  1. Sep 29, 2023 at 11:00 AM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    Looks like any other modern DOHC setup. If my dumbass can figure it out in my garage, shouldn't be too painful for a mechanic that's got all the right tools and has been trained on how to repair those engines. That's not to say the DOHC motors look terrifyingly complicated when you open them up, they absolutely do, but as long as you're methodical it's not bad.
    Ozark_RegCab[QUOTED] likes this.
  2. Sep 29, 2023 at 11:20 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
  3. Sep 29, 2023 at 11:22 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Front chain is still way easier than the dumb audi rear chains or the early ford front and back chains. I'd much rather work on the Ecoboost than either of those.
    Ozark_RegCab likes this.
  4. Sep 29, 2023 at 11:33 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
  5. Sep 29, 2023 at 11:34 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Hey lil dude
    Wulf and CS_AR like this.
  6. Sep 29, 2023 at 11:45 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Real nice
    jubei, Wulf and CS_AR like this.
  7. Sep 29, 2023 at 12:17 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    It is brand new literally
  8. Sep 29, 2023 at 12:18 PM
    Empty_Lord
    Dan
  9. Sep 29, 2023 at 12:34 PM
    Ozark_RegCab
    Ozark_RegCab Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    CS_AR[QUOTED] likes this.
  10. Sep 29, 2023 at 12:34 PM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    Dang, you better park that beauty in winter lol
    Empty_Lord[QUOTED] likes this.
  11. Sep 29, 2023 at 12:49 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Laser vs plasma, it gets close
  12. Sep 29, 2023 at 12:52 PM
    eon_blue
    Azusa, CA
  13. Sep 29, 2023 at 12:57 PM
    m3bassman
    Green truck
    Seems most ecoboost need worked on regularly though. Cam phasers, oil pump failures, and carbon buildup seem all too common in them. That said, the audi 4.2 timing chain seems like a nightmare but I bet it's not so bad since the work is down outside the car.
    CS_AR likes this.
  14. Sep 29, 2023 at 1:02 PM
    Empty_Lord
    Dan
    I have a lifted corolla and an Avalon for winter lol. All the trucks are parked for it
  15. Sep 29, 2023 at 1:05 PM
    Speedytech7
    The part I like least about the Ecoboost is the damn chain drive water pump, cause when it leaks (and they all do) it dumps the fucking coolant into the oil. Cam phasers suck but are doable, expensive tho. High power coyote builds are just locking the things out since Ford can't figure out how to make their design not suck.
  16. Sep 29, 2023 at 1:13 PM
    m3bassman
    Green truck
    Cam phasers are something I can relate to. I think the set for me would be $2500 for parts alone. My understanding is the 1.0L ecoboost use a wet belt oil pump, the belt deteriorates, plugs the pickup tube and starves the engine of oil. Fun stuff!
  17. Sep 29, 2023 at 1:14 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
  18. Sep 29, 2023 at 1:19 PM
    Speedytech7
    They use 2 wet belts haha. They say the belt doesn't deteriorate if you use their approved oil for it... the lawsuits determine that was a lie. Wet timing and wet oil pump belts aren't wise. Toyota, Nissan, and Kia/Hyundai got the cam phaser design right. Honda sorta did but people forget they have it because they also have VTEC which is variable valve lift so high power guys usually lock out the vvt and leave VTEC. BMW in a rare stroke of reliability managed to nail out vvt pretty well lately, just took 22 years, but they also started 10 years before everyone else with it too.
    CS_AR and m3bassman[QUOTED] like this.
  19. Sep 29, 2023 at 1:21 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    cynicalrider[QUOTED] likes this.
  20. Sep 29, 2023 at 1:26 PM
    CS_AR
    I don't think so. I think the cutoff was for t-shirts in the swag pack. Walk ins registration is available at the park.
