  1. Sep 19, 2023 at 9:12 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    If I score a cheap 2' x 2' 1/4" I may try this file out
  2. Sep 19, 2023 at 10:26 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
  3. Sep 19, 2023 at 10:34 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  4. Sep 19, 2023 at 10:43 PM
    m3bassman
    Green truck
    Like butter. I swung a bit wide on the approach and drifted off center line on touch down but overall it was a good one.
    All I was really messing with is the range of the screen to zoom in and adjusting the heading and decent rate on the AP. From there it's throttles and flaps for speed control.
    Kwikvette[QUOTED] likes this.
  5. Sep 19, 2023 at 10:47 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    My thorleys on the 01 weren’t terrible to install.
    But honestly I’m leaning doing custom headers for it when the time comes. The old thorleys can go on my 95 I guess if I go that route. We’ll see
  6. Sep 19, 2023 at 10:58 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    My complaint about the thorleys are that they block access to the engine mount and bellhousing bolts. Hell one of the starter bolts can't even be fully removed with them installed.
    Digiratus likes this.
  7. Sep 19, 2023 at 11:02 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    m3bassman[QUOTED] and Kwikvette like this.
  8. Sep 19, 2023 at 11:08 PM
    Empty_Lord
    Dan
    Honestly I really wish I could find a set of the Edelbrock headers… I would love to see how they fit. Since the crossover went under the transmission
  9. Sep 19, 2023 at 11:17 PM
    Empty_Lord
    Dan
    upload_2023-9-20_1-17-25.jpgliterally the only thing i can find on the edelbrocks.
    unstpible likes this.
  10. Sep 19, 2023 at 11:19 PM
    Speedytech7
    That must've been one tight fit around the driveshaft and steering shaft. Also wouldn't you lose clearance on that cross under? I dunno, were these for prerunners only?
  11. Sep 19, 2023 at 11:22 PM
    Empty_Lord
    Dan
    i found instructions. 4x4 or 2wd. it had to be close.. but i cannot find photos of the kit installed on anything.. i dont care about the crossover so much. im genuinely curious how much room that collector had by the steering shaft.. i'd love to run a proper dual bank setup when the 01 goes haltech..
    Bandido likes this.
  12. Sep 19, 2023 at 11:24 PM
    Empty_Lord
    Dan
  13. Sep 19, 2023 at 11:25 PM
    Speedytech7
    Could be a guinea pig and see if the Aussie Prado 3.4 headers fit. Looks similar to the Edelbrock.... but you never know they may have not planned around a steering shaft, but they had to plan around the driveshaft at least. Only so many ways to skin a cat
    https://www.ebay.com/itm/2853074309...AT15Wc-R3e&var=&widget_ver=artemis&media=COPY
  14. Sep 19, 2023 at 11:27 PM
    Empty_Lord
    Dan
    eh its a project for later. i will probably end up going custom on them IF i dont just toss the thorleys on
    those prado ones look eerily close to the edelbrocks though
  15. Sep 19, 2023 at 11:33 PM
    m3bassman
    Green truck
    Thanks. That was just a hop and a skip north of Golden BC. ended the route in Invermere which was fun. I have a fun approach and landing that I will share tomorrow that i think is fun to watch. I should do some recorded landings at some places you and I have been to before. I am sure you will recognize some of the places.
  16. Sep 20, 2023 at 12:15 AM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Starfield high key pissing me off now with its lack of adequate tutorials...
    I'm what? 6 hours in (cuz I've been playing casual) and two of the primary quest lines I've gotten to the waypoints with no idea how to progress?
    I'm all for throwing a gamer in the deep end, but ffs if you have a storyline at least put the controls on the screen for how to progress
  17. Sep 20, 2023 at 5:56 AM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    Have you replaced the starter on your Tundra yet?
  18. Sep 20, 2023 at 5:59 AM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    I really need to spend more effort setting up my table and tuning my feed/amps to the material....
    I've been cutting everything at 30fpm and 30amps lol
  19. Sep 20, 2023 at 6:26 AM
    Speedytech7
  20. Sep 20, 2023 at 6:30 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    YOUR SOUND CARD IS WORKING PERFECTLY.
    good ole Warcraft II
