  1. Feb 25, 2024 at 10:27 AM
    Ozark_RegCab
    Ozark_RegCab Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    No I read it, I just thought maybe there was some obscure change in the coil buckets in 98 or something when I saw that. But I think they just put that cause the leaf springs are different so it carried over to the front coils too.
  2. Feb 25, 2024 at 10:28 AM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    I’ll call them tomorrow and make sure it’s actually in stock. Websites don’t always update that quickly.
    01x4[QUOTED] likes this.
  3. Feb 25, 2024 at 10:28 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    The only difference in coil buckets that exists in this platform is between 4Runners and tacomas. The coil buckets are exactly the same but the three bolts are clocked differently on the 4Runner. Same bolt spacing it's just the coilover faces slightly different if it doesn't have a separate set of holes on top but pretty much all manufacturers have double drilled top hats for both patterns anyway
  4. Feb 25, 2024 at 10:29 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Nowhere did I say anything changed with the IFS
    I was using the leafpack difference as an example as to why they possibly excluded the front coils from "fitting" on older models
    They're most likely playing it safe
    Ozark_RegCab[QUOTED] likes this.
  5. Feb 25, 2024 at 10:30 AM
    01x4
    01x4 I know what I'm doing?
    Coast of Southeastern VA
    Very true, always a good idea check. :thumbsup:
  6. Feb 25, 2024 at 10:30 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I knew this already, as my King 2.5's were purchased for my Tacoma and I installed them on my 4R
    Well, I talked about this off-site with Ryan and just told him "oh yeah I just stuck a rod through the bottom eyelet and turned the shock"
    Didn't know you couldn't do that with Bilstein's as I never owned a set of their front shocks :rofl:
  7. Feb 25, 2024 at 10:31 AM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    Does he have a website, or you just message him?
  8. Feb 25, 2024 at 10:31 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Careful, you might blow your coil bucket out
  9. Feb 25, 2024 at 10:32 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
  10. Feb 25, 2024 at 10:32 AM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    True I better gusset and brace it with a tungsten vibranium alloy.
  11. Feb 25, 2024 at 10:32 AM
    Speedytech7
    You can turn the bottom of any shock. Most people are just worried about the heims at the top not being in line with or perpendicular to the direction of motion. But it really doesn't matter because the front on these trucks is actually almost vertical motion there's not much twisting.
  12. Feb 25, 2024 at 10:33 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I forget what specific shock it was, he'll chime in
    But yeah 2.5 coilovers could just twist but on his shocks, there was an integral part about the whole thing that wouldn't allow you to "clock" it
    He was going to use his Tacoma fronts on his 4Runner
  13. Feb 25, 2024 at 10:34 AM
    JKO1998
    Utah
    I've never even paid attention to that haha
  14. Feb 25, 2024 at 10:34 AM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    The 4Runners also have smaller tie rods apparently. I’m not really sure why they did that.
  15. Feb 25, 2024 at 10:36 AM
    JKO1998
    Utah
    Balljoints are different too
  16. Feb 25, 2024 at 10:38 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    If you swap the tie rod ends on the 4R with Tacoma variants, you can use Tacoma ball joints as well
  17. Feb 25, 2024 at 10:40 AM
    JKO1998
    Utah
    Riiiight
  18. Feb 25, 2024 at 10:41 AM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    The frames are too. I’m not sure if they’re any better or stronger than the Tacoma frames though. A lot of people swear the Toyotas made in Japan are better, but idk the NUMMI stuff seems pretty high quality.
  19. Feb 25, 2024 at 10:41 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Bought @Wulf ball joints from her Tacoma, and threw them on the 4R
    The only real change was minor and it was the turning radius
  20. Feb 25, 2024 at 10:45 AM
    JKO1998
    Utah
    Different frames huh
    from a truck to a SUV?
