  1. Aug 7, 2023 at 8:36 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Valve cover leaks are common. Sludge isn’t a huge issue unless neglected.
  2. Aug 7, 2023 at 8:37 AM
    Abeyancer
    Abeyancer Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    And when you've had even more than enough of those V8s your ears subconsciously perk up when they hear that balancer on someone else's rig at a red light lol
    Kwikvette[QUOTED] likes this.
  3. Aug 7, 2023 at 8:37 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Those rocks were all smoothed out due to the water out there
    I'm talking consistently dry areas with sharp rocks
    Think So Cal for instance, a lot of areas out there stay dry AF
    I'd hate to lose a tire on the trail and not have a spare
    You got a full size spare?
  4. Aug 7, 2023 at 8:39 AM
    Ozark_RegCab
    Ozark_RegCab Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    It’s some 32” all terrain. I think it’s a bit wider than my tires and probably not quite the same height, but it would work in a pinch to get me home.
  5. Aug 7, 2023 at 8:39 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Abeyancer[QUOTED] likes this.
  6. Aug 7, 2023 at 8:39 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You're not full-time 4WD; you'll be good
    I'd just make sure it isn't old and dry rotted
  7. Aug 7, 2023 at 8:41 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @Abeyancer
    With the exception of GM motors, do you have any experience with any motors having crappy OEM harmonic balancers?
    I've experienced and witnessed it on multiple LS engines; never on an LT engine though
    And not on my old LS3 but that had 67k miles only
    Abeyancer likes this.
  8. Aug 7, 2023 at 8:46 AM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    It must be very rare on Toyota engines. Their rubber is some of the highest quality around. I’ve only seen one case in a 1FZ.
  9. Aug 7, 2023 at 8:50 AM
    eon_blue
    Azusa, CA
    We come prepared for Sofia's quesadillas...TJs fire roasted tortillas and Costco shredded Mex cheese. Believe me she'll know if they're made with anything different
    0xDEADBEEF and Kwikvette[QUOTED] like this.
  10. Aug 7, 2023 at 8:51 AM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    That sounds similar to a 5VZ. Apparently after 8/96 they made the oil passages smaller for emissions reasons, which may have made them less resistant to sludging, but I’m not sure on that. My 96 Camry with the 5S was rock-solid. Those will still run mint even after unthinkable abuse.
  11. Aug 7, 2023 at 8:51 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    No, I'm talking common as in, expected
    It's an issue with many LS variants, knowing @Abeyancer and his wealth of random knowledge he'd probably chime in on something else he's familiar with
  12. Aug 7, 2023 at 8:52 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Bring extra, I may want some myself :anonymous:
    eon_blue[QUOTED] likes this.
  13. Aug 7, 2023 at 8:58 AM
    eon_blue
    Azusa, CA
  14. Aug 7, 2023 at 8:59 AM
    Abeyancer
    Jimmie
    PNW
    My results are probably skewed since I did unlicensed auto repairs outta my van for awhile. Almost allof my customers were waitresses or bartenders (and other bar patrons lol) that couldn't afford real shop rates so their cars were usually way more beat to shit than avg.
    That being said, the GM3.3 and GM3.8 stand out in my memory as regularly bad, or ones that were clapped out by 200k
  15. Aug 7, 2023 at 8:59 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I take mine to 8-11, no worries on an E load even without bead locks
    Wulf, Kwikvette and Abeyancer like this.
  16. Aug 7, 2023 at 9:05 AM
    Abeyancer
    Jimmie
    PNW
    I've rocked 10psi on C load tires :anonymous:
    Ozark_RegCab, Wulf and Das it mang like this.
  17. Aug 7, 2023 at 9:05 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Ha so GM in general just couldn't get it right
    Dayco makes a cheap and better replacement than an OEM variant, at least that was the common go to for replacement
  18. Aug 7, 2023 at 9:08 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @Wulf
    When you dream of playing with your shitbox crawler on 40s
    Realizing you forgot to refill your propane tank
    CS_AR, Tour991, Ozark_RegCab and 4 others like this.
  19. Aug 7, 2023 at 9:12 AM
    Abeyancer
    Jimmie
    PNW
    LOL I had a dayco one on my parts shelf cause it happened often enough for me (3 separate cars in a 5month period) but yes, in my, very limited, small sample size, work experience, GM engines require the most maintenance. But the only German cars I worked on were VW so it's possible the other guys were worse.
    At least as far as needing parts... I'd much rather work on a GM engine than a VW engine
  20. Aug 7, 2023 at 9:16 AM
    Empty_Lord
    Dan
    My buddy hasn’t changed the oil on his clunker in 3 years 25k miles. He’s got a spare motor for it, so at 310k miles he’s waiting for it to die. Lol the MZ is stout. Just dated like the VZ
