  1. Aug 16, 2023 at 3:15 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    *cue up all the comments saying you should drive your Taco cause It HaS a SnOrKeL :duh:
  2. Aug 16, 2023 at 3:17 PM
    eon_blue
    Azusa, CA
    will be the most justifiable snorkel action it's gotten in a few years, that's for sure
  3. Aug 16, 2023 at 3:50 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    It doesn't take long.
    Some people recover pretty quick. It took me a solid week to feel like I was normal again. You gotta be careful not to tear anything.
    eon_blue[QUOTED] likes this.
  4. Aug 16, 2023 at 3:51 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Didn't the eyelash fad die long ago?
    Tour991 and eon_blue like this.
  5. Aug 16, 2023 at 5:03 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  6. Aug 16, 2023 at 5:09 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
  7. Aug 16, 2023 at 5:11 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Lambofeeties :burp:
  8. Aug 16, 2023 at 5:12 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    IMO, that is a fairly reasonable report and certainly no reason to panic. FWIW, and this may be comparing granny smith apples to cosmic crisp apples, here is my most recent 3 blackstone reports. Worth noting is that I installed the supercharger at 226K so the numbers have actually improved since then and of cource, less miles between oil changes.
    Ozark_RegCab[QUOTED] likes this.
  9. Aug 16, 2023 at 5:46 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Bringing back my nightmares from jobs past.
  10. Aug 16, 2023 at 5:52 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    no wonder they don't run right
  11. Aug 16, 2023 at 5:53 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    FCs were garbage :rofl:
  12. Aug 16, 2023 at 6:20 PM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    Got the truck back, and she's been good so far. Power to weight ratio is not bad, but think the slug had a better pull. I won't complain having 4wd now tho
    01x4, Tour991, ChargedSHOTaco and 2 others like this.
  13. Aug 16, 2023 at 6:22 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Hit me up when you're ready to slap a supercharger on that bitch and a computer. We can speed it right up. Or if you're feeling really spicy we can figure out a turbo kit for a t100
  14. Aug 16, 2023 at 6:27 PM
    m3bassman
    Green truck
    Boost IS the answer for the 5vz.
  15. Aug 16, 2023 at 6:32 PM
    Das it mang
    Az
    1996 T100 SR5 MT
    The idea of a turbo has always been enticing, but that premium on every refill might hold me for a bit. I will say I kind of enjoy the body lines on the t100 over the taco
  16. Aug 16, 2023 at 6:32 PM
    Das it mang
    Az
    1996 T100 SR5 MT
    We'll see what bigger tires do to change my mind tho
    Kwikvette likes this.
  17. Aug 16, 2023 at 6:34 PM
    Speedytech7
    Gears for your front end will be cheap to find out of people swapping pickup stuff around but rear is still gone incur the taco tax since it uses the taco third member. But they'll be your easiest way to offset larger tires. Get some 33s on their and you'll probably be happy I'd guess. I have a buddy with a ball joint lift for your front end if you want it, he said he'd let it go for $20
  18. Aug 16, 2023 at 6:40 PM
    Speedytech7
    Definitely adds some fun
    Das it mang and Digiratus like this.
  19. Aug 16, 2023 at 6:43 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @Das it mang when you need some bed stiffeners let me know ;)
    Tour991, jubei and Das it mang like this.
  20. Aug 16, 2023 at 6:54 PM
    Das it mang
    Az
    1996 T100 SR5 MT
    Hoping to go 33x10.50s on the next set, might be able to do with cutting and bfh bashing. Smart thinking on the front end gears; how much do bj lifts give? An inch or so?
