  1. Jul 2, 2018 at 3:42 PM
    #4661
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    These rounds flatten on impacts. So the polymer goes through the skin then the lead expands like a hollow point.https://youtu.be/tkjQv0CS0Y8https://youtu.be/3hqCwVG2yx8
  2. Jul 2, 2018 at 3:53 PM
    #4662
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    Tack weld on the slider joint of the steering column, which is meant to collapse in the event of a crash, so tread carefully, and at your own risk. But, It takes all the slop out of the column. If you reach up and grab the steering column from below, and can move the steering wheel (unlocked), you may want to do this mod. Symptoms are that when on the highway, you are constantly correcting, with just a slight movement of the wheel to keep on a straight line. Most folks tack weld the joint, in the theory that the tacks would break first in a serious crash. Others have drilled and put in roll pins. It would also be feasible to use a press take the slop out.
    Area51Runner likes this.
  3. Jul 2, 2018 at 3:55 PM
    #4663
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Man sounds like i need this. I have to constantly correct to go in a strait line.
  4. Jul 2, 2018 at 3:57 PM
    #4664
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    I know I could benefit from this as well but no way I'd ever attempt it. Even if I found someone to do the mod, would still bug the heck out of me whether it was safe or not. (OCD thing) o_O
  5. Jul 2, 2018 at 3:59 PM
    #4665
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Just realize the I have the patch from your avatar on my headliner in the cruiser
    Area51Runner[QUOTED] likes this.
  6. Jul 2, 2018 at 3:59 PM
    #4666
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Your married right? Are you sure that was a safe decision?
    Think of how nice it would be to drive after lol. Kinda tempted to do it rn because my welder is here at the house. But im to tired to go do it lol
  7. Jul 2, 2018 at 4:05 PM
    #4667
    Seagull233
    Tom
    Upstate New York
    2004 DC 4x4 V6
    Here is the write-up that I used, read the early part, to get an idea of what they are doing, but you need to get down to post 42, as the OP was taking a whole bunch of stuff loose that doesn't need to be. Basically, you pull the clam shell around the column, unhook tilt springs, remove two allen bolts, and loosen at the floor board, and pull it out, tack it, and "assembly is the reverse".
    Sperrunner[QUOTED] likes this.
  8. Jul 2, 2018 at 4:10 PM
    #4668
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    What write up?
  9. Jul 2, 2018 at 4:10 PM
    #4669
    Seagull233
    Tom
    Upstate New York
    2004 DC 4x4 V6
    That's why I mentioned the press. A machinist on here and I were talking about the possibility of using the press, and he thought that would work very well, if you used some sort of tool (he had a name for it) that created a dimple on each of the flats. This is a hexagon shaft within a shaft.
  10. Jul 2, 2018 at 4:11 PM
    #4670
    Seagull233
    Tom
    Upstate New York
    2004 DC 4x4 V6
    DOHHH!!!
  11. Jul 2, 2018 at 4:17 PM
    #4671
    Area51Runner
    Yeah, I love that patch. Those taco patches he does are awesome as well. He still has Ivan tacos available. https://orezonadesigns.bigcartel.com/
    Yep, married with a 3yo. truthfully, steering isn't that bad - I have certainly read some posts which describe it and sounds like a death ride in comparison. If you do decide to do the mod, lots of pictures and results please. :thumbsup:
  12. Jul 2, 2018 at 4:24 PM
    #4672
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I just might, my steering is bad
  13. Jul 2, 2018 at 4:27 PM
    #4673
    Seagull233
    Tom
    Upstate New York
    2004 DC 4x4 V6
    It takes one thing out of the equation. I did mine in under an hour. And I love the result!! No more wandering down the highway.
  14. Jul 2, 2018 at 4:31 PM
    #4674
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Yeah my truck just likes to wander down the road. The steering needs to be tightened up. Im sure that mod will help me alot, because Ive checked everything else and its all tight
  15. Jul 2, 2018 at 4:34 PM
    #4675
    HansWorldTravels
    HansWorldTravels Well-Known Member
    Hans
    Colorado/NY/Germany
    '03 Toyota Tacoma 3.4L Ext Cab TRD
    Roll & Ram repairs on '95 Front end crash repairs on '03
    @Speedytech7 habe ich leztzes Jahr in NRW (Bonn) wohnt. In the “federal village”. Meine freundin kommt Mitwoch aus Deutschland.
  16. Jul 2, 2018 at 4:55 PM
    #4676
    Speedytech7
    Oh, okay, ich kann nicht viel Deutsch. Aber Familie in Dunzweiler, einem kleinen Dorf nördlich von Homburg
  17. Jul 2, 2018 at 4:58 PM
    #4677
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Stop now both of you.
  18. Jul 2, 2018 at 4:59 PM
    #4678
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Oh yeah...
    due possono giocare a questo gioco
  19. Jul 2, 2018 at 5:00 PM
    #4679
    Speedytech7
    I don't know any Italian, well I know some pasta and cheese but that's about it
  20. Jul 2, 2018 at 5:00 PM
    #4680
    Speedytech7
    eBay has a 20% off code right now if you happen to find one on there.
