  1. Sep 12, 2023 at 12:02 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    m3bassman likes this.
  2. Sep 12, 2023 at 12:02 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Well I'm eager to see what you come up with.
    Bandido[QUOTED] likes this.
  3. Sep 12, 2023 at 12:06 PM
    Speedytech7
    Can grind a flat spot in the bolt head to clear a diff drop, that's how my buddys truck is
  4. Sep 12, 2023 at 12:14 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Yep. I think people get into issues when spending too much time trying to avoid pulling the oil cooler and then dealing with the coolant hoses. It's one of those right-of-passage maintenance items like doing a timing belt, water pump, and related stuff.
    Ozark_RegCab[QUOTED] likes this.
  5. Sep 12, 2023 at 12:15 PM
    Ozark_RegCab
    Ozark_RegCab Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    I might just wanna take that thing out since it’s kinda pointless anyway
  6. Sep 12, 2023 at 12:18 PM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    apparently the RZR Pro R shocks use the same valve.... and also have ~3 IBP and the front is ~12" travel, the rear is 16" travel!
    I might just be keeping my eyes peeled for those instead
  7. Sep 12, 2023 at 12:19 PM
    Speedytech7
    Whats the shock dia and shaft dia on those?
  8. Sep 12, 2023 at 12:21 PM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    upload_2023-9-12_15-20-54.png I should give up on my build and just by a sxs
  9. Sep 12, 2023 at 12:22 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    Now I like that! Way for functions than mine
    Kwikvette[QUOTED] likes this.
  10. Sep 12, 2023 at 12:32 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    It's going to take me awhile, but the software is what makes this thing truly shine; it's not for the faint of heart apparently when programming.
    You can program over 128 physical buttons, by creating logical buttons which are anything from button presses, to toggles, to set switches, and more. You can even change an axis to a step and vice versa. The clear buttons also light up different colors to either match a cockpit, or even change to a different color when activating/disactivating something (or an in-game alert goes off or what have you).
    I'll have to set it up tonight when I have all the time in the world to kill :laughing:
    It's lighter than the Warthog, but that's because it adds unnecessary weight to the base to add a sense false of quality. But the Virpil's button layout makes way more sense.
  11. Sep 12, 2023 at 12:35 PM
    Speedytech7
    Pretty impressive, didn't expect a 3.0
  12. Sep 12, 2023 at 12:53 PM
    eon_blue
    Azusa, CA
    My diff drop kit only barely blocked the long steering rack bolt, I just had to take a grinder to the flange on the bolt and grind a tiny corner off it for it to clear the front diff. Took just a minute. Doesn't compromise the bolt at all.
    Unless your diff drop is bigger than 1" or whatever the standard one is
    edit - aka this
  13. Sep 12, 2023 at 12:56 PM
    eon_blue
    Azusa, CA
    that would be the wise thing to do. Did you save the old diff mount bolts? The ones the kit comes with will be too long without the diff drop washers on them
  14. Sep 12, 2023 at 12:56 PM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    I think the valve thing is different than the ford spec one tho.... maybe I will continue to wait for a set of bronco rears to show up on ebay
    they are $5400+ shipping direct from Ford lol
  15. Sep 12, 2023 at 1:01 PM
    CS_AR
    @Ozark_RegCab I ordered a set of dual rubber brake hoses for ABS VSC on the 02 model on Sunday from McGeorge. They shipped today. I should get them on Thursday.
    Ozark_RegCab likes this.
  16. Sep 12, 2023 at 1:01 PM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    They must be somewhere in all the junk the PO gave me lol
  17. Sep 12, 2023 at 1:12 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    No one, I jus want em
  18. Sep 12, 2023 at 1:30 PM
    01x4
    01x4 I know what I'm doing?
    Coast of Southeastern VA
    A company even makes portals for the Jimny. Weird way to spend money.
  19. Sep 12, 2023 at 1:31 PM
    eon_blue
    Azusa, CA
    people spending crazy money on these things dayum
  20. Sep 12, 2023 at 1:42 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    BRO YOU ASSUME THEY DON'T OWN THEIR OWN F-16? :mad:
