  1. Jul 3, 2024 at 8:56 PM
    eon_blue
    Azusa, CA
    where has @0xDEADBEEF been anyway
  2. Jul 3, 2024 at 9:12 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I was gonna tag but then I got lazy
    eon_blue[QUOTED] likes this.
  3. Jul 3, 2024 at 9:29 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    Here you go
    Kwikvette[QUOTED] likes this.
  4. Jul 3, 2024 at 9:42 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Shiiiit, what paint you using on that?
  5. Jul 3, 2024 at 9:43 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Boomer church-goers, can confirm?
  6. Jul 3, 2024 at 9:52 PM
    Tour991
    James
    South Reno/Tahoe
    Ace primer and Rustoleum bedliner that I had leftover.
  7. Jul 3, 2024 at 10:17 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    California couple with his and hers LC250s.
    449784521_10232735349909033_324108020185_b0208ef912996dcaa40efd1cf8d8176f9d9564d4.jpg
    Tour991 and Sperrunner like this.
  8. Jul 3, 2024 at 11:27 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    CS_AR likes this.
  9. Jul 4, 2024 at 6:44 AM
    m3bassman
    m3bassman Well-Known Member
    Green truck
    CS_AR likes this.
  10. Jul 4, 2024 at 7:32 AM
    eon_blue
    Azusa, CA
  11. Jul 4, 2024 at 8:15 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
  12. Jul 4, 2024 at 8:45 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    You should hydro dip it some crazy pattern
    Tour991[QUOTED] likes this.
  13. Jul 4, 2024 at 9:11 AM
    CS_AR
    m3bassman likes this.
  14. Jul 4, 2024 at 9:11 AM
    Ozark_RegCab
    Ozark_RegCab Well-Known Member
    Nick
    Northwest Arkansas
    1996 Tacoma SR5 4x4 5 speed
    Sliders, lift, 275/70/17
  15. Jul 4, 2024 at 9:18 AM
    CS_AR
    After this starter job, I finally caved and ordered this topside creeper. I've got enough projects coming up where it might come in handy. My oldest son can crawl up in an engine bay without issue, but he travels with his job and is not always around to help. Right now, I remove the front wheels to lower it or let the air out of the front tires. If this saves me two hours in the next year, it will be worth it.
    448829233_1132608797807375_7813161397174_af336c4137d7795caa54bfc9c256cd57422d39d5.jpg
    449824072_1132611007807154_9168544241721_cac9b1150f1c009610489b35a52e5124a1ba247a.jpg
    unstpible and jubei like this.
  16. Jul 4, 2024 at 9:19 AM
    CS_AR
    That's no fun, especially in this heat.
    Ozark_RegCab[QUOTED] likes this.
  17. Jul 4, 2024 at 9:20 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Mileage is a bit high. I'll be curious to see what it ends up at.
    This is the first T4R I've seen with this wrap I think. There's a 1st Gen Tacoma I've see before with this combo. IIRC, it was in the Spokane/CDA area.
    m3bassman[QUOTED] likes this.
  18. Jul 4, 2024 at 9:21 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    i think you'll enjoy it they make engine work a lot less painful
    CS_AR[QUOTED] likes this.
  19. Jul 4, 2024 at 9:25 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    See! We told you it's an easy DIY
    Glad to see you working on it
  20. Jul 4, 2024 at 9:29 AM
    Ozark_RegCab
    Nick
    Northwest Arkansas
    He many bolts are holding this bracket in? I got the first two, but it looks like there’s on attached to a bracket.
    Black97v6MT likes this.
