  1. Oct 16, 2023 at 4:30 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Thanks!
    I welded on super thick (1") welding tables professionally but never owned anyhing even half as nice myself
    This was me finally making a table from that laser cut table top
  2. Oct 16, 2023 at 4:31 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I think you'll be fine with the 250° water temp given that it's all aluminum construction with MLS head gaskets. It's very unlikely you did any damage. To give you an idea a modern Mercedes or BMW runs at 230° all the time and around 240 on the economy programming for a BMW. Touching 250 for a moment isn't going to be a problem I don't think
  3. Oct 16, 2023 at 4:38 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    It's starting to get into the danger zone but not deep into. The question is though, and maybe you already know this, is where that reading takes place. Remember that the fluid wasn't flowing so in the block I wonder if it could've been even hotter. I think if I did anything it's the head gasket and if that is the case, I can do that and I already have a machine shop. I was already there when I had the cams out. Just a lot of tedious work.
    Kwikvette likes this.
  4. Oct 16, 2023 at 4:38 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Fuck
    I'm not familiar with that engine so here just hoping for the best:fingerscrossed:
  5. Oct 16, 2023 at 4:40 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    GM does/did this but specifically for power while meeting emissions; they don't leave much headroom after that though
    Bimmer and Mercedes do that for the same reason? Or are you saying they can just handle much more heat in general...
  6. Oct 16, 2023 at 4:41 PM
    Speedytech7
    The temp sensors are almost always in the heads and near to the water outlet. Heads get the hottest, in fact on drag racing engines to make smaller cooling systems to cut weight they'll only cool heads because the oil can cool the block fine. I doubt you did any real damage.
  7. Oct 16, 2023 at 4:43 PM
    Speedytech7
    Bimmer and Mercedes do it for emissions. In fact if you really romp on a BMW it'll alter the thermostat set point lower (190 or so) to give you greater performance headroom and then when you start driving casually again it'll raise the temperature back up to 230 for economy. I had the tuner on my 135 set to keep it in the 190° range all the time for engine longevity. It's not so much the hard parts that wear with the higher engine temp it's all the rubber stuff that wears out exponentially faster with hotter oil touching it.
    Kwikvette[QUOTED] likes this.
  8. Oct 16, 2023 at 5:01 PM
    m3bassman
    Green truck
    Aluminum block, aluminum heads, magnesium intake, it kinda an exotic V8 compared to the American stuff. When you dig I to it's details it's an absolute masterpiece. When EV's take over I think it'll have a very loyal cult following as it's basically the last NA V8 that made 500hp.
    I hope so. I have seen oil temps hit 240s when really driving the piss out of it so it's not that far out of the envelope. Full disclosure is, I didn't even hear it fail. I got a big red warning on the LCD screen about the battery. I was like FUCK. I knew right away it was the belt. I then tested the steering to confirm it, sure enough that was gone too. My thinking was I just need to milk it to the next exit and I can do that without voltage or steering so I went to pick up the pace a bit and it had no power, engine and trans acted real odd and that's when I peeped the temp gauge fully in the red and the readout was 253. So idk I think the way the car acted there is what's messing with me. Felt pretty normal and idled fine when we moved it on and off the trailer. But it was hot enough it emptied the expansion tank, but I didn't leave any coolant under where I broke down. So it's either in the trays or it went somewhere. It is easy to sit here and speculate on all the fine details, I mean shit I did it for 11hrs yesterday but I'm hopeful it's an easy fix and I'm all good. Looks like $65 for a pulley and belt and I hope that's it. The power steering is very noisy but if I can push that off longer, the better. (Both C63 I have had have had PS pump issues oddly).
  9. Oct 16, 2023 at 5:05 PM
    Speedytech7
    It's new enough to have had engine protection strategies in the computer too. It probably started bringing down your rev limit without you even noticing and use the trans to trap you in lower gears so you don't push it. Slowly richening up the mixture to cool it down... Etc If it didn't blow big puffs of white smoke when you started it up later in the day it's probably just fine and it needs an oil change and a fresh belt system. Oil temp sounds pretty normal these cars all have electronic thermostats to control when there's flow through the cooler. It is probably keeping it warm unless you were going hard on it because you get better economy that way.
  10. Oct 16, 2023 at 5:12 PM
    Speedytech7
    Better watch out for Nivlac on YouTube haha... You just described the Cadillac Northstar and that man is determined to make power out of those things haha
  11. Oct 16, 2023 at 5:19 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Even Cadillac techs and service advisors suggest replacing a Northstar versus repairing it if their head gasket goes :bananadead:
  12. Oct 16, 2023 at 5:20 PM
    m3bassman
    Green truck
    Thanks Zane, your comments certainly help bring down my blood pressure over the whole thing. I hope your right. German engineering is a blessing and a curse, but more often than not they do seem to think of everything and they do their homework with FMEAs.
    There is no Northstar making 500hp from the factory lol and yes I am well aware of some parallels between the two motors :laugh:
    01x4 likes this.
  13. Oct 16, 2023 at 5:26 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Sperrunner and treyus30 like this.
  14. Oct 16, 2023 at 5:44 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
  15. Oct 16, 2023 at 5:45 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You know @Wulf would scoop that lil thing up and take it home right now :rofl:
    Speedytech7[OP] likes this.
  16. Oct 16, 2023 at 5:48 PM
    JKO1998
    Utah
    Didn't get the one we wanted but she's fine
  17. Oct 16, 2023 at 5:51 PM
    Speedytech7
    Very cute dog... But we need to talk about that baseboard moulding and how the floor meets the cabinets.
    jubei and Kwikvette like this.
  18. Oct 16, 2023 at 5:54 PM
    JKO1998
    Utah
    That's PO shit and on the project list
  19. Oct 16, 2023 at 6:00 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    she is waaaay too adorable :boom:
  20. Oct 16, 2023 at 6:02 PM
    JKO1998
    Utah
    Takes us to 4 dogs rn
