  1. Mar 26, 2024 at 5:00 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Humidity hitting you really bad out there I take it? I heard reports of 300 pierces and said "fuuuuck that" but I'm also cutting a lot more often too
    Had done a quick test cut (for slots and sizing) before going full ham on a sheet of 3/16"
    Those consumables had over 300 pierces already
  2. Mar 26, 2024 at 5:02 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Don't let it get to you if it doesn't start on the first crank. It has to refill and Purge all the air out of the injectors
    time623[QUOTED] likes this.
  3. Mar 26, 2024 at 5:08 PM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    Yeah you are getting absolutely top tier results for the hardware. Make a plastic pressure vessel and freeze it to check your approximate dryness. If there's absolutely nothing a dryer won't be worth it.
    I know a dryer would be good for me, but I only really do build projects for myself and I'm not running the machine enough to make it better than it currently is.
    But the machine torch and a dryer are on my wishlist!
    Kwikvette[QUOTED] likes this.
  4. Mar 26, 2024 at 5:10 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Ah shit, great idea
    You're talking like those people use to trick their tire pressure sensor?
    Bandido[QUOTED] likes this.
  5. Mar 26, 2024 at 5:24 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    A 2 liter coke bottle can hold about 90psi. At least the old ones could. And, the base of a valve stem seals tightly in the neck.
    Bandido and Speedytech7[OP] like this.
  6. Mar 26, 2024 at 5:27 PM
    Speedytech7
  7. Mar 26, 2024 at 6:04 PM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    Basically this, just make sure to purge it, and do a few fairly redundant checks. If you get more than a few droplets worth a dryer will help.
    Also, how much moisture builds up in the tank of your compressor?
  8. Mar 26, 2024 at 6:55 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Proof that the cool kids drive Toyotas!
    414040643_10111701051915132_631507990687_ce184bdf5e8769d72cad64c89fe59744a5748f85.jpg
    Ozark_RegCab and eon_blue like this.
  9. Mar 26, 2024 at 7:41 PM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    SHES ALIVE
    No smoke, starts quick, not overheating
    Faint whirring sound from the front driver side, head or timing belt area… something I should be concerned about?
  10. Mar 26, 2024 at 8:03 PM
    Speedytech7
    Could be anything, new belts make noise, bearings in pulleys make noise when you tension more than previous if they were going out... Just monitor, but doesn't sound urgent by that description
  11. Mar 26, 2024 at 8:13 PM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    I don’t know how I feel about these weights. Discount hid these on the back after they stacked over a pound of the stick on weights 4-5 tall with the first tire. I had the brand new tire replaced because the manager swore my wheel was fine. He then tried to convince me over 16oz of weight is perfectly normal on truck tires.
    Swapping on my friend’s stock wheels and tires tomorrow to see how my truck drives with a known good setup.
  12. Mar 26, 2024 at 8:38 PM
    Speedytech7
    That definitely looks like the "I didn't want to rotate the tire on the rim" special
    04Pre_Runner[QUOTED] likes this.
  13. Mar 26, 2024 at 9:05 PM
    Running Board Man
    Running Board Man Well-Known Member
    Idk if you've seen the video but the shio was broken down... It lost power not even a minute or two before collision
    04Pre_Runner likes this.
  14. Mar 26, 2024 at 9:07 PM
    Running Board Man
    Tell them to do it again and turn off the dynamic balance feature... Demand they do it again with a static balance
    That *probably hunter* smart weight bullshit just gets confused with tires larger than ~30"
  15. Mar 26, 2024 at 9:32 PM
    04Pre_Runner
    Andrew
    Yeah... I'll report back how the stock wheels/tires from my buddy's truck handle. But I'm going back and having them redo this wheel specifically at the other Discount location in town regardless.
    What's crazy is they replaced a tire over this. If they're trying to be lazy and just get me out the door why deal with me 3 separate times. They could've just done it once correctly and saved time. They also lost my wheel spline lug key and made me dig through their stupid bucket of spline lug keys. When I brought my spare lug key in to compare to the manager said "well you're holding your key right there" and couldn't comprehend that I had two keys. I guess that answers my question.
  16. Mar 26, 2024 at 9:51 PM
    Ozark_RegCab
    Ozark_RegCab Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
    I've been studying Dan's writeup on the LCAs - just a few points:
    -It sounds like buying the Moog/Mevotech arms and polyurethane bushings separately are not much cheaper than just getting the OEM LCAs. I'm thinking I'd rather just take my chances with the Moog arms as they come, especially since it says you need a 20-ton press (I'm not sure if you can rent those anywhere?).
    -Seems like a no-brainer to replace my leaky rack at the same time since it'd save on labor and I'm tired of it leaving drops everywhere. there's just no way I'm putting the old one back on. Maybe I could send it off to be rebuilt?
    -Wow, the alignment hardware is pricey; almost 200 bucks alone! Do you really need to order those as well?
    https://adventuretaco.com/guide/ste...ement-on-a-1st-gen-tacoma-or-3rd-gen-4runner/
  17. Mar 26, 2024 at 9:53 PM
    Speedytech7
    If your alignment hardware turns then you don't need to order it. But if it seized you'll have to cut it free in which case you'll need new ones. I don't know if you noticed but I'm in the background of a lot of that work because the first time Dan saw it done was me Mike and other Dan doing it to Mike's truck.
    jubei and Ozark_RegCab[QUOTED] like this.
  18. Mar 26, 2024 at 9:56 PM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    Yea it's a great writeup but I feel like the expense of that OEM hardware is kinda glossed over. It would really suck for them to be seized and end up dead in the water though. They never mentioned it being seized at the shops I've been to however.
  19. Mar 26, 2024 at 9:57 PM
    Speedytech7
    Well that's exactly what happened and that's why it got mentioned in the right of. Mike and I ended up driving to three different Toyota dealers to piece together enough hardware to put his truck back together. It's fairly expensive if you buy the OEM hardware but if you buy the aftermarket ones they just break so you might as well get the OEM ones and make sure to put anti-seize on them and then you don't have to have to worry about them seizing again or ever having to buy them again. All four of the ones came out of my last two 1996 trucks just fine. Really though unless you're in dire straits the cost isn't that much, it's like $200 and you're set. Immigrant scheme of things I don't know where you could get any other alignment hardware new for another platform for any less
  20. Mar 26, 2024 at 10:03 PM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    That’s fine but I don’t understand why everyone seems to balk at the cost of just getting the OEM LCAs in that case. The cost of the Moog plus poly bushings is not really much cheaper, and then you need the “special” tools like the 20 ton press etc. or have a shop press them in.
