  1. May 9, 2024 at 12:05 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Nice, enjoy em! What hangers you using?
  2. May 9, 2024 at 12:07 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Post your work here!
    Learned quite a bit reading Zane's posts and helping a friend with his own 63 swap
    Might not get a Taco in the future but would be applicable to a Pick Up anyway
  3. May 9, 2024 at 12:08 PM
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    Slag factory. Seemed to be a lot cheaper than Ruffstuff and similar design. I wanted the gradual angle of the front perch unlike some. Buddy used the barnes kit and was getting hung up on the front perch quite a bit this past summer. Only downside of these not being french is that lip that could hang me up. But i think itll work out nice.
  4. May 9, 2024 at 12:09 PM
    TacoVio
    Kolton
    CO/WY
    Will do. Wanting to be done by the end of the day tomorrow. We will see if that works out.
    Kwikvette[QUOTED] likes this.
  5. May 9, 2024 at 12:10 PM
    Speedytech7
    Those look like they'll work well, I might take a piece of plate yourself and bridge the ledge to make a smooth ramp all the way to the rail, would be super easy.
  6. May 9, 2024 at 12:16 PM
    TacoVio
    Kolton
    CO/WY
    Thats what I was thinking as well.
  7. May 9, 2024 at 12:19 PM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    I'm thinking to make/french a set for the front and Make a rear unit from a ballistic fab 2.0 joint similar to a trailgear joint
    I also have a ridiculous plan to make 2x rear crossmembers to stiffen up my already boxed rear frame.... and box the little bit where the fuel tank crossmember currently sits
  8. May 9, 2024 at 12:22 PM
    Speedytech7
    You sure do got plans :p An actual X shaped crossmember would go a long way to stiffening up the rear though. A ballistic joint would work well since it is rebuildable, the TG ones have been really pain free so far.
    Kwikvette likes this.
  9. May 9, 2024 at 12:28 PM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    Main difference I see is that the ballistic units have adjustable preload, so the stints between rebuilds should be longer.
    also planning to run their threaded ballistic joints instead of heims for UCA's
  10. May 9, 2024 at 12:30 PM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    also speaking of grand plans... did you ever get that sequoia rear end under your rig?
  11. May 9, 2024 at 12:31 PM
    Speedytech7
    Because you're wheeling so much these days....
    I just load up the TGs with some grease after each trip so far no slop after lots of driving and a good amount of wheeling for 3 years.
    Bandido[QUOTED] likes this.
  12. May 9, 2024 at 12:32 PM
    Speedytech7
    I got it into the shop again, but no haven't taken out my rear yet because I have a few trips coming up
    Wulf likes this.
  13. May 9, 2024 at 12:32 PM
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    :bananadead:
  14. May 9, 2024 at 12:40 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    I'm feeling that. going to knock out a rattle can job and tie up a few loose ends then I'm done fawkin with it and just driving it
    Kwikvette and Speedytech7[OP] like this.
  15. May 9, 2024 at 12:43 PM
    Speedytech7
    I've had to stop rattlecanning things I care about, it just doesn't hold up that well. Started using the two part heavy roll on rustoleum stuff.
  16. May 9, 2024 at 12:46 PM
    Wulf
    rock raisin
    well that's the thing, I don't care too much about the Tacoma lol
    It's currently got failing clear, brown primer, and mismatched blue touchups going on. If I had the energy I'd probably do a cheap HVLP job
  17. May 9, 2024 at 1:02 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Have a sneaky suspicion my workload is about to triple :oops: maybe I'll get a couple
    dollar raise next month
    Wulf likes this.
  18. May 9, 2024 at 1:18 PM
    Speedytech7
  19. May 9, 2024 at 1:28 PM
    TacoVio
    Kolton
    CO/WY
    Then break and beat on it all summer and then comes the repairs in the winter :bananadead:
    After many rattle can jobs, I have found the Rustoleum Professional Enamel Primer and Paint is extremely durable IF you allow it to completely dry which seems like a long time to me. But once its hard, its pretty surprising how hard it is to grind it away with an angler grinder wire brush.
  20. May 9, 2024 at 1:49 PM
    Wulf
    rock raisin
    that's the ideal way to do it. hopefully less breaking and more wheeling while I collect SAS parts
