  1. Apr 17, 2024 at 6:15 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    There's a Delorean, a few old Porsche vehicles, and several more
    Tour991[QUOTED] likes this.
  2. Apr 17, 2024 at 6:32 PM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    What the hell did I do wrong
    Trying to flush my clutch fluid, read a few threads seemed the easiest way is to attach a hose to the slave bleeder valve, crack it open and let it drain while topping off the master reservoir
    I crack open the slave bleeder and nothing comes out?
    Some said they pump the clutch slowly to get it moving, so I try that then my clutch sticks to the floor.
    Tightened the bleeder back up and I got some clutch feeling back but I definitely got air in
    I’m confused
  3. Apr 17, 2024 at 6:39 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    @Ozark_RegCab @0xDEADBEEF
    The LS Macho Taco is coming to LIT Rigs and Coffee on Saturday. Then he'll be off to HSORP for a day of wild wheeling.
    437968299_2752519854912486_9773179951053_be776583ecb1c15183a77cb2991373709b516514.jpg
    unstpible, Laxtoy and Ozark_RegCab like this.
  4. Apr 17, 2024 at 6:56 PM
    Wulf
    rock raisin
    I had a similar problem, I ended up having to use a pneumatic bleeder on the clutch
  5. Apr 17, 2024 at 7:08 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    Yeah there is a lot of fun looking cars there.
    Kwikvette[QUOTED] likes this.
  6. Apr 17, 2024 at 7:17 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    So uhm, wow...happy and healthy cause one of them already molted
    Wulf likes this.
  7. Apr 17, 2024 at 7:22 PM
    Ozark_RegCab
    Ozark_RegCab Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
  8. Apr 17, 2024 at 7:26 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  9. Apr 17, 2024 at 7:44 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, LonePeak wedge camper, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    Fear of the number 13 is called triskaidekaphobia.
  10. Apr 17, 2024 at 7:47 PM
    Wulf
    rock raisin
    oooo
  11. Apr 17, 2024 at 7:48 PM
    Wulf
    rock raisin
    I think I killed another PS pump in the Tacoma lol . need to check the screen to make sure it's not clogged but it shouldn't be
    crawling on 35s is apparently hard on parts :notsure:
  12. Apr 17, 2024 at 7:50 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Mine is happy after a good screen cleaning now
  13. Apr 17, 2024 at 7:59 PM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    Yay! Cats humans came and got her after seeing the flyer. What a relief.
    Digiratus, jubei, unstpible and 4 others like this.
  14. Apr 17, 2024 at 8:03 PM
    Wulf
    rock raisin
    you still running ATF?
    I'm thinking about switching to the same synthetic hydraulic fluid I run in the crawler... I'm wondering if the ATF additives are what burn and clog the screen
  15. Apr 17, 2024 at 8:10 PM
    eon_blue
    Azusa, CA
  16. Apr 17, 2024 at 8:38 PM
    eon_blue
    Azusa, CA
    jubei, Kwikvette and 04Pre_Runner like this.
  17. Apr 17, 2024 at 8:43 PM
    Speedytech7
    Yeah but I've been putting in full synthetic maxlife since it should be more temp stable. I actually wondered if it was the return hose internal jacket breaking down, that's kinda what the shit on the screen looked like.
  18. Apr 17, 2024 at 9:22 PM
    eon_blue
    Azusa, CA
  19. Apr 17, 2024 at 9:49 PM
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    A little late to the discussion but I'll still voicing my opinion.
    What you went through in the lawn was probably "2-4D" its the active ingredient typically used in lawns because it targets the "broad leafed" vegetation.
    Glyphosate is the active ingredient in Round Up and it kills pretty much whatever plant you spray it with. A lot of glyphosate products have been removed from the shelves solely based on the % of active ingredients because too many rednecks think that if a little bit is good than a lot must be even better and that's where it starts causing issues.
    Years ago i purchased a consentrated bottle of Home Depot's brand HDX Glyphosate (round up) to treat half an acre of my own property and like the dumb redneck I sometimes claim to be i mixed it up stronger than needed thinking it would work better or faster but really everything ended up just as dead... Including at least one of my neighbors trees.
    Fast forward a couple of years later to when I became a licensed pesticide applicator and learned that that particular consentration of glyphosate is now only legal to buy/use if you have a pesticide applicator license (mine has since expired).
    Another snippet on top of that. Round Up (glyphosate) has seen a lot of lawsuits specifically linked to Non-Hodgkin's Lymphoma which happens to be the very same type of cancer that my dog recently passed away with.
    One of my not so favorite photos of Maggie shortly before she passed. you can clearly see a few of the lymphatic tumors in her neck, she also had some just above the knee in her back legs.
    It was a slow growing cancer and in this photo she had been living with it for about 5 years.
    in sort wear PPE while fucking with chemicals designed to kill things.
    Not wearing the proper PPE can be enough of an offense that they can suspend or revoke your license. Closed shoes, goggles, mask, long sleeves, and gloves are all "required"
    Pets should be kept away for at least 12 hours after spraying.
    A lot of flee and tic type medications/sprays people use for their pets are the very same chemicals used for killing roaches and things just at different consentrations.
  20. Apr 17, 2024 at 10:03 PM
    unstpible
    Derek
    Cedar City, Utah
    I other news, I saw another turkey
    m3bassman and Running Board Man like this.
