  1. May 31, 2023 at 12:15 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Niiiice
    I miss having extra PC parts
    And DDR4 is stupid cheap yet still used in current builds
  2. May 31, 2023 at 12:19 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    You only wanted easy mode? There's not a single lock in that pile that you'll have to single pin pick, you can rake them all and a couple you can use a comb pick and just lift up. The only master locks that are a challenge are the lockout tag out locks, they're a 5 pin core with spools and serrateds.
    treyus30 likes this.
  3. May 31, 2023 at 12:24 PM
    Speedytech7
    Oddly enough these chintzy little locks have the best core master lock makes
    https://www.amazon.com/Government-Safety-Lockout-Padlock-Zenex/dp/B00192092C/
  4. May 31, 2023 at 12:28 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Different types (no spools) to teach me some muscle memory in learning how to 'finesse'
    I won't try my hand at raking these and really want to learn how to better apply my tension wrench and get a feel for everything.
    Spools are definitely next but I figured since no lock is the same, maybe one would give me more trouble than the next?
    The Donner can be shimmed, but not bypassed (it's shielded) and they're harder to single pin pick versus any of the Master Locks.
    Abus is next on the list since they run 3 spools.
    Never tried a deadcore before though so I'll run spools for a bit before anything with a deadcore or more pins.
  5. May 31, 2023 at 12:37 PM
    Speedytech7
    Spools are probably the hardest to get a feel for since you'll almost always need counter rotation to let them get by
    Kwikvette[QUOTED] likes this.
  6. May 31, 2023 at 12:44 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Abeyancer and Kwikvette like this.
  7. May 31, 2023 at 12:44 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Yeah I've learned a little about counter rotation messing with other locks that have different spring tension.
    It's been fun as fuck for sure, but once I get a lock with spools you'll be the first to know (if I open it) :rofl:
    But yeah I'll order one now.
    Either a Master Lock 570 or Abus 55/40
  8. May 31, 2023 at 12:45 PM
    Speedytech7
    Prybar works on em well cause of the plastic body, the irony... masterlock uses its only non shitty lock core on its weakest lock
  9. May 31, 2023 at 12:52 PM
    Speedytech7
  10. May 31, 2023 at 1:08 PM
    01x4
    01x4 I know what I'm doing?
    Coast of Southeastern VA
    I go for reusables bc it's closer. Air filters, garden stuff, paintbrushes, etc., etc.
    Wulf and Kwikvette[QUOTED] like this.
  11. May 31, 2023 at 1:16 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Pretty much any disconnect handle can be pulled enough to the side to go around the lock too.
  12. May 31, 2023 at 1:28 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  13. May 31, 2023 at 1:35 PM
    eon_blue
    Azusa, CA
    I just horrified a bunch of coworkers in the break room...grabbed my taquitos out of the toaster oven and put them on a plate, then moved too fast and they all fell off the plate onto the floor. Figured fuck it, I don't want to cook more and the 5 second rule still applies so...bon appetite.
    They were all like "NOOOoooo Ryan what are you dooooooinnng EEWWWWW" haha
    treyus30, Wulf and Kwikvette like this.
  14. May 31, 2023 at 1:41 PM
    Wulf
    rock raisin
    I feel like it's ok because you have a toddler
    Your immune system is already used to regular stress testing
    Kwikvette and eon_blue[QUOTED] like this.
  15. May 31, 2023 at 1:42 PM
    eon_blue
    Azusa, CA
    just spiced them up with a little floor seasoning
    Kwikvette likes this.
  16. May 31, 2023 at 1:43 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Would you say as shocked as your family was when they saw you properly flipping a tortilla?
  17. May 31, 2023 at 1:43 PM
    Speedytech7
    Did he use a tool?
  18. May 31, 2023 at 1:44 PM
    eon_blue
    Azusa, CA
    you mean with tongs right
  19. May 31, 2023 at 1:46 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Don't call him a tool :rofl:
  20. May 31, 2023 at 1:46 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Abeyancer likes this.
