  1. Jan 19, 2024 at 4:37 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    Maybe. Was a solid setup.
    35s would fit today, even lowered :anonymous: I never did get to try that but based on the geometry it would work. Would've looks wild.
  2. Jan 19, 2024 at 4:37 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Imagine owning a truck for over a year with shitty suspension you complain about and never doing anything about it :burp:
  3. Jan 19, 2024 at 4:37 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I've seen your truck when you'd wheel it, definitely a nice setup.
  4. Jan 19, 2024 at 4:38 PM
    m3bassman
    Green truck
    It lacked travel but it was capable, and most importantly, reliable. Outside of a failed alternator it was perfect.
  5. Jan 19, 2024 at 4:39 PM
    Ozark_RegCab
    Ozark_RegCab Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    They have some of the worst reliability ratings according to CR. The drivetrains are actually decent, and the axles are way better than anything new from Toyota. Hell, I’d take the linked Dana 44s over the 80 series axles. But all the electrical gremlins and poor build quality lets them down.
    If only Toyota could get their head out of the sand and build something with the same or similar axle/suspension set up under it.
  6. Jan 19, 2024 at 4:40 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I've seen a few instances of that on the forum, not often
    Kind of wish mine did so I could've replaced it with the Grand Vitara one
    The starter did fail though; easy rebuild
  7. Jan 19, 2024 at 4:40 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Did you ever replace that?
  8. Jan 19, 2024 at 4:42 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Toyota's marketing team might know a thing or two :burp:
    01x4 likes this.
  9. Jan 19, 2024 at 4:43 PM
    01x4
    01x4 I know what I'm doing?
    Coast of Southeastern VA
    Hey, like the 22RE, reliability is overrated. You have a warranty. Even get a ZF trans. Get on it.
    Kwikvette likes this.
  10. Jan 19, 2024 at 4:46 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    It just stops there. I do have dual super bumpstops on the LCA to arrest up travel. Those work like helper springs and lift one side or the other over a washout to keep the wheel from tucking up into the wheel well.
    If I need more downtravel on one side of the front, then I'm usually twisting, and the bumps push one side up and the opposite side goes lower. It twists the frame, but that's ok.
  11. Jan 19, 2024 at 4:47 PM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    Yea a warranty isn’t always that useful. I talked to someone that got one with never ending electrical gremlins and fluid leaks, and the dealer just gave him the runaround. They tried telling him ATF coating the underside was just grease, and he traded it for a 2500 Cummins since the “service department said it was fine”.
    A former coworker is having a similar ordeal with his oil-burning 5.0 F150. They were telling him it was within normal range, so he might be stuck with it unless he takes it to corporate. Meanwhile my shitbox with 250k on the clock only loses about a quart every 5k, and his Ford burned 5x that amount basically off the lot.
    CS_AR likes this.
  12. Jan 19, 2024 at 4:49 PM
    eon_blue
    Azusa, CA
    The 2 door ones are pretty cool
    Not cool enough to deal with the 3.slow or a 4banger in one, but I like the look
  13. Jan 19, 2024 at 4:49 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Shit not yet. But I probably got enough raises already to
    01x4[QUOTED] likes this.
  14. Jan 19, 2024 at 4:50 PM
    01x4
    Welp. Moral of the story: EVERYTHING SUCKS.
    Just choose the one you can best live with and figure it out without overthinking.
  15. Jan 19, 2024 at 4:50 PM
    01x4
    Put it off until you can get a Dakar. Prob take you one more year haha. 20 hour days.
    Sperrunner[QUOTED] and Kwikvette like this.
  16. Jan 19, 2024 at 4:51 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You should worry less about everything you'll never own and more about fixing your truck :rofl:
    CS_AR and 01x4 like this.
  17. Jan 19, 2024 at 4:54 PM
    01x4
    Ain't. Gonna. Happen.
    Kwikvette[QUOTED] likes this.
  18. Jan 19, 2024 at 4:54 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I've always wanted to own an RS200
    Hearing one racing as a kid, that sound never left me :drool:
  19. Jan 19, 2024 at 4:58 PM
    01x4
    Legendary. I've never even seen one in person. Such a little beast.
  20. Jan 19, 2024 at 5:00 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I became a diehard WRC fan when my dad took me to watch them (we lived in Germany)
    It continued when he let me get into it in the RC world
