  1. Oct 28, 2018 at 5:47 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    You sure they weren't already attached to pads? Mine were & most aftermarket pads these days do to.
  2. Oct 28, 2018 at 5:48 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    They had a metal backing plate, but nothing seperate like the OEM ones.
  3. Oct 28, 2018 at 5:50 PM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    dude that shit sucked. I would always try n keep my mouth shut, it was worse that way...
    Btw got the driveshaft @mechanicjon Hagen just stopped by. :thumbsup:
  4. Oct 28, 2018 at 5:51 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    If your braking system got air into it because of compressing the caliper piston without opening the bleeder valve you may have a leak somewhere, possibly the caliper seals. They say you shouldn't compress the piston without opening a bleeder to help prevent pushing dirt past the seals but you're still at risk even with opening a bleeder. Your seals may just be old & hard already.
  5. Oct 28, 2018 at 5:52 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Yeah that's the shim. I've only seen the seperate shims with OEM pads.
  6. Oct 28, 2018 at 5:55 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I never bled my brakes when I replaced pads or rotors. Only when air is introduced into the system, for example when you put new brake lines.
    Area51Runner[QUOTED] and zero4 like this.
  7. Oct 28, 2018 at 5:55 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    When I drove my truck off the lot, I had the dealer install the TRD pads up front. I was back within aacouple of weeks if I recall - pads had fractures in them. Whatever, had them install Toyota pads and refund the cost of the TRD pads.
    They tried to tell me the reason was because they were ceramic. I think the more likely explanation was I didn't know better and wasn't told that they needed to be broken in. Oh well.
    Glad I found the Akebono/Brembo combination. They have served me well and i will continue to use them.
    zero4 likes this.
  8. Oct 28, 2018 at 5:56 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Serious*
  9. Oct 28, 2018 at 5:56 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    The thing is though, I cracked the bleeder to assist in compressing one stubborn piston. It was off camber a bit and just needed the pressure behind it to be released. Somehow, someway when the bleeder was open, it sucked air in. The pedal is firm and the truck stops fine. The problem lies in the pedal hanging up a bit about halfway down the stroke when you work it while sitting in a parking lot. I dont think the issue is major, its just annyoing the piss outta me.
  10. Oct 28, 2018 at 6:02 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Sounds to me.like typical dealer or mechanic, put the blame on the customer or something about the part that's not logical.
    My only gripe with cermaic pads is they don't do well when cold or in cold climates. They need to heat up to bite really well. But I live in sunny hot SoCal desert weather, we don't have cold weather here. My pads will get up to temp quick once I leave my house as there's a big hill to go down.
    I certainly don't need ceramics pads but they last forever for me & make very little dust.
  11. Oct 28, 2018 at 6:08 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Oh that camber part you described is not right. Piston could be worn. Might want to check out that caliper, it may be bad. Yes air will enter into the bleeder when cracked, need to use a a catch can with a check valve like the ones they sell or just make one with a long tube with fluid at the bottom (no check valve needed) so air doesn't get sucked back in. Kind of like what Tyler posted earlier. Otherwise without a catch can, you'll need to bleed anytime you crack open the bleeder without a catch can
    Crodell6 likes this.
  12. Oct 28, 2018 at 6:23 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    @Speedytech7 This is the page for bleeding the master cylinder in the Haynes manual for my 92 pickup. Think this process would work on my '04? Dunno if this would affect the ABS.1028182120.jpg
  13. Oct 28, 2018 at 6:47 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    ABS makes everything a bit fuck because it can hold a huge airbubble and needs a special tool to turn it on so you can purge it too. I didn't know you had ABS, thats not fun.
  14. Oct 28, 2018 at 6:51 PM
    Speedytech7
    Well there's really only two things that cause this airbubbles and leaks, so you have one or the other. Leaks aren't always external
  15. Oct 28, 2018 at 6:51 PM
    Fkn_kyle
    Fkn_kyle Kyle Kagz
    Kyle
    Honolulu Hawaii
    2018 Cement Grey PRO
    Hi guys ! Just wondering my dad has a 04 taco 4x4 V6 , are the front wheel studs little shorter than the rear studs ? Just threw on some 1 1/2” spacers today
    Sorry if this is a dumb question
    Running Board Man likes this.
  16. Oct 28, 2018 at 6:51 PM
    Area51Runner
  17. Oct 28, 2018 at 6:51 PM
    Speedytech7
    I think they are, from what I remember they have different part numbers
  18. Oct 28, 2018 at 6:54 PM
    lucky13don
    lucky13don Well-Known Member
    Don
    Milton, fl
    R.I.P.04 tacoma prerunner, 04 sequoia 4x4
    Too many to list
    Check my stock still decent, not warped. So ran with those.
    Area51Runner[QUOTED] likes this.
  19. Oct 28, 2018 at 6:54 PM
    Area51Runner
    whoa guess us norcal taco hunters are fast!
    Crodell6[QUOTED] likes this.
  20. Oct 28, 2018 at 6:55 PM
    Area51Runner
    Rock it out bud! Ace that shit!
