Jupiter as it's uncertain whether it even has a solid core or not. Same goes for any other gaseous planet.
    But yea #teampluto here too.
    Abeyancer and eon_blue like this.
  4. May 16, 2023 at 9:20 PM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    Wulf[QUOTED] likes this.
  5. May 16, 2023 at 9:34 PM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    Yeah. I’d be more looking for an abandon one on a ranch for $1500. I talk about this then let my 04 sit in the garage apart for 9+ months.
  6. May 16, 2023 at 9:35 PM
    Speedytech7
    I see sad looking 3fe ones up here in the 2k range sometimes
  7. May 16, 2023 at 9:39 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    As is tradition here.
    04Pre_Runner[QUOTED] likes this.
  8. May 16, 2023 at 9:47 PM
    Abeyancer
    Jimmie
    PNW
    First let me state: Electrolysis, in this regard, is the corrosion of engine components when an excess current passes through them and the coolant acts as an electrolyte. It's made worse at the union of 2 or more dissimilar metals (ie the aluminum head and iron block) coolant can more readily become an electrolytic solution when is degrades from a weak acid to a weak base.
    So technically yes, any coolant will eventually allow this to happen. Almost every single automotive coolant is ethylene glycol based (shoutout to my propylene glycol little equipment) but not all ethlyene glycol is the same. Green coolant is IAT or Inorganic Acid Technology. Our red coolant is HOAT (or currently I believe it is OAT) which is Hybrid Organic Acid Technology. Number 1 difference between the 2 is that to make the solution acidic, IAT will include Silicates, where as HOAT/OAT will use Phosphates. Asian car manufacturers say Silcate is bad for the seals they use but, (IMO cause I haven't done any really testing) the chemical composition of the alloys they use to make the various engine components is the real culprit. My anecdotal evidence is that I've seen alot of older 20r/22r and 22re engines that have the level of corrosion and pitting on the head equal to that picture I shared earlier. Each one was running green. I've also seen some 3cyl Kubota engines in Bobcats that had aluminum radiators leaking like a sieve from running green stuff for only 1 season
    Regardless, due to the chemical differences between IAT and HOAT/OAT, every car manufacturer agrees IAT will degrade from an acid to a base faster than its competitors and should be replaced more frequently. I don't want to give you a brand new fear to be obsessed over... you're seriously A-Okay running green. But don't wait 3yr/30k to flush and change it, it will be worn out before then.
  9. May 16, 2023 at 9:49 PM
    Abeyancer
    Jimmie
    PNW
    I guess technically yes? But electrolysis will speed normal galvanic corrosion way the fuck up, and there's always some amount of transient voltage going through the engine components
  10. May 16, 2023 at 9:56 PM
    Abeyancer
    Jimmie
    PNW
    @treyus30
    Thinking more about it, isn't galvanic corrosion only when 2 dissimilar metals fuse with one another?
    Wulf likes this.
  11. May 16, 2023 at 9:56 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Having dealt with this shit before, I'm 90% positive I did.
  12. May 17, 2023 at 5:36 AM
    Ozark_RegCab
    Ozark_RegCab Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    Wait a minute, I thought coolants were supposed to stay alkaline. Also, couldn’t that corrosion have been caused by a bad ground?
  13. May 17, 2023 at 6:29 AM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    One of those old timer tricks once you learn, you never go back. A little goes along way. Suspension parts and wheel lugs, it's a must!
    I found out that the Hubble photographs, which when younger spurred imagination and blew me away, were actually shot B&W, the color was added in post. Sad day that was.
  14. May 17, 2023 at 6:50 AM
    Speedytech7
    Still pretty crazy how good those images were given the limited bandwidth for transmission back to earth and given that infrared and visible light spectrum digital cameras back then were barely developed. Hubble is/was still very impressive, even if someone had to bust out the crayons to fill in the blanks.
    m3bassman[QUOTED] and Abeyancer like this.
  15. May 17, 2023 at 7:02 AM
    Abeyancer
    Jimmie
    PNW
    No, coolant that is alkaline isn't effective for corrosion resistance. Brand new coolant will have a pH of 2.0-2.6
    Yes that corrosion can be caused by a bad ground, it'll happen way worse with brand new coolant if it's bad enough. But even with good grounds it can still happen with coolant that expires
  16. May 17, 2023 at 7:46 AM
    Wulf
    rock raisin
    god mother fucking DAMN. It's taken months but my insurance approved 3 doses. There's no way anyone can pay for this out of pocket
  17. May 17, 2023 at 8:02 AM
    Wulf
    rock raisin
    Yes
    Abeyancer[QUOTED] likes this.
  18. May 17, 2023 at 8:07 AM
    m3bassman
    Green truck
    That's fair. But it felt like I was lied to to find that out years later haha
    Oh and I'm looking at a 5.3 later today :spy:
    Wulf likes this.
  19. May 17, 2023 at 8:07 AM
    Speedytech7
    I thought you're gonna go for the 6.0?
    Wulf likes this.
  20. May 17, 2023 at 8:10 AM
    m33ps
    m33ps Member
    PNW
    2004 TRD 3.4 XtraCab
    Anyone know what this is? Spotted on the way to work. Has to be custom, no?
