  1. Aug 3, 2023 at 12:22 PM
    eon_blue
    Azusa, CA
    high school flashbacks
    Kwikvette likes this.
  2. Aug 3, 2023 at 12:49 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I just wanna see Dishwalla and Fuel
    eon_blue[QUOTED] likes this.
  3. Aug 3, 2023 at 12:49 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Oh man
    You know the latest showtime will be at like 5-6pm to get us home in town to make sure we get enough sleep :rofl:
  4. Aug 3, 2023 at 12:50 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You uhm, you could just be our moral support :rofl:
    Abeyancer[QUOTED] likes this.
  5. Aug 3, 2023 at 12:50 PM
    Speedytech7
    It's a cruise, you just need to fall asleep without falling on someone else really
    Kwikvette[QUOTED] likes this.
  6. Aug 3, 2023 at 12:51 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Shit I missed the Cruise part :rofl:
    Fuck...are we going Ryan? :bananadead:
  7. Aug 3, 2023 at 12:52 PM
    eon_blue
    Azusa, CA
    It's happening on a cruise ship to the Bahamas lol
  8. Aug 3, 2023 at 12:54 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Yeah I quickly skipped that part and went from Creed to 3 Doors Down
    Reading thoroughly is my Kryptonite :laughing:
  9. Aug 3, 2023 at 12:57 PM
    Speedytech7
  10. Aug 3, 2023 at 1:23 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    Fuel, is the only band I would want to see, the rest is on the level of a root canal.
  11. Aug 3, 2023 at 1:24 PM
    Tour991
    James
    South Reno/Tahoe
    How did he do?
  12. Aug 3, 2023 at 1:24 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    I tried. The passenger side has had a noisy valvetrain. I assumed it was worn cams/lifters as I had no record of them being changed. So I tore it apart to see. At first I thought the cam was worn and bought the $2k kit from FCP to do both sides. After cleaning oil off the lobe it looked good so I need to return the kit. Managed to jump the timing gear when pulling it apart I think. But I reset it back to 40* and pulled the cams. What I found was that the cams were replaced at some point and the headbolts replaced, as well as lifters (both known issues). So that was great news and the cam adjusters look to have minor wear for the mileage so they may have been replaced too. The shitty thing is that somewhere along the line when someone did that work, they lost a couple dowels needed to properly time the engine. My timing tools would not fit but just barely. They also failed to lock the gear lash on the adjusters during install so they were what was making the noise. So once I fix the gear lash and correct the timing at all 4 cams it should be all good to go. With only minimal cost for new tty bolts, dowels and a timing kit. I'm hoping it picks up some power as I have to assume that the thing was adding timing since I've had it to correct the issue. I was curious if it was down on power for a while, it's pretty quick as you know but didn't feel as stupid as the white car. Combine that with only getting a 13.4s in the quarter had me sure something wasn't right. Stock they should run a 12.3, but mines not stock and should be making 50hp more than stock. That should make up for elevation so I should still expect a low 12 second pass.
    It would also explain the odd "bog" I have experienced between gears. You can hear it below when it shifts into third. Again, that was probably the computer trying to make up for being a tooth out of time in the cams.
    https://youtu.be/OwjvUVq_uVY
    I haven't found one yet. Keep looking for a used one but still haven't found anything. Just gonna rock it bumperless until something turns up.
    01x4[QUOTED] likes this.
  13. Aug 3, 2023 at 1:52 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    We'll see, his appt is at 3pm
    Took him out earlier to grab some eggs and formula; I was craving a tart and other yummy goods...not sure what I'll fill it with once I bake it but I'm also gonna make cake pops too later
    Tour991[QUOTED] likes this.
  14. Aug 3, 2023 at 2:13 PM
    Tour991
    James
    South Reno/Tahoe
    Sounds like it will be delicious.
    Making progress on this but starting to get too hot out almost 80°.
  15. Aug 3, 2023 at 2:48 PM
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    I too need to make a 4x5 slab.
    you guys ever try that dry method of spraying em?
    its a doorstep in my yard so want to not step in dirt.
  16. Aug 3, 2023 at 2:50 PM
    Speedytech7
    Yeah the dry method isn't very good, wet concrete sets the hardest. Being lazy doesn't typically payoff in construction
    Tour991 and Kwikvette like this.
  17. Aug 3, 2023 at 2:52 PM
    Sebz13
    Shane
    Maui Hawaii
    heard, I'd be hand mixing that shit in a wheelbarrow or maybe ill go buy a kids pool to throw away.
  18. Aug 3, 2023 at 2:53 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    God damn
    So we're at Theo's actual pediatrician now, and it's so convenient being 5 minutes from home
    This place is niiiiice, even has this sort of indoor/outdoor play area for kids (right side)
    And a big ass park just outside (left)
    Das it mang and Tour991 like this.
  19. Aug 3, 2023 at 2:56 PM
    Speedytech7
    That's the place that definitely charges too much, damn dude... it's nicer than most 5 star hotels.
  20. Aug 3, 2023 at 2:58 PM
    eon_blue
    Azusa, CA
    damn do they send a whole team of people to look for you when the doctors ready
    Das it mang likes this.
