  1. Oct 27, 2018 at 9:22 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    The guy made it seem like it was deep curb rash that would require machining the surface to get it out. I didn’t realize it was only paint transfer.
    Crodell6[QUOTED] likes this.
  2. Oct 27, 2018 at 9:30 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Me
    I’m OCD over little things like that.
  3. Oct 27, 2018 at 9:39 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
  4. Oct 27, 2018 at 10:24 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
  5. Oct 27, 2018 at 10:40 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Alloys, polished not chrome. 16x8 4.0" BS. I forget the model number but they don't make these anymore in 4.0" BS.
    They're not too shiny anymore & have dings & scratches. Perfect for painting black though. Was gonna post em on CL for $150, I only want $120 for them so not worth shipping. I might still have the center caps somewhere but they're ugly IMO. No tires on them.
  6. Oct 27, 2018 at 10:42 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Do you have the bar in the bed just to mount the a atene
  7. Oct 27, 2018 at 10:47 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    I got the Demello bed bar cause I wanted mount dust lights. But I stopped going to the desert with the CT guys & never ended up going LT.
    So yeah now the bed bar is only for the antenna which I have off most of the time anyway (quick disconnect). But at least it makes my truck look different. I haven't seen anyone else with it around here on a 1st gen.
    Sperrunner[QUOTED] likes this.
  8. Oct 27, 2018 at 10:51 AM
    JKO1998
    Utah
    I wish @Willbeck would provide and finish this up ;)
    https://www.tacomaworld.com/threads/3rd-brake-light-antenna-mount.530202/
  9. Oct 27, 2018 at 10:55 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Cool idea but I'd be concerned about the strength of the cab. Those 2 mounting studs aren't very big. The cab might buckle or flex with an antenna, especially if you hit something with the antenna?
    But I guess that 3rd brake light mount is intended for HAM & not CB.
  10. Oct 27, 2018 at 10:56 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    :thumbsup: front bumper aligned and not crooked
    zero4[QUOTED] and Sperrunner like this.
  11. Oct 27, 2018 at 10:58 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Lol. Maybe just a little if you look closely at it but yeah not noticeable or as bad as others I've seen.
    Area51Runner[QUOTED] likes this.
  12. Oct 27, 2018 at 10:58 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Does that drive you crazy when its noy strait?
    Even seen when the rear bumper is folded down
  13. Oct 27, 2018 at 10:59 AM
    JKO1998
    Utah
    I feel like it wouldn’t be any weaker than drilling a hole in the roof.
  14. Oct 27, 2018 at 11:03 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    That's not a good way to mount an antenna either unless it has a wide base & short thin antenna.
  15. Oct 27, 2018 at 11:05 AM
    JKO1998
    Utah
    I’ve never seen a problem with them either
  16. Oct 27, 2018 at 11:08 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    By just drilling a hole in sheet metal & mounting without a wide base? I've never seen it done that way. Maybe ok for just HAM antennas but I wouldn't do it. I guess that's what that 3rd brake light mount is for, not CB. I don't have HAM.
  17. Oct 27, 2018 at 11:11 AM
    JKO1998
    Utah
    It’s like a 3/4” hole, i don’t know how wide the part under the hole is.
    We use them for ham radios and long range gps
  18. Oct 27, 2018 at 11:12 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Do you have pics of them mounted in a hole drilled on the roof of a 1st gen?
  19. Oct 27, 2018 at 11:15 AM
    JKO1998
    Utah
    No, I’d imagine someone does though.
    Mine are currently mag mounted caue I’m poor.
    @Speedytech7 @m3bassman @Blackdawg @turbodb
    @any other radio dude.
    Do you or anyone you know have holes drilled in the roof of their trucks for antennas?
  20. Oct 27, 2018 at 11:19 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    I only know one person with a HAM radio & his antenna is mounted on the bed. I've never seen a CB antenna hole mounted on the roof. I've only seen mag mounts on the roof.
