  1. Feb 7, 2024 at 5:52 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I used to own a Zune; was my music lifeline in Iraq :anonymous:
    JWoodall and 01x4[QUOTED] like this.
  2. Feb 7, 2024 at 5:52 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Working on an apple pipe already
    01x4[QUOTED] likes this.
  3. Feb 7, 2024 at 5:53 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    This shit is annoying, really hard to get the ceramic out of a spark plug. Welded a Toyota drive shaft nut to an old spark plug to make an adapter for the compression tester.
    jubei and 01x4 like this.
  4. Feb 7, 2024 at 5:55 PM
    01x4
    01x4 I know what I'm doing?
    Coast of Southeastern VA
    If it helped your deployed sanity, it gets a pass.
  5. Feb 7, 2024 at 5:59 PM
    01x4
    No words, I'm conflicted and intrigued by its existence. Its glorious.
    The lack of interior shag carpeting is an oversight.
    https://greatdalehousecar.com/
    jubei likes this.
  6. Feb 7, 2024 at 7:36 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Downloaded and compiled Dectalk. My phone ringtones will never be the same.
    Speedytech7[OP] likes this.
  7. Feb 7, 2024 at 7:52 PM
    eon_blue
    Azusa, CA
  8. Feb 7, 2024 at 7:53 PM
    eon_blue
    Azusa, CA
    Sofia would pop a squat like that after she started walking whenever she was pooping
    Kwikvette likes this.
  9. Feb 7, 2024 at 8:20 PM
    Speedytech7
    That voice is fascinating, I love the way early speech synthesis works.
  10. Feb 7, 2024 at 8:21 PM
    Speedytech7
    Damn they grow up so fast walking and pooping at the same time...
    Actually that might truly be impressive, I've never tried but I think its probably hard to do.
    eon_blue[QUOTED] likes this.
  11. Feb 7, 2024 at 8:23 PM
    0xDEADBEEF
    Yeah, its amazing what can be accomplished with such little processing.
    Its still in use too - every US airport's ATIS system has it:
    https://youtu.be/NOVot7p2IGI?t=20
  12. Feb 7, 2024 at 8:27 PM
    Speedytech7
    It's pretty well rounded, people even get it to sing. Has the familiar speech synthesis sibilants though, took a long time for computer voices to get past that. Makes sense it is still in use, easy to implement and programs have had the ability to make hardware calls for it forever. I guess it is probably all virtualized these days huh, no reason to employ a dedicated box for it anymore.
    0xDEADBEEF[QUOTED] likes this.
  13. Feb 7, 2024 at 8:30 PM
    0xDEADBEEF
    I just need to put it on a raspberry pi and hide it at the girlfriends house. Haunting via SSH is totally my jam :burp:
  14. Feb 8, 2024 at 4:45 AM
    JKO1998
    Utah
  15. Feb 8, 2024 at 9:13 AM
    JKO1998
    Utah
  16. Feb 8, 2024 at 9:21 AM
    eon_blue
    Azusa, CA
    Apparently Nebraska is changing their tourism slogan, I thought it was pretty good
  17. Feb 8, 2024 at 9:45 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @Speedytech7
    Freaking cpu cooler arrived, and won't fit
    It's a NOS Thermaltake with everything inside; using the correct mounting plate (only 1 cause using AM4 omitted use of the plate) and nope
    Bracket sits nice and flat with clearance all around
    Only ever experienced this once in my life where the cpu sits "high" in relation to where the cooler rests once in place
    Remove the bracket, install the heatsink in said bracket, and check clearance and yeah you can see the cpu depth raises the whole assembly
  18. Feb 8, 2024 at 9:46 AM
    Speedytech7
    Pretty sure you need to fasten the bracket down first to the mobo and then use the tension clamp to secure the heat sink on, should be under a good bit of pressure when installed.
  19. Feb 8, 2024 at 9:48 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Yeah, I've built plenty of these before
    What I'm saying is, you put one clamp on, and then you use the other to clamp (tension down) on the cpu
    But the height of the cpu is significantly taller
  20. Feb 8, 2024 at 9:49 AM
    Speedytech7
    Enough so that you can't get the clamp to seat or is it just hard to? This was fairly standard back in the day for multi fit stuff, I've seen em bow the motherboard on the cheaper ones that don't have a backplate even
