  1. Jan 20, 2024 at 10:54 AM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    Uhg now I need a cut chart instead of all the tool profiles I made.
    I guess the feed rate will carry over.
  2. Jan 20, 2024 at 10:55 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Table has the latest firmware, and Firecontrol has remain unchanged for some years (still 1.6)
    It's just something they ignored altogether :rofl:
    I do remind people in my group often though "it is absolutely the most affordable table on the market" so I can't expect much myself if I'm convincing others to feel the same way
  3. Jan 20, 2024 at 10:55 AM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    Basically yes, but the cam output of f360 apparently has only a few brands/models with native support.
    Kwikvette likes this.
  4. Jan 20, 2024 at 10:56 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Yeah feedrate carries over, and kerf width is absolutely considered in your tool paths
    You just have to manually adjust pierce delays; but you said your cut height was off
    Did you never use the cut height in the post process section?
  5. Jan 20, 2024 at 10:57 AM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    Before I bought mine I thought about upgrading my ender 5 to be a plasma... It has way more features lol
  6. Jan 20, 2024 at 10:58 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    In the back of my mind, I still consider going with the extruded aluminum way and going rack and pinion for my movement (making a new table)
    The problem is I don't know of anything else I'd be able to use outside of Mach 3
  7. Jan 20, 2024 at 10:58 AM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    No... that's my big dumb
    But it cut pretty well, but never great.
    Kwikvette[QUOTED] likes this.
  8. Jan 20, 2024 at 10:59 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    That would be interesting. I just want a used Haas VF2, is that too much to ask. I could turn that into a money printer really fast
    jubei and Bandido[QUOTED] like this.
  9. Jan 20, 2024 at 10:59 AM
    eon_blue
    Azusa, CA
    gimme one of them chicken nuggs
    Speedytech7[OP] and Kwikvette like this.
  10. Jan 20, 2024 at 11:00 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Ahhh that makes sense!
    My cut height programmed is 0.045" which translates to a physical cut height of 0.06"
    So there's a little deviation you have to make up for
  11. Jan 20, 2024 at 11:00 AM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    A buddy of mine just bought a few haas machines and is starting a real machining business of his own.
  12. Jan 20, 2024 at 11:02 AM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    Whichever version I am running has the .02 ihs setting built in... And fusion was adding as much as .06 depending on the extruded material thickness it seems
  13. Jan 20, 2024 at 11:02 AM
    Speedytech7
    My former shop foreman and close friend started his own machine shop last year, doing mostly manual work but is now looking to buy a VF4 and SL30. I'm excited for him. I actually liked creating tool paths for them because Haas has awesome canned cycles and post processor support.
  14. Jan 20, 2024 at 11:05 AM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    I've only had experience with a gx series Bridgeport, and with the auto edge finder and touch off functions it did everything you told it to without a ton of thinking required.
    Speedytech7[OP] likes this.
  15. Jan 20, 2024 at 11:09 AM
    Speedytech7
    I've never got to play with any of the Bridgeport cncs, even the converted knee mill style ones. I've only messed with Haas machines and Fadal, and the Haas Auto edge finding is pretty damn good. They've got two different styles of edge finder now, for most of the stuff I did because it was all Job shop work I just touched off by hand.
  16. Jan 20, 2024 at 11:09 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Yeah springback is there regardless; try it on a sketch for an item you didn't extrude (I don't extrude half the stuff I cut) and it'll still occur.
  17. Jan 20, 2024 at 11:43 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Holy fuck that 3rd Gen is way overloaded
    ace_10 likes this.
  18. Jan 20, 2024 at 11:55 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Wut
  19. Jan 20, 2024 at 12:01 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    So i logged into the book of faces for the first time in 5 years. Its very very creepy how good the 'people you may know' recommendations' are - several people i've met since, but barely interacted with.
    @Kwikvette So which group is the one with all the good plasma table info?
  20. Jan 20, 2024 at 12:02 PM
    0xDEADBEEF
    On the upside, my feed is full of far side comics for some reason.
