  1. Aug 16, 2023 at 6:56 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I think the bj lift is 2" by default. But you can take the tension off the torsion bar from stock amount and make it as little as one inch of lift. It's the fat bob bj lift kit for Toyota pickups. It's how you get 3 in without losing all your down travel on a pickup front end.
    Das it mang[QUOTED] likes this.
  2. Aug 16, 2023 at 6:58 PM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    Last set was still holding up after the accident, I'll be getting in touch when that time comes for sure :)
    Kwikvette[QUOTED] likes this.
  3. Aug 16, 2023 at 7:05 PM
    Das it mang
    Az
    1996 T100 SR5 MT
    20 bucks is cheep insurance, sounds worth it as well. I'm still learning my front end, thank you for the summary. I need to pull that cv axle and I'll get a good anount of info. I can send ya 20 and the amount for shipping, just lmk
  4. Aug 16, 2023 at 7:08 PM
    Speedytech7
    I'll pick it up from his house. I think the only thing missing from it is the sway bar drop and if I remember correctly you don't actually need that if you only use it for an inch of lift
  5. Aug 16, 2023 at 7:11 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    There have been some improvements to the design since then ;)
    jubei and Das it mang[QUOTED] like this.
  6. Aug 16, 2023 at 7:33 PM
    Das it mang
    Az
    1996 T100 SR5 MT
    Thank you, hoping to do majority clearancing with bfh and angle grinder again; an inch should be plenty.
    Oh lawdy, they look so much nicer now. Do the dimples serve as latch/ tie down points once the brackets are bolted in??
  7. Aug 16, 2023 at 7:35 PM
    Speedytech7
    I don't think you'll hardly have to do anything for skinny 33s, they basically fit as is on pickups, they have way less interior foot room which means way bigger wheel well room
  8. Aug 16, 2023 at 7:37 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Tie down points are exactly what they're for ;)
    @Wulf was the test subject when I churned out the first set out of 12 gauge (as a beta). We decided the leg should be extended to add strength, and I opted to go 10 gauge vs 3/16" due to cost (both to me and the customer). The added strength from 3/16" was really unnecessary.
    I will still offer a set in 3/16" if someone wanted but that'd be even more.
  9. Aug 16, 2023 at 7:39 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Gotta say, truck looks good
  10. Aug 16, 2023 at 7:47 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  11. Aug 16, 2023 at 7:58 PM
    Das it mang
    Az
    1996 T100 SR5 MT
    I'd be okay with having to cut less for now. The 31s on it now have plenty of tread, they're old as shit but no cracking
  12. Aug 16, 2023 at 8:00 PM
    Speedytech7
    I mean a 10.5 is a skinny 33 you might have some trimming for a 12.5 tho. I think you can just bolt the skinnies right up
  13. Aug 16, 2023 at 8:05 PM
    Das it mang
    Az
    1996 T100 SR5 MT
    Nice! They came out really good, I'm happy to see how much progress you've had on them. Makes perfect sense on the gauging versus cost. I'll have to keep my eyes peeled for cheepie shells. Think beds the same size on the tundra? No se
    Thank you, really appreciate it. Was looking for about a month before it came up. Offerup again, just like the wheels and shell that were on the slug
  14. Aug 16, 2023 at 8:12 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Ozark_RegCab likes this.
  15. Aug 16, 2023 at 8:27 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Getcha some Kendas and get out there
  16. Aug 16, 2023 at 8:54 PM
    eon_blue
    Azusa, CA
    Just curious have you tested the 4wd out yet? I imagine it's got the J shift right and not the push button 4hi?
  17. Aug 16, 2023 at 9:18 PM
    eon_blue
    Azusa, CA
    Dex thinks he's one of the cats now
    Sperrunner, 01x4, Wulf and 5 others like this.
  18. Aug 16, 2023 at 10:02 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    I'll have a 4.56 rear open diff available in a few months. That would be perfect with 33s
    Das it mang likes this.
  19. Aug 16, 2023 at 10:04 PM
    Tour991
    James
    South Reno/Tahoe
    Fixed it.
    eon_blue[QUOTED] likes this.
  20. Aug 16, 2023 at 10:10 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I don't want to live on this planet anymore
