  1. Aug 31, 2023 at 7:55 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    amyracecar, Tour991 and 01x4 like this.
  2. Aug 31, 2023 at 8:30 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Oregon smoke is gettin us
    amyracecar likes this.
  3. Aug 31, 2023 at 9:08 AM
    Wulf
    rock raisin
    @Speedytech7 @treyus30
    Didn't want to shit up the standalone ECU thread -- is there a budget friendly standalone wideband sensor + gauge y'all recommend?
  4. Aug 31, 2023 at 9:09 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I think the AEM UEGO is still the best all in one gauge solution for AFR only. The innovate ones are more fragile it seems and often end up broken
    eon_blue likes this.
  5. Aug 31, 2023 at 9:10 AM
    eon_blue
    Azusa, CA
    Wulf[QUOTED] likes this.
  6. Aug 31, 2023 at 9:11 AM
    Wulf
    rock raisin
    word, that was the one I was considering after looking at the $90 eBay ones.
    I can't leave well enough alone and want to dial in my tuning on propane to squeeze every anemic hrspr I can out of the ol 22R lol
  7. Aug 31, 2023 at 9:12 AM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    was trying to find the annoying russian channel that does stupid shit to cars that did a bunch of mini turbos - one per cylinder, but turns out this is a common thing on youtube lol
    Kwikvette[QUOTED] likes this.
  8. Aug 31, 2023 at 9:12 AM
    eon_blue
    Azusa, CA
    every time I get in the Tacoma I get a chuckle because the AEM gauge reads "P00" when it starts up
  9. Aug 31, 2023 at 9:13 AM
    Speedytech7
    Propane has a stoich of 15.5 so shouldn't be uber hard to dial in
  10. Aug 31, 2023 at 9:13 AM
    Wulf
    rock raisin
    eon_blue[QUOTED] likes this.
  11. Aug 31, 2023 at 9:14 AM
    treyus30
    Trey
    Mesa / AJ, AZ
    Any name brand one, ya (I swore off Innovate Motorsports though). The genuine Bosch sensors are like $60-$80 by themselves if that tells you anything
  12. Aug 31, 2023 at 9:15 AM
    Wulf
    rock raisin
    yeaaa
    plus there's only a handful of things I can adjust on the propane setup. Idle mix, WOT mix, timing...
    I just can't seem to strike a good balance between power and economy by drive tuning it blindly lol
    Running Board Man likes this.
  13. Aug 31, 2023 at 9:18 AM
    Speedytech7
    Yeah it's tough with propane because it gives almost no smell cues or color to the exhaust. Shoot for like a 14.1ish at WOT with higher RPM... you can lean it if you have no ping or heat issues. Idle anywhere from 15.5 to 16.6, whatever in that range makes it happiest. Make sure you have no exhaust leaks before the sensor, sensors only measure air... so adding extra air is gonna be a bad time
  14. Aug 31, 2023 at 9:22 AM
    treyus30
    Trey
    Mesa / AJ, AZ
    Is it just me or do the cold sides look really small for a compound setup?
  15. Aug 31, 2023 at 9:25 AM
    Speedytech7
    Maybe a little but might be right for a stoker 3.2 or whatever that 2J is supposed to be, the split in sizes grows as you decrease effective range and increase maximum horsepower.
  16. Aug 31, 2023 at 9:32 AM
    eon_blue
    Azusa, CA
    Wulf likes this.
  17. Aug 31, 2023 at 10:02 AM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
  18. Aug 31, 2023 at 10:03 AM
    eon_blue
    Azusa, CA
    jubei and Tour991 like this.
  19. Aug 31, 2023 at 10:08 AM
    amyracecar
    amyracecar suck it up buttercup
    Virginia Applejack
    SouthEast USA
    2013 AC V6 MT OR Spruce/Mica
    Guessin' its not the good kind
    :rasta:
    Wulf likes this.
  20. Aug 31, 2023 at 10:30 AM
    Wulf
    rock raisin
    thanks, I appreciate the tips. The tuning instructions online are basically idle out mixture til it runs roughly then add a turn back in. WOT is just seat of the pants tuning lol
    I am building a lot of heat in the exhaust when I advance the timing to the point I'm happy with the torque so the extra data point will be a big help
