  1. Jun 18, 2024 at 5:16 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    Just for reference I paid $750 for the set on my 2nd gen. I agree with Zane, $700 to $800 is a good price point. New Valve stacks are cheap and simple to replace when doing a rebuild. Find a set and we could rebuild them in an hour or two. (As long as they are in better shape than @JKO1998 's)
  2. Jun 18, 2024 at 5:16 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    @Kwikvette
    Not sure what spring you'd need, but if it's 3.0x13" 600lbs, Accutune sometimes has take-offs for dirt cheap.
    https://accutuneoffroad.com/product/fox-3-0-x-13-x-600lb-coil-spring/
  3. Jun 18, 2024 at 5:19 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    So, I had completely dismissed (forgot really) the fact that the coilovers I'd be replacing is a 4Runner set
    I'm in no rush, would just like something I can rebuild long term
    So it isn't the valving part really (as that can be redone like Zane and James said) but just making sure the right coil is already on there otherwise I could swap them
    Need to see what coils the GX/4R use as they're meant for the heavier front end versus a Tacoma
    My current coilovers are Bilstein 6112's
  4. Jun 18, 2024 at 5:19 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    They're probably on mark @750ish, you probably have a lot more options than I do here. Just watch Facebook and other marketplaces, I'm sure they'll pop up, especially as the "season" ends.
    Kwikvette[QUOTED] likes this.
  5. Jun 18, 2024 at 5:21 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    And yeah @Tour991 you can show me how to rebuild them for sure, but the first rebuild I'd just drive them up to Zane just to finally visit his ass up north :rofl:
  6. Jun 18, 2024 at 5:21 PM
    6P4
    Colorado Springs
    Come to think of it, I have some 3.0x13" 650lbs I should offload...
    Kwikvette likes this.
  7. Jun 18, 2024 at 5:22 PM
    JKO1998
    Utah
    Liiiike
  8. Jun 18, 2024 at 5:24 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Good example, but that's in CO lol I ain't driving out there
  9. Jun 18, 2024 at 5:25 PM
    JKO1998
    Utah
    Make @Wulf ship em
  10. Jun 18, 2024 at 5:25 PM
    JKO1998
    Utah
    Wonder if they'd fit a Tacoma though
  11. Jun 18, 2024 at 5:28 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    They will; apparently the issue sometimes comes from the Tacoma lower control arm mounts...certain year coilovers are too wide so the mount needs to be grinded down or something
  12. Jun 18, 2024 at 5:28 PM
    JKO1998
    Utah
    I saw that, wonder about the rears
  13. Jun 18, 2024 at 5:30 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Rear lower mount needs replacing
    Er...the bushing that is
    I mis-spoke when I said the bottom front mounts need to be changed for Tacoma to a GX/4R, it's actually the rear shock lower mount
  14. Jun 18, 2024 at 5:30 PM
    Tour991
    James
    South Reno/Tahoe
    Just make sure you have the right spring rate. If you go to heavy it's going to drive like a brick.
  15. Jun 18, 2024 at 5:31 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    No no, Tacoma coils are too light so I just need to see what the spring rate is on a 4R/GX
    Just side tracking with someone about CAD work
    Did another meeting this morning, quick cash :D
    Tour991[QUOTED] likes this.
  16. Jun 18, 2024 at 5:32 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    It's a good Mount but I'm not sure I'd run it without also having poly engine mounts
    Wulf and 01x4[QUOTED] like this.
  17. Jun 18, 2024 at 5:34 PM
    JKO1998
    Utah
    Fck why do I want those shocks
  18. Jun 18, 2024 at 5:36 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Go pick them up, and mail me the fronts
    600lb up front works for me (as long as I keep it stock, which I will completely)
    650lb is what people normally run when they want a lift and everything on the GX using Tacoma shocks; I'm wanting to lower it from where I'm at
  19. Jun 18, 2024 at 5:40 PM
    Tour991
    James
    South Reno/Tahoe
    The extra cash is a great way to pay for all the truck stuff.
    Here is a set in Sac. The price is higher but there's a lot of extra stuff.
  20. Jun 18, 2024 at 5:40 PM
    JKO1998
    Utah
    But I want them for me
