  1. Aug 22, 2023 at 2:54 PM
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    I think I can get him at 900
  2. Aug 22, 2023 at 2:54 PM
    Sebz13
    Shane
    Maui Hawaii
    If I pay 900 for that truck I can’t lose right ? My main concern is that frame horn. I’d need to put a bumper on it.
    Wulf likes this.
  3. Aug 22, 2023 at 2:58 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I'd do it, that's the first normal looking truck I've seen in Hawaii, basically a unicorn
    jubei and Wulf like this.
  4. Aug 22, 2023 at 3:02 PM
    Sebz13
    Shane
    Maui Hawaii
    I'm gonna buy a bumper and figure a way to mount it, then new tail lights and re list it for 5 grand.
    I need to pull the core support out a bit.
    amyracecar likes this.
  5. Aug 22, 2023 at 3:06 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    do you weld? You could cut the frame horn back to 95-97 length, cap it, and run that year of bumper just fine
    Tour991 likes this.
  6. Aug 22, 2023 at 3:07 PM
    Sebz13
    Shane
    Maui Hawaii
    tell me more about this, I forsure can have someone do this for me, I actually prefer the 95 front end.
  7. Aug 22, 2023 at 3:10 PM
    Wulf
    rock raisin
    98-00 are the only years that have the frame horns that stick out past the core support. The other years are capped flush with the face of the body mount and just have a captured nut on the end that the crash bar mounts to on both sides
  8. Aug 22, 2023 at 3:11 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Since when was your boy a hack :luvya:
    All part of the learning curve
    Unfortunately they'll require some work; my damn table is cutting a little wonky again with some beveling
    May have to disassemble a little and square it up again
  9. Aug 22, 2023 at 3:12 PM
    Speedytech7
    Is the table itself leveled well?
    Kwikvette[QUOTED] likes this.
  10. Aug 22, 2023 at 3:14 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    It's probably not completely level at the moment, but being out of square (deflection comes into play since the gantry tube hangs over the table) is more likely the culprit
    Y axis is completely square but I never was thorough about my X axis and it shows as most pieces are beveled in the same general area
  11. Aug 22, 2023 at 3:15 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    Oh man I forgot about your pet. Let's not let Monica see it this weekend.
  12. Aug 22, 2023 at 3:16 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Nothing a belt sander can't take care of as long as I'm steady in knocking it down flat
  13. Aug 22, 2023 at 3:16 PM
    Wulf
    rock raisin
  14. Aug 22, 2023 at 3:17 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    That's great to hear! Makes flying much more enjoyable. Once you learn the autopilot setups it helps a ton too. Some planes take quite a bit of learning the systems just to get them up and running which I enjoy. The A310 is a bear but pretty much the only jet liner I fly because of it.
  15. Aug 22, 2023 at 3:17 PM
    Speedytech7
    I helped align a whole bunch of cncs when I worked at the machine shop and it's pretty critical you get them level in the space they stay in because otherwise they can be out of square or ill supported and they'll gradually sag to out of square even if they're not immediately.
  16. Aug 22, 2023 at 3:17 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I sold him some years back
    I only have one and no one even notices her; in fact plenty of people don't even see her when they visit :rofl:
    Tour991[QUOTED] likes this.
  17. Aug 22, 2023 at 3:20 PM
    Sebz13
    Shane
    Maui Hawaii
  18. Aug 22, 2023 at 3:20 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I bet those tables were much better supported too
    Yeah my table needs bars between the legs at the bottom but you're right, definitely have to be on level ground
  19. Aug 22, 2023 at 3:23 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    that's 4 more than me
    also need to up the compression on your pistons and make a ground effects kit
    and make it a manual
    Abeyancer[QUOTED] likes this.
  20. Aug 22, 2023 at 3:24 PM
    Wulf
    rock raisin
    lose weight :luvya:
    Abeyancer[QUOTED] and Kwikvette like this.
