  1. Oct 20, 2018 at 12:07 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    I've heard of people using romex in trailers & RVs without issues. Me personally I would use stranded as it's more vibration resistant than solid core. You would pretty much never use solid core for automotive use. But then again I know nothing about trailers & I've never had to wire AC for automotive use.
  2. Oct 20, 2018 at 12:07 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    It’s Friday.
    zero4 likes this.
  3. Oct 20, 2018 at 12:08 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Right I believe that’s why Romex, and solid wire is never used in moving vehicles or machinery. It’s the vibrations that’ll harm it.
    zero4[QUOTED] likes this.
  4. Oct 20, 2018 at 12:08 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Sleeping early is for old folks.
    Guess I should be going to sleep soon too then.
    BartMaster1234 likes this.
  5. Oct 20, 2018 at 12:10 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Marine grade
    BartMaster1234[QUOTED] and zero4 like this.
  6. Oct 20, 2018 at 12:10 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Yeah that's how I understand it. Hmm, maybe do a quick search on RV or camper forums?
  7. Oct 20, 2018 at 12:13 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Any specific gauge?
  8. Oct 20, 2018 at 12:14 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    What are you wiring up?
  9. Oct 20, 2018 at 12:14 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    120v Outlets
  10. Oct 20, 2018 at 12:16 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    I believe in that case you still should follow the rules with AC. Wire gauge & breaker size depends on amperage & wire run length. But length shouldn't be much of a factor in a trailer.
  11. Oct 20, 2018 at 12:31 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    Why? Do you plan on living in this trailer? When would you ever need 120v? If you can run a shore power cable to the trailer, it would be just as easy to open the door and run the extension cord inside.
  12. Oct 20, 2018 at 12:37 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    To run or charge tools on the road.
  13. Oct 20, 2018 at 1:15 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    Just mount a 12v inverter to the wall. That will give you 2 outlets. Also will need to run a heavy gauge 12v power supply cord to the pickup battery.
  14. Oct 20, 2018 at 5:09 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Use PVC electrical conduit to run the 12 gauge, stranded wire. The conduit and boxes are cheap. You could get by with 14 gauge easily as well.
    Are you putting in a breaker box? You will need a 30 amp, waterproof,recessed male plug.
  15. Oct 20, 2018 at 6:08 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I cross my left leg under my right leg.
    Crodell6 likes this.
  16. Oct 20, 2018 at 6:55 AM
    Ramphonic
    Ramphonic Well-Known Member
    Cape Cod
    2k1 SR5 4x4 V6
    Adjustable Bilstein, AAL Lift, Eagle Rims with BFG ATs, Trd Exhaust, Clear Corners, Red Clear Tails
    Seems like this is happening alot. Im trying to find someone to help replace my backing plates
  17. Oct 20, 2018 at 7:49 AM
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    Friends my alternator died last week I haven’t ordered a new one yet what’s everyone recommend? I don’t need crazy output stock has always worked fine so far..
  18. Oct 20, 2018 at 7:52 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    or just kick his ass :rofl:
    Denso only which is after all, stock. :thumbsup:
    Crow_of_judgement and what road like this.
  19. Oct 20, 2018 at 7:52 AM
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    So I'm getting ready to do my frame swap on my 04 as soon as my new frame arrives from the barge.
    I have a really bad spacer in the front, and a block in the back. (Revtek) Its a 2.7L 4x4, Stock front bumper.
    I am trying to achieve 3 inches of lift. no more, no less.
    Goal is also to eliminate any possible rake.
    https://bilsteinlifts.com/shop/toyota-tacoma/boss-1995-2004-toyota-tacoma-suspension-system/
    550LB silver coils
    Diff drop
    Add a leaf for rear, taking out block
    Plus, https://jbaoffroad.com/toyota/jba-std-high-caster-upper-a-arms-for-1996-2004-toyota-tacoma.html
    Everything look good?
  20. Oct 20, 2018 at 8:15 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
    i been dropping him down some pegs with 4LO memes lol
