  1. Jul 14, 2023 at 11:08 PM
    Wulf
    rock raisin
    change oil, and diff fluids if you haven't relocated the breathers
  2. Jul 14, 2023 at 11:12 PM
    snoopytaco
    snoopytaco Well-Known Member
    Xander
    2003 Tacoma
    In progress Frame repair Bilstein 6112s Ome Dakar leaf pack Tundra brake upgrade 315/75/16 nitto trail grapplers
    I appreciate the response I’ll get on that right away, do I just do the one oil change or should I do it twice?
  3. Jul 14, 2023 at 11:27 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  4. Jul 14, 2023 at 11:52 PM
    Wulf
    rock raisin
    how's it look on the dipstick? Just one should be fine if it's not a milkshake
  5. Jul 15, 2023 at 5:11 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    I would rock one like this all day long.
  6. Jul 15, 2023 at 5:16 AM
    CS_AR
    I don't get the 100 series people complaining about frame rust. Just get some reinforcement panels and fuck it. [not mine]
    Taco critter likes this.
  7. Jul 15, 2023 at 6:24 AM
    Ozark_RegCab
    Ozark_RegCab Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    They seem to rust a lot more aggressively than 80 series frames. I’m not sure if the 80 had better rust proofing, or they just leaked more oil onto the undercarriage.
    CS_AR[QUOTED] likes this.
  8. Jul 15, 2023 at 6:24 AM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    I must’ve missed that. It was a really busy week in the field. Did someone end up trading for it?
  9. Jul 15, 2023 at 7:41 AM
    eon_blue
    Azusa, CA
  10. Jul 15, 2023 at 8:08 AM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    Wiring looks overwhelming here. Is that normal?
  11. Jul 15, 2023 at 8:09 AM
    Das it mang
    Az
    1996 T100 SR5 MT
    I should be able to replace those door panels. But with the wiring it looks like I'll short shit if i hit a puddle in that
  12. Jul 15, 2023 at 8:45 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
  13. Jul 15, 2023 at 8:46 AM
    Wulf
    rock raisin
    Erm, sort of . A lot of the pigtails and harnesses have about 2x as much slack as you'd expect and end up hanging all over the place. Not the best pic but you can see there's a lot of wiring in the bottom left
    Das it mang[QUOTED] likes this.
  14. Jul 15, 2023 at 8:47 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
  15. Jul 15, 2023 at 8:48 AM
    Wulf
    rock raisin
    honestly it would probably just take a couple hours of grinding and welding to fix that right up. Don't need to prep the whole frame, just the weld areas lol
  16. Jul 15, 2023 at 8:49 AM
    Wulf
    rock raisin
    bologna is hotdog pancakes for a more rounded meal
    Kwikvette likes this.
  17. Jul 15, 2023 at 8:50 AM
    Das it mang
    Az
    1996 T100 SR5 MT
    Okay that's reassuring at least, thank you! Do you have any insight on the weber carb ? I'd be interested if they aren't a haggle vs oem
  18. Jul 15, 2023 at 8:54 AM
    Wulf
    rock raisin
    the Weber carb is actually more reliable than the OEM asin carb in old age and high mileage. It's a pretty common swap and parts are more readily available. Maybe Zane can offer more insight on how the 32/36 works at that altitude, I have seen more 38/38s but the 32/36 should be plenty to support a 22R
    Do you live in an emissions area? The only thing I see is that the EGR has been deleted if they're strict on the visual inspection
  19. Jul 15, 2023 at 9:26 AM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
  20. Jul 15, 2023 at 11:16 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
