What would you rather listen to instead of Cold Play
This poll will close on Jul 20, 2025 at 7:20 AM.
  1. Nails on a chalboard
    5.9%
  2. Bass boosted memes
    52.9%
  3. Rod knock
    52.9%
  4. Political discourse
    11.8%
  5. That one annoying drunk gal at a comedy club
    11.8%
  6. No i really do like Cold Play and I'm not writing this under duress (help Cold Play is in the room)
    11.8%
Multiple votes are allowed.
  1. Jun 21, 2023 at 12:39 PM
    Wulf
    Wulf no brain just damage
    rock raisin
  2. Jun 21, 2023 at 12:42 PM
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    that’s the plan, so there’s no need to evacuate before changing out parts?
    Thanks.
  3. Jun 21, 2023 at 12:44 PM
    Wulf
    rock raisin
    If the freon is out due to a leak it's out lol. There's nothing left to evacuate except any residual PAG oil
    I don't think I vacuumed mine before changing parts, only after.
    I'm not any kind of HVAC pro, maybe @Sperrunner can provide the proper info
    Parkvisitor[QUOTED] likes this.
  4. Jun 21, 2023 at 12:54 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  5. Jun 21, 2023 at 1:00 PM
    01x4
    01x4 I know what I'm doing?
    Coast of Southeastern VA
    CS_AR and Ozark_RegCab[QUOTED] like this.
  6. Jun 21, 2023 at 1:09 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  7. Jun 21, 2023 at 1:19 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Gonna have to throw away my skid plate @Ozark_RegCab
    Someone suggesting i shouldve gone aluminum :rofl:
    Ozark_RegCab likes this.
  8. Jun 21, 2023 at 1:20 PM
    Wulf
    rock raisin
    jubei and Taco critter like this.
  9. Jun 21, 2023 at 1:22 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You're the one with the biggest shop between us so...cooking at your place? :D
    I'll bring my gloves :anonymous:
  10. Jun 21, 2023 at 2:19 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
  11. Jun 21, 2023 at 2:27 PM
    Wulf
    rock raisin
  12. Jun 21, 2023 at 2:29 PM
    Speedytech7
    Them Japanese engineers are smart cookies... Unlike your typical Mopar owner...
    Why go fast make hot?
  13. Jun 21, 2023 at 2:32 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Fucker's mint
    I'll deal with rear mounting later
    jubei, 01x4, CS_AR and 1 other person like this.
  14. Jun 21, 2023 at 2:35 PM
    Speedytech7
    That's nice, mine is missing the t-case skid ever since it went to a shop before auction, pretty sure they drained the t-case and forgot to put it back
    CS_AR and Kwikvette[QUOTED] like this.
  15. Jun 21, 2023 at 2:39 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Thanks!
    That sucks about your skid, but I doubt either of us were missing much not having it. Pretty thin piece of steel I'd assume?
  16. Jun 21, 2023 at 2:41 PM
    Speedytech7
    Yeah it's just a tin deal from what I can tell, never seen one in person but I guess it has the skid portion (just so stuff slides off rather than hanging on the cases weird shape) and a reinforcement portion for the bolts so they don't tear out.
  17. Jun 21, 2023 at 2:43 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @Speedytech7
    @Wulf
    Metaltech wants $80 for their u bolts, and White Knuckle won't respond about selling me a set.
    Also seems no one on mud wants to share the dimensions for their custom ordered u bolts...it's as if hiding the holy grail. :jerkoff:
    With that said, this was what I had in mind for mounting; a plate on each side to sandwich the frame but with square tube that'll bolt up against the rear of the skid plate.
    Seeing how I nailed the bracket dimensions perfectly, I may still want to go with the U bolt method on one side to attach to the bracket.
    Any vendor I should check out for a strong, single u bolt? Are they measured the same as other bolts in terms of strength?
    There's a tractor supply but not sure what type they use in terms of strength (not to mention limited supply).
    CS_AR likes this.
  18. Jun 21, 2023 at 2:49 PM
    Speedytech7
    Got a spring maker near you? The local leaf spring maker here just makes ubolts exactly as you ask for them
    Kwikvette[QUOTED] likes this.
  19. Jun 21, 2023 at 2:50 PM
    Wulf
    rock raisin
    Tractor store is a good idea
    Do you have any local trailer shops? They can bend up custom u bolts for cheap
    Speedytech7[OP] likes this.
  20. Jun 21, 2023 at 2:50 PM
    Wulf
    rock raisin
    wew lad
