  1. Jun 12, 2023 at 12:48 PM
    eon_blue
    Azusa, CA
    The amount of women's pants we produce at my company with no pockets, or worse yet..."faux pockets", is crazy.
    What good are pants without pockets??
    jubei likes this.
  2. Jun 12, 2023 at 12:49 PM
    Ozark_RegCab
    Ozark_RegCab Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    Yea it’s weird cause it seems like most of that has been in the last 1000 miles or so.
  3. Jun 12, 2023 at 12:53 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I mean, you were just thinking that using the wrong weight oil would've killed your truck...I'm pretty sure dropping the diff and replacing your oil pan would be the equivalent to getting your balls nailed to a tree stump and having that stump lit on fire with the only thing within arms reach being a rusted hack saw.
  4. Jun 12, 2023 at 12:56 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Little extreme? :rofl:
    Abeyancer likes this.
  5. Jun 12, 2023 at 1:03 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    Owners manual says for 5w30. This isn't a cocktail to just try. The engineers at Toyota knew what they were doing and spec that oil due to the lubricity it provides over a broad spectrum of temperatures within the tolerances they designed into the moving parts of the engine, such as bearing tolerances and the oil pump flow rate. It wouldn't surprise me if you caused wear in the motor leading to oil consumption from using the wrong oil in your engine for an extended period of time.
  6. Jun 12, 2023 at 1:04 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Just pull it.
    Kwikvette and Abeyancer like this.
  7. Jun 12, 2023 at 1:09 PM
    eon_blue
    Azusa, CA
    @Kwikvette I needed your lock picking abilities this morning...our model changing room in the studio has a door that will lock itself if closed, so I put tape over the latch which has worked for years until this AM when it didn't. Had to climb a 12 foot wall and jump over the side to get into the room. Tried picking it first but have zero idea what I'm doing lol
  8. Jun 12, 2023 at 1:10 PM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    I think you've given those engineers a little too much credit:laughing:
    There's even a really broad temp range in the owners manual for both the 5w30 and 10w30
  9. Jun 12, 2023 at 1:10 PM
    m3bassman
    Green truck
    As someone preparing to do just this, why did you pull the intake plenum off to pull the motor? I have been looking for connections external to it to hook to. Drivers side has the loop bracket, not sure I found a suitable spot on the passenger side. Maybe @Speedytech7 has some tips/tricks too when it comes to pulling the 5vz.
    CS_AR[QUOTED] likes this.
  10. Jun 12, 2023 at 1:12 PM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    European specs of the 5VZ also recommended 40 weight oil. I think the 5w-30 thing had more to do with CAFE. I mean would that marginal of a difference really change anything?
    Wulf and CS_AR like this.
  11. Jun 12, 2023 at 1:16 PM
    CS_AR
    I had the intake off anyway to replace gaskets, knock sensors, and to install a beefed-up knock sensor harness.
    m3bassman[QUOTED] and Abeyancer like this.
  12. Jun 12, 2023 at 1:20 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    if shit was going to blow up immediately it would be surrounded with lots more warnings in the manual.
    A lot of it does have to do with CAFE and helping the engine run optimally in specified conditions
    Abeyancer[QUOTED] likes this.
  13. Jun 12, 2023 at 1:20 PM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    Anyway I’m about send in a sample for analysis so if there was any damage it should show up in the Blackstone report.
  14. Jun 12, 2023 at 1:21 PM
    Wulf
    rock raisin
    Sounds like I've done everything right based on the propane chat group. my propane mixer is just half the size I need to support travel speeds
  15. Jun 12, 2023 at 1:21 PM
    Wulf
    rock raisin
    Can they check for brain damage too? I could use another analysis myself :luvya:
  16. Jun 12, 2023 at 1:22 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Damn
    And my TOK tension wrenches arrived last week too, would've been perfect
    eon_blue[QUOTED], Abeyancer and CS_AR like this.
  17. Jun 12, 2023 at 1:26 PM
    eon_blue
    Azusa, CA
    yeah HR woulda had a heart attack if she'd walked in when I was climbing over that wall, kind of wish she had just to see her reaction
    Kwikvette[QUOTED] and Wulf like this.
  18. Jun 12, 2023 at 1:26 PM
    Wulf
    rock raisin
    one of the rules is also that there are no rules sometimes :bananadead:
    Kwikvette and Abeyancer[QUOTED] like this.
  19. Jun 12, 2023 at 1:26 PM
    Wulf
    rock raisin
    Heart Resources department
    eon_blue[QUOTED] likes this.
  20. Jun 12, 2023 at 1:28 PM
    m3bassman
    Green truck
    Hey man you do you. If the Tacomas sold in Europe use a different oil then feel free. I can't remember off the top of my head, how many tacomas were sold in Europe?
    The manual doesn't warn against a 200 shot of nitrous... So maybe it isn't a terrible idea to strap to the 5vz before I pull it :evil:
    Wulf[QUOTED] likes this.
