  1. Aug 31, 2023 at 7:57 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I think it was that or stop selling superchargers entirely for the first gen... Which means they still sell enough. But they were having trouble getting the old mp62 rotor cores from eaton anymore and I guess the tooling had also worn out for the second gen case. So it was the perfect storm for moving to a more available rotor pack.
  2. Aug 31, 2023 at 8:09 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Oooook those red skies look fucking killer
    You were playing in real-time with said weather?
  3. Aug 31, 2023 at 8:13 PM
    eon_blue
    Azusa, CA
    . Walking Dex and just saw the biggest meteor I've ever seen fly across the sky, that was nuts. Bright neon green then turned orange when it flamed out, that was awesome
  4. Aug 31, 2023 at 8:14 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    Yeppers. I tend to play that way most of the time.
    Kwikvette[QUOTED] likes this.
  5. Aug 31, 2023 at 8:26 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Speaking of Flight Sim, @eon_blue you're welcome to buy as many planes as you want on my account :burp:
    Just need to put your card info first
  6. Aug 31, 2023 at 8:27 PM
    eon_blue
    Azusa, CA
    How much for an SR71
  7. Aug 31, 2023 at 8:34 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Apparently it's being developed for the game still
  8. Aug 31, 2023 at 8:36 PM
    eon_blue
    Azusa, CA
    Laaaame...I hope they build in a feature to let you eject at Mach 3
  9. Aug 31, 2023 at 8:45 PM
    Wulf
    rock raisin
    What do you see on your phone
  10. Aug 31, 2023 at 8:47 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @m3bassman
    Left LFMN 530 in the morning
    City is nicely lit up below
  11. Aug 31, 2023 at 8:48 PM
    eon_blue
    Azusa, CA
    Is it turned on
    Speedytech7[OP] likes this.
  12. Aug 31, 2023 at 8:53 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @eon_blue
    Where people really go all out is they buy plug and play sim instrument panels or even separate displays to display all your info versus just seeing it on-screen
    Whether you click something with your mouse, program it to a peripheral, or clone it on a panel, practically everything can be manually operated with the exception of munitions
    This is just me hovering my mouse over the many different items you can interact with (or program separately)
    I'm often flying the Cessna 172
    eon_blue likes this.
  13. Aug 31, 2023 at 8:57 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Even the interior flood light :anonymous:
  14. Aug 31, 2023 at 9:05 PM
    m3bassman
    Green truck
    Turn north and find LFPS ;)
    You can turn off the hud in the cockpit...all the info is already right in front of you. There's a lot the MFD/PFD can do as well. Below you can seei have the inset close range map overlaid on the synthetic vision, wind indicator next to it. I also have weather in the C208 leaving Eugene on the way to Bandon. I also have the legen in the bottom right to gauge elevations better. Play with the softkeys and you can set it up pretty cool. I think the settings will hold between flights, at least it appears to for me.
    Some planes have more functional buttons than others. A lot of the aftermarket planes have more, like the Kodiak i mention before, you even can flip all the circuit breakers. Makes it realistic if you put Failures on mid flight. I would like there to be an option for random failures, currently you pick what fails in what time frame which is not really as much fun. Random failures would really be a challenge to address and work through.
  15. Aug 31, 2023 at 9:34 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I had already extended my flight lol got pretty far and still had plenty of fuel left
    Sun wants to peak out over the horizon
    Surprised about the no random failures; that'd make shit so much more realistic
  16. Aug 31, 2023 at 9:34 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    :rolleyes: Kinda reminds me of this one
    unstpible likes this.
  17. Aug 31, 2023 at 9:45 PM
    Speedytech7
  18. Aug 31, 2023 at 9:46 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @Wulf has entered the chat
  19. Aug 31, 2023 at 9:47 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Don't you people usually have the font like really big anyway?
  20. Aug 31, 2023 at 9:49 PM
    Wulf
    rock raisin
    scroll all the way down ( and maybe over) and try selecting this Screenshot_20230831-224811.png
