  1. Jun 3, 2023 at 5:35 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    You take “taste the rainbow” literally. Rip to all the fallen crayons
  2. Jun 3, 2023 at 5:39 PM
    Wulf
    rock raisin
    YESSSSSS boo
    Kwikvette[QUOTED] likes this.
  3. Jun 3, 2023 at 5:46 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Just hanging with a bunch of chill Toyota people at Hot Springs Off-road Park.
    Kwikvette and Sperrunner like this.
  4. Jun 3, 2023 at 5:57 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Why didn't @Ozark_RegCab go
    CS_AR[QUOTED] likes this.
  5. Jun 3, 2023 at 6:09 PM
    Nicklovin
    Nicklovin Mall Crawlin Through Life
    Nick
    Huntington Beach, CA
    00 The Tunda - 0̶4̶ P̶r̶e̶r̶u̶n̶n̶e̶r̶ - 0̶1̶ O̶v̶e̶r̶l̶a̶n̶d̶e̶r̶ - 07 FJ Mall Crawler Xtrme
    Tacoless
    Thinking it’s just the sensor. So far no leaks. Just waiting on it to cool down, still 99 degrees, then drive it back to the house.
    Bad timing though as this was the start of a 12 day road trip through Utah then up to Yellowstone.
    6 cylinder
    Hahaha yeaaa same, the taco just decided it doesn’t want to go to Moab and Yellowstone this time :anonymous:
  6. Jun 3, 2023 at 6:11 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You can go home, fix whatever issue, then turn back around and go to Moab!
    Or better yet fix it on-road.
    When we did our Moab trip, 99% of us drove the whole way to. My trip was 17hrs and I think @eon_blue was 13-14hrs. Drove non-stop each way.
    You've got members that live along your route and I'm sure many would lend a hand.
    Nicklovin[QUOTED] and Tour991 like this.
  7. Jun 3, 2023 at 6:13 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    Just call to Moab and order a new sensor. Install it when you're up there. Wouldn't stop me but I am a bit reckless I suppose.
    Nicklovin[QUOTED] and Kwikvette like this.
  8. Jun 3, 2023 at 6:16 PM
    Nicklovin
    Nick
    Tacoless
    True true good points
    Haha yea I could gamble that. Hell I could swap it out in vegas or St. George too. Just a tad bit concerned as the temp gauge spiked earlier
    Also I have a stock FJ Cruiser at home that I’m probably just going to swap all my camping gear to then deal with the taco after the trip :anonymous:
    Kwikvette[QUOTED] and eon_blue like this.
  9. Jun 3, 2023 at 6:17 PM
    eon_blue
    Azusa, CA
    You got an FJ? Nice, those are $$$ used, better resale than Tacomas even
    Tell me you got a manual one
  10. Jun 3, 2023 at 6:19 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Wait, are you monitoring your temps via gauge?
    You need to use your OBD tool.
    That gauge is a dummy gauge and it'll easily give you false readings (good or bad) while your actual engine temps could be altogether different.
    Your ECT sensor up front is what reads actual temps, and that signal is sent to your ECM and available via OBD.
    The gauge receives its signal from a sender at the rear of the engine, as it's a single wire plug that's worthless.
  11. Jun 3, 2023 at 6:26 PM
    snoopytaco
    snoopytaco Well-Known Member
    Xander
    2003 Tacoma
    In progress Frame repair Bilstein 6112s Ome Dakar leaf pack Tundra brake upgrade 315/75/16 nitto trail grapplers
    Sounds good man! I've already done quite a bit of grinding outside of their cuts but will just continue to chop away at it!
  12. Jun 3, 2023 at 6:30 PM
    Nicklovin
    Nick
    Tacoless
    I wishhh it was manual. This one is an 07, I think?, with about 130k on it. Picked it up under 12 to flip it. So many scratches hah
    Huh didn’t know that. I’ll keep an eye on the obd temp when I get the truck rolling
  13. Jun 3, 2023 at 6:33 PM
    m3bassman
    Green truck
    Your temp worked due to the bad sensor reading is my guess. Otherwise, if the fluids in the engine, your WP is turning I wouldn't worry much.
    Nicklovin[QUOTED] likes this.
  14. Jun 3, 2023 at 6:34 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Yeah that sender communicates with the gauge.
    The sensor communicates with the computer and OBD.
    I missed what you said about the engine code but if I were you, I would monitor temps via OBD only.
    If your ECT sensor was having an issue, most likely it would run as if it was cold and dumping a lot of fuel followed by a high idle.
  15. Jun 3, 2023 at 6:38 PM
    snoopytaco
    Xander
    2003 Tacoma
    Do you think it matters a lot of I can’t get them absolutely perfect? I mean I’ll get them closer but I’m not sure what a “safe” margin of error is. There’s a lot of variables with suspension so I doubt I’d be able to notice it much
  16. Jun 3, 2023 at 6:41 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I'm only a welder, gaining experience as a fabricator (mostly things outside trucks).
    With that said, I would ask the suspension gurus regarding that difference in your rear axle.
    Personally I don't believe anything to be absolutely and perfectly square, as much as we'd want it to be, but if I were you, I would grind/bevel what was needed to get that 1/4" of room to move the bracket over.
    Not sure what you said cutting away though. You can easily remove 1/4" from any piece within seconds and be done.
    snoopytaco[QUOTED] likes this.
  17. Jun 3, 2023 at 6:48 PM
    Nicklovin
    Nick
    Tacoless
    That’s a sigh of relief thanks
    Actually I did have a pending code 171, system running lean bank 1. Kinda glad to hear it’s most likely just a bad sensor.
    My butt might be a little less puckered watching the temps on the way home haha thanks
  18. Jun 3, 2023 at 6:57 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Tour991 and Yota X like this.
  19. Jun 3, 2023 at 7:09 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    The only Jeep you can call reliable :bananadead:
    Tour991, Nicklovin and Yota X like this.
  20. Jun 3, 2023 at 7:11 PM
    Yota X
    Yota X Some say dresser, I say dryer.
    NW New Jersey
    1st gen
    ls turbo, tons, 40's and a partidge in a pear tree
    McDonald’s offer a lot of build options. Even a standard issue 4dr jeep can be chosen for a happy meal.
