  1. Apr 10, 2024 at 9:33 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Pair the fact that gold fish produce a lot more waste than many other fish, along with using water that wasn't dechlorinated, I'd bet they died due to high ammonia levels.
    Only takes 0.6ppm to kill most fish, and ammonia is produced by fish food (uneaten, decomposing), fish waste, etc.
    Need to establish a nitrogen cycle before adding fish. Haven't done this shit in over 16 years but you basically set up a tank and add dechlorinated water.
    You need to introduce ammonia, in order to create bacteria to handle the ammonia. The result of that is a drop in ammonia, and a rise in nitrites. Nitrites are still toxic, but not as toxic as ammonia, but are handled by other bacteria to create nitrates.
    Nitrates are much less toxic and having live plants helps with nitrate levels. After they reach a certain point (below 40ppm, some people wait until 20ppm) then you do a partial water change.
    In short, the longer the break between water changes, the more water you'll need to replace in order to bring nitrate levels down.
    You also have ph levels, water hardness, etc to monitor. A lot of fish can easily adjust for this but those levels can directly affect bacteria itself.
  2. Apr 10, 2024 at 9:42 AM
    eon_blue
    Azusa, CA
    I think we only had 4 or 5 over the years, I was a lot more invested in the toads I had for a few years. Had a couple firebelly toads, looked just like this
    They were technically poisonous but Firebellies don't usually irritate human skin unless you're really sensitive to them.
    when we had to move to Texas I let my brother's friend have them because he was really curious about them, little fucker put their tank outside the first night and they died in the cold
    Kwikvette[QUOTED] likes this.
  3. Apr 10, 2024 at 9:46 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Crazy, never knew you had any
    They need both a place to swim and dry land, with a nice temperature gradient right? I've had snakes so I'd think it's the same?
  4. Apr 10, 2024 at 9:49 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Goldfish are hearty MFs but you have to give them the basics, they don't care much about heavy metals but they want chlorine removed and they need lots of oxygenation. Other than that, they're great, but they're treated as giveaways so they often don't even get oxygenation or a water change.
  5. Apr 10, 2024 at 9:50 AM
    eon_blue
    Azusa, CA
    Yeah they are pretty small so the tank wasn't very big, but was half dry/have submerged. The worst part was having to do the crickets once every few weeks, if those things escaped into the house it was a nightmare getting rid of them
  6. Apr 10, 2024 at 9:50 AM
    eon_blue
    Azusa, CA
    Yeah we always won them at the church fair in little ziplock baggies, so I doubt they were given much thought from the get-go lol.
    Kwikvette likes this.
  7. Apr 10, 2024 at 9:51 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I don't get how people breed them; they stink like a MFer
    Never had one escape, but whenever I'd buy between 5-10, whenever I heard one chirp, that's the next one that god fed
    eon_blue[QUOTED] likes this.
  8. Apr 10, 2024 at 9:53 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
  9. Apr 10, 2024 at 9:54 AM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    I’m sure that whatever we do, it will be for the last enemy we faced and not the next, and that jobs in congressional districts will determine what the warfighter needs and not the warfighters themselves (see JSF).
    God forbid, we ya know… ask them or anything :rolleyes:
  10. Apr 10, 2024 at 9:55 AM
    eon_blue
    Azusa, CA
    If you go before me I'll make sure they flush you down the toilet as per custom
  11. Apr 10, 2024 at 10:08 AM
    eon_blue
    Azusa, CA
  12. Apr 10, 2024 at 11:28 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    m3bassman likes this.
  13. Apr 10, 2024 at 11:32 AM
    Speedytech7
    She thicc. These things aren't the good ones... the Chinook and early Dolphin are a two piece design that more sturdy and way less leak prone. I would like to see someone take this heavy duty chassis and slap 4wd on it though, me thinks it would be weirdly balanced and scary
    Digiratus[QUOTED] likes this.
  14. Apr 10, 2024 at 11:41 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Definitely needs a suspension and a tcase. Might be able to keep up with Ben's van
  15. Apr 10, 2024 at 11:41 AM
    Speedytech7
    :rofl::rofl:
  16. Apr 10, 2024 at 11:43 AM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    the rig those youtubers are driving around in SA with looks great from 10+ft away
    absolutely would love to do that.
  17. Apr 10, 2024 at 11:50 AM
    Speedytech7
    This is one of the better ones
  18. Apr 10, 2024 at 11:58 AM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    Workin' extra hard in the office today..
  19. Apr 10, 2024 at 12:01 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Rusted a pillar, fender, hood, and grill
    Love how the rear bottom of the bed rotted out completely :rofl:
  20. Apr 10, 2024 at 12:05 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Office work today as well :anonymous:
    time623 likes this.
