  1. Oct 18, 2023 at 6:35 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    @Empty_Lord do you know if a r150f from a 2000 Tacoma will fit on a 94 truck with a 3.0?
  2. Oct 18, 2023 at 6:37 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    It is but usually shoved under the wifi card or on the back side of the mobo, usually one 1
  3. Oct 18, 2023 at 6:48 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    How do you potty train a dog
  4. Oct 18, 2023 at 6:49 PM
    Speedytech7
    Pee pads, redirection to them, and positive reinforcement when they're used. Though if that little bugger is 8 weeks older that training should have started 2-3 weeks ago
    treyus30 likes this.
  5. Oct 18, 2023 at 6:54 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Constant walks, especially before and after feedings as that's usually when they'll go
    A small treat each time they go to the bathroom while outside, to reinforce what they're doing is a good thing
    If you catch them having an accident in the house, immediately take them outside and if they go outside, reward as needed
  6. Oct 18, 2023 at 6:54 PM
    JKO1998
    Utah
    She's 6 weeks
    she doesn't pee at night or anything, yet. Pees everytime we take her out, but she just let enough shit out of her I thought it was my kid
  7. Oct 18, 2023 at 7:00 PM
    Speedytech7
    She's still a lil young to be away from momma. Might ask the breeder what she should be eating
    jubei and Kwikvette like this.
  8. Oct 18, 2023 at 7:01 PM
    JKO1998
    Utah
    Solid poops, so I don't think her stomachs messed up.
  9. Oct 18, 2023 at 7:30 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Not just catholic. Im a confirmed catholic.
  10. Oct 18, 2023 at 7:32 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    You guys cut your hair?
  11. Oct 18, 2023 at 7:33 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    We know one thing you don't cut :luvya:
  12. Oct 18, 2023 at 7:39 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I be cutting lines and chopin blades
  13. Oct 18, 2023 at 7:43 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    No. The pickups have the clutch fork on the passenger side and the tcase drops different.
  14. Oct 18, 2023 at 7:45 PM
    Speedytech7
    Does fit though and work just fine if you're okay with using the 3.0 clutch and coming up with a longer clutch hose
  15. Oct 18, 2023 at 7:49 PM
    m3bassman
    Green truck
    Let her out often, like every hour. When she potties outside reward her either with treat or praise. Tell her sternly no when she goes in the house. If she ever approaches the back door let her out, even if she is not needing to potty. It teaches them that going to the door is how the get to go outside. They figure out out pretty quick but the key is to be consistent. Also know that they do have less control on their bladders so it may take longer to get that under control. But that also means that as they learn it all that their signs be be subtle. Like we had a couple times where Znüni walked to the door then turned around and peed on the floor. Like she was kinda putting the pieces together but we weren't fast enough to recognize what she was doing. They figure it out quick enough..
    Personal opinion is pee pads are not helpful. I want my dogs to know that they cannot potty indoors. Pee pads give them that luxury and I think you then have to train that out of them eventually.
  16. Oct 18, 2023 at 7:50 PM
    m3bassman
    Green truck
    Or you would need the 3.0 bellhousing and I believe a tcase adapter as those are passenger drops. You would also need to open up the trans and fit a different input shaft as the Tacoma ones are longer than the pickup ones. I learned enough when researching for my LS swap, the R150F for Tacomas vs the R150F for the pickups are far enough apart in differences that they are not interchangeable. Or the amount of work to make them so, is cost prohibitive for what you're getting out of it. Hence why I'm going TKX for a trans instead of making an old R150F work
    Tour991 likes this.
  17. Oct 18, 2023 at 7:53 PM
    Speedytech7
    Yeah have to use the 3.0 bellhousing with the 3.0 clutch, keeps ya from having to swap input shafts. Transfer case will need an adapter tho. 2wd is direct swap
    Tour991 likes this.
  18. Oct 18, 2023 at 7:55 PM
    Neal4x4
    Neal4x4 Well-Known Member
    Southern California
    Truck.
    thanks that’s what I was looking for.
    JKO1998[QUOTED] likes this.
  19. Oct 18, 2023 at 7:56 PM
    m3bassman
    Green truck
    I don't think that's true. The 3.0 bellhousing won't compensate for the longer input shaft. The 3.4 bellhousing does, but like we said, clutch fork is on the wrong side with the 3.4 bellhousing.unless I'm mistaken the input shaft will bottom out before the bellhousing mates to the engine block, regardless of the clutch used.
  20. Oct 18, 2023 at 7:57 PM
    Speedytech7
    Oh yeah you're right, I though he was going pickup to taco not vice versa.
